Question about Acer Aspire 5500 5570-2609 Laptop
I can't get graphics to "save as" from CorelDRAW 8 installed into VISTA Home Premium
Title: Saving work created in CoreDRAW 8 on VISTA Home Premium
    Sergeant:
  • 306 Answers
Without more detail I can give you a useful tip -make sure that you are running as Administrator. With Vista you cannot always be sure of this so when you start the program right-click on the program icon and if it is the executable then the menu you see will have the 'Run as administrator' option. Vista works overtime on saving us from ourselves so program anomalies are generally a permissions issue.
Posted on Oct 14, 2008
Corel DRAW X6 problems
I presume you mean CorelDRAW Graphics Suite X6 and NOT technical Suite?
If nothing seems to work I would then do as follows.
1.Uninstall CorelDRAW X6 via Control Panel
2.After uninstalling X6 in the Control Panel - Go BACK to the Control Panel and uninstall "Corel Graphics - Windows Shell Extension".
3.Then go to Documents > Corel folder > Uninstall/Delete anything that says CorelDRAW X6
4.You can also go to C: > Program > Corel and delete anythign that says CorelDRAW X6
5.Repeat step 4, but choose folder called Programx86, and delete anything that says CorelDRAW X6
6.You should now have uninstalled everything that useally could disturb when you re-install from scratch.
7.NOW put in your DVD again with CorelDRAW Graphics Suite X6 - and INSTALL from Scratch.
8.You SHOULD now be able to run your CorelDRAW X6.
9.And NOW you should go online to www.corel.com and download and install Update/service pack and Hotfix for CorelADRAW Graphics Suite X6
10.It should in all normal situations work just fine on your PC with any Windows 7 version as well as any Windows 8 and 8.1 version.
11.Try to use a program to recover and view CDR files. For example, you can try this CDR Open File Tool http://www.cdr.openfiletool.com/
12.Also recommend to come to this forum. Many have useful information on the topic. http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/coreldraw/479-problems-with-cdr-files
Good luck and hope this helps!
Nov 12, 2014 | Corel DRAW Graphics Suite X5
Overheating
Have you checked whether the computer your using meets CorelDraw X6's System Requirements?
Other thing is are you keeping an eye on temperature of CPU especially if it's working really hard (Just like a cars engine that runs at high end of revs eventually cooling will not be able to be enough to keep it at proper operating temperature), therefore shutdown.
OR it's time to clean fans on CPU and or Case Fans etc.
All the best anyway.
Sep 03, 2014 | CorelDRAW Graphics Suite v.X6 - Complete...
Not sure what happened ,lost parts of my os for vista home premium 64 bit ,no sound, not even beepcodes,no text when atempting restore ,limited control in command promt, still have some stuff ,pictures...
Which do you have - Vista Home Premium or Vista Home Basic? The title of this question category and what you said you have doesn't match. I'll assume you had Home Premium 64 Bit. Yes you can upgrade to Windows 7, 64 Bit. Please be aware that there is the 64 Bit and the 32 Bit versions. Check with your OEM of the computer before you upgrade. In the upgrade process, Windows 7 will create a folder called "windows.old" once the install has completed. There you will find the data you had from the old operating system like pictures and documents. Before you do the upgrade, I recommend downloading and installing the Windows 7 Advisor to check on any software and hardware issues - the advisor will list those problems before you can upgrade so that you can make the corrections.
Dec 17, 2010 | Microsoft Windows Vista Home Basic for PC
I am using Corel X3 version and would like to open a file that was created with the X4 version. What can I do?
Step 1 Launch CorelDRAW Graphics Suite X4. If you don't own the software, download and install a free 30-day trial from Corel.
  • Step 2 Go to "File" "Open" and open the X4 file you want to convert into a backward-compatible X3 file.
  • Step 3 Go to "File" "Save As" and choose "CorelDRAW X3-compatible" from the "Save as Type" drop-down menu. Click "Save."
  • Feb 11, 2010 | CorelDRAW® Graphics Suite X3 Upgrade...
    Resolution issues since vista upgrade
    Just force and install the driver, It should be working good. I too had similar problem. I just forced and installed the driver even though it said that its not compatible.
    Nov 12, 2009 | Microsoft Windows Vista Home Premium with...
    What is a M.cdr file and how can I burn it to dvd to watch on dvd player?and the same for a dmg file?
    Detailed information for file extension CDR: File classification: Graphic Mime type: application/cdr, application/coreldraw, application/x-cdr, application/x-coreldraw, image/cdr, image/x-cdr, zz-application/zz-winassoc-cdr Identifying characters: Hex: 52494646, ASCII: RIFF
    Program ID: CDraw4 , CorelDRAW.Graphic.8 , CorelDRAW.Graphic.9 , CorelDRAW.Graphic.10 , CorelDRAW.Graphic.11 Associated links: XnView Other applications associated with file type CDR:
    • Elite Plus Commander Saved GameThe Identifying characters used for this association are:Hex: 45 4C 49 54 45 20 43 6F 6D 6D 61 6E 64 65 72 20 46 69 6C 65 1A , ASCII: ELITE.Commander.File.
    • Final Cut Pro CD/DVD Image File by Apple Inc.Final Cut provides Mac users editing tools, sound design, real-time motion graphics and DVD authoring. CDR files are ISO images and, if moved to a PC, can be renamed and burned as ISO files. Associated links: Ken Stone's Final Cut Pro Website
    • GameJack Virtual CD or DVD Image by S.A.D. GmbH.Appears to be an older extension. GameJack seems to use .XMD now.
    • Raw Audio-CD Data
    • Sound File This association is classified as Audio. Associated links: Linux Player
    The DMG file type is primarily associated with 'Macintosh OS X' by Apple Inc.. On the Macintosh, these files are treated like a real disk. They can be created with Disk Copy, burnt to CD or mounted as a normal volume. The DMG file also comes in different formats: HFS, HFS+, UFS, ProDOS, Linux, and Fat32 and so may also require special mounting software to account for the format. IsoBuster can interpret these files directly as can other programs such as UltraISO. The program TransMac, by Acute Systems, can both open and create DMG files on a PC.
    Oct 22, 2009 | Apple iMac 24" Desktop
    Can't open Coreldraw 12 file
    convert bitmap object in lo-resolution by convert to bitmap option & than try to save the document
    Feb 26, 2009 | Corel AE CorelDRAW Graphics Suite 12 for...
    Acer Aspire 5500 5570-2609 Laptop Logo
    71 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
