This is an interesting question! I'll suggest some basics, but if this doesn't help you out, can you please respond with what kind of system this is, what the OS is and if you are able to determine the firmware revision. I'd also be curious to know if this is plugged directly into a wall outlet, a power strip etc.
MS Windows does not have the ability to turn on its host PC from the "off" state, but it does have the ability to turn itself on from a sleep state. So for starters I would ask you to be sure the PC is truly off.
In the BIOS (where the computer stores its hardware options) there is almost always a setting for what happens in the event of a power failure. Specifically what happens when power comes back on. Options always include "stay off" (my recommendation) and might also include "return to previous state" (or something similar) as well as "power on". If your system's AC power is on a timer (unlikely but hey) you might find the answer is here.
Also in the BIOS, there may be some settings to specify what time you would like the system to power on/off at. This would be an obvious answer to your problem.
If you're not sure how to access the BIOS on your system, look for a line of instruction at first power on to let you know. Compaq it's F10, Dell and many others it's F1, others are F2. Once inside... don't make any changes you aren't reasonably sure about. And if you do make changes, be sure to save them before rebooting.
Hi
Just go into your BIOS settings
(as soon as your systems starts press F1, F2, Del , F10 buttons simulteneoulsy to enter into BIOS , usually any one of above keys will work for you)
So in the BIOS locate the Option - Advance - Alarm
Here disable the Alarm then you will get rid of your problem
i am trying to download the online computer game maplestory and i think i need the sp3 (service pack...
(More)
i am trying to download the online computer game maplestory and i think i need the sp3 (service pack 3) because i am having a problem downloading it because wen the wiz shield finishes a window pops up and sais that the package cant be opened and i have to verify if its a windows package. i was given advice to make sure my windows update was running sp3 but it wasnt so i had to upgrade to sp2 and noe i cant find the update for sp3 so i dont no wat to do
window xp;and printmaster gold 16; printmaster will not download fully, when i click on the...
(More)
window xp;and printmaster gold 16; printmaster will not download fully, when i click on the printmaster icon it has pop up that has windows has configures with windows ask for the install disk, then after all that the printmaster window pop up and then the compute frezzes and I have to do the ctrl, alt, delete to get out of it
I have loaded JUICE on my computer to get Downloads from BBC radio - When it searches -Scanning...
(More)
I have loaded JUICE on my computer to get Downloads from BBC radio - When it searches -Scanning feeds it comes up ''0 enclosures fetched'' I am using Windows XP
