Question about Marantz Televison & Video
Dvd inoperative, When disc is installed , unit diplays "No Disc".
SOURCE: Emerson DVD Recorder EWR20V
The problem is likely that you are using 8x/2x media. Though the booklet does not say it, the burner does not support anything above 4x for DVD-R and 1x for DVD-RW. Calling their tech support can (possibly) get an update for this problem. Otherwise, the burner cannot use anything but outdated media.
Posted on Jun 02, 2007
SOURCE: dvd recorder won't record on DVD-RW disc.
CLEANING THE DISC LENS ? If this unit still does not perform properly although you refer to the relevant sections and to ?TROUBLESHOOTING GUIDE? in this Owner?s Manual, the laser optical pickup unit may be dirty. Consult your dealer or an Authorized Service Center for inspection and cleaning of the laser optical pickup unit. FROM EWR20V5 OWNERS MANUAL FUNAI-CORP.COM
Posted on Jul 01, 2007
aceltix
  • 119 Answers
SOURCE: cannot play dvd
hy
try to clean the reading lense with a special brush cleaning cd.
youll find it computer stores.
most of the cases it works
bye
Posted on Feb 03, 2008
praky16
  • 744 Answers
SOURCE: Toshiba SD-K770 DVD player flashes error and BAD DISC
hi... the problem might be in ur dvd... If ur dvd is perfect and u found that ur player has some problem means the best solution is that to clean up ur dvd player lense which plays a vital role in reading ur dvd when u insert into it...For cleaning up ur lense all u need is a lense cleaner dvd available in electronic shops.. u can purchase it and play that dvd as normal one.. ur problem will get solved..
thank u rate me!!!
Posted on Feb 07, 2009
  • 9 Answers
SOURCE: DVD unit says, disc is empty, with all DVDs
First, insert the DVD into the recorder.
Then, try double-click on OPEN/CLOSE button on the remote control. You have to make it very quick - two quick clicks on the same button. If done correctly, you will first see OPEN, then CLOSE in the right corner of the screen.
When done successfully, the unit will recognize the DVD again (if the burner has not failed totally.)
I tried that with RD-XS55 (it has the same DVD-RAM drive as RD-XS35.) It is not perfect solution, but it might help temporarily. In my situation, it bring my dvd drive back to "life," so I do not need to do double-click all the time.
Let's face it, your burner is dying whether you like it or not. And new replacement would cost you around $200.
Posted on Dec 05, 2009
JVC STEREO DIPLAYS UGGRADING DISC AND NOTHING IS FUNCTIONING APPEARS TO BE A FIRMWARE PROBLEM CAN GET ANY SUPPORT FROM JVC CAN HELP? MODEL #CA-MXDK1
my JVC model MXDK15 has a message saying upgrade Disc, and is not working can you please advise how I can get it working again.
Many thanks
Aug 03, 2012 | Televison & Video
Toshiba DVR19DTKB2 user manual
i have a dvr19dtkb2 video and dvd freeview recorder it has froze on channel 800 tried unplugging it still froze when turned back on can you help please
Oct 12, 2010 | Televison & Video
Dvd player won't read disc
I believe Vizualogic has serious quality problems. I had RT20 installed and it was defective to start with. The headphones did not work on one unit and the other unit made a loud sound when it was turned on. I had the units replaced. The new units had a new problem - Disc Error. The players were not able to read the discs. The installer tried another unit and it also had the same disc error problem. Interestingly, the word disc was spelled as DSIC - can you believe the quality control on Vizualogic prodict?
The installer then found that a wire had come loose in one of the units. He applied some tape to hold the wire in place. The unit seemed to transmit sound again. Well, a broken connection, disc error in multiple units and incorrect spelling was enough to turn me off. I am now trying to get some other brand installed.
Aug 18, 2009 | TMI Products Vizualogic Headrest Pair...
Panasonic DMR EH56 permanent U88 Error on DVD- and HDD-Drive
displays when ther was somthing unusal detected with the disc while recoding playback or copy this is diplayed when the unit is in the recovery process to return to normal operation the unit is not broken once the display clears you can use the unit again
Jul 14, 2009 | Panasonic DMR-E55 DVD Recorder
Dvd player always says "no disc " when i play it...ed...
First try running a CD/DVD player cleaner disc thru the unit, you can find them at Walmart, Target, etc. Get one that uses fluid. If your lucky, it's just dusty and needed cleaned. If it's still inoperative, you need to send it to Bose for service. They will swap out the transport for a new one and you will get many more years of service out of it. Just occasionally clean it. The repair will probably run 100-150. You can call Bose support for average pricing for transport repair and they should give you at least a ball park estimate. Hope this helps
May 25, 2009 | Bose 3 2 1 GSX System
I have a thinkpad and running on windows 2000 pro. inop
Check with other discs. If you still receive such an error, you drive might be faulty
Mar 30, 2009 | Teac DW 28E CD-RW/DVD-ROM Burner
Supported media list
try using a CD-R or a CD+R they are diffrent formatts its the same for dvds i had that problem with mine
Mar 24, 2009 | iLO DVDR05 DVD Recorder
Navigation
I have found that copied dvd's don't always work properly and even the slightest blemish or scratch renders it inop also it is illegal to sell a copied disc as it infringes copyright, I understand that the genuine disc's are expensive but you get what you pay for.
Feb 24, 2008 | Pioneer AVH-P6500DVD Car DVD Player
Televison & Video Logo
20 people viewed this question
Top Marantz Televison & Video Experts
Electro Med Services...
Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
