Question about Samsung CLP 300 Laser Printer
Chronic paper jams
Ever since I bought this printer a year ago my daughter complains of constant paper jams which occurs about 85 percent of the time she attempts to print something. It is very frustrating and I can't seem to fix it for her.
Howard
email: horo64@yahoo.com
  • PrinterJunk Sep 12, 2008
    Same issue, sucks up paper then says there is a 'jam' even though there is not. Seems to be way to hot, possible overheating?
This printer in a hunk of S***!
Posted on Sep 22, 2008
    Problem Solver:
  • 5 Answers
If it appears to start printing sucks up a sheet a little way and then stops red light on etc try the waste toner trick. I was plagued by this problem for ages then took out the waste toner container sucked out the dust with a vacuum cleaner stuck it back no more jams. It is less a jam than the thing just getting an error from the waste toner. The other thing could be the paper feed roller. There is a rubber on this that grips the paper and feeds it if it is worn then the paper wont feed. I flipped it over kind of turning it inside out to get a fresh smooth side that will grip and feed the paper. If you are a little dextrous then it isnt a difficult job. Had two of these and problems on paper feed with both. The toner is expensive the waste container at a tenner is a ridiculous price. Still the second one was bought as it was cheaper to get the whole printer with toner than a 4 colour toner pack, I use it for spares! email if you want to try the feed roller trick.
Posted on Sep 20, 2008
Di151 All-In-One Laser Printer: Minolta Di151 copier. J2 Paper Jam Followed t...
Sensor may be bad, for that jam. cleaned the rollers?
also also mite need to replace the rollers for the draw try this ite you have alegacy Minolta machine Now Konica Minolta
May 15, 2010 | Minolta Di151 All-In-One Laser Printer
Change paper/letter appears constantly when
see in the printer menu on paper settings set it ot A4 and on the pc.should work
Mar 10, 2010 | Lexmark X342n All-In-One Laser Printer
Epson workforce 500 constantly has a paper jam after paper jam each time, ive loaded it about 100 times and its still the same problem and tried everything to make the paper go through fine. It worked a...
hi, sorry for the inconvinience youre having on this printer, but obviously, the printers rollers aren't good, there is a hardware issue on this part and you would need to go to a service center if they can replace the rolllers or better yet call epson to ask for the warranty option, if you bought it w/in 1 yr. they should replace it w/another unit, same model, txn
Feb 10, 2010 | Epson WorkForce 600 All-In-One InkJet...
Says rec paper jam slide left platen
check as follows. Give by turns several sheets. Localize, where paper is stoped attentively see that can disturb her(its) motion. Follows to pay attention to presence stranger subject ( such can be) , then, when you find, place of the constant grip, analysing reason, can is there jammed ragged paper, can was torn off protection of the corona, it wore slantings gross, please ask, beside who has occurred jam and that herewith occurred. I ?????? with this technology 20 years and always in such events ask, as this has occurred. Most often this reason scrap papers, which is not seen, hereinafter stranger subjects, even feminine emery board and staples. You manage, in this nothing complex.
Sep 13, 2009 | Canon PC1061 Copier
Canon PIXMA MP480 bought 4 months ago jams paper
paper jam problems are usually occured by dust and debris in the printer . clean up ur printer from inside . also align ur paper tray. that will fix the problem. thanks and take care of urself.
Jun 09, 2009 | Canon Pixma MP480 All-In-One InkJet...
Not Recognizing Paper/Paper Jams
its a hardware issue ..
try add some paper and arrange it properly on the tray and also try to check you paper pick sensor..try to resolder it..maybe it suffered loss connection..the sensor is located at the pick mechanism itself....
Good luck,..
May 19, 2009 | Lexmark X8350 All-In-One InkJet Printer
Laserbase mf3220 paper jams
usually that problem occur when the paper pickup feed roller has run out.....and theres nothing you can do about it....but you can try to cleaning the paper pickup feed roller with the soft cloth and soap water...
Feb 04, 2009 | Canon LaserBase MF3220 All-In-One Printer
Paper jam, Is this the fuser?
I have had the same problem. Changing the fuser is easy (about $85, and must be ordered through Dell) remove the 4 screws from the back, and you'll see the fuser. 2 screws, and 2 wires, and it slides right out.
Jul 16, 2008 | Dell 1600n All-In-One Laser Printer
Not printing, making me crazy
A paper jam has occurred. To solve the
problem, see “Clearing Paper Jams” on
page 6.3.
• The front or top cover is opened. Close the
front or top cover.
• There is no paper in the tray. Load paper
in the tray.
• The waste toner container is not
installed or full. Check the container.
• Your system has some problems. If this
problem occurs, contact your service
representative.
  • Also i can indicate that the Toner Cartridges are empty and need replaced with Genuine Samsung Cartridges
Jun 17, 2008 | Samsung CLP 300 Laser Printer
Paper jams
Check solinoid transformers that controls opening and closing of paper handling trays. Check and clean sensors from in and out of paper path. Check and clean paper rollers or heat rollers for dust and paper remains pieces. Please determine when is the paper jams occurs. Hope this gives you hints.
Best regards,
Rosener
Feb 05, 2008 | Lexmark E238 Laser Printer
Samsung CLP 300 Laser Printer Logo
184 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
