Question about Roper RAB2121KW Top Load Washer
The toppart of my adjitater wont spin around ony the bottom part does
How do i tighten the top part
The Bucket (actual part where you put your clothes) is very loose. When its on spin cycle, the bucket rocks against the sides of the machine. How do i fix this>
Posted on Sep 29, 2008
  • 1,314 Answers
You dont the top part spins independent of the bottom if its not working at all you can get a kit at appliances parts store to replace the dogs in it to catch when the agitator does its back stroke but its supposed to be loose
Posted on Sep 11, 2008
Noise from front wheel while driving whinning turn steering slightly to left stops , if bearing can i do my self transit 280 ,53 plate
Sounds like the bearing is loose, yes you can do it yourself. Remove the bearing dust cap, do you see a cotter pin, if so jack up the front wheel, remove the cotter pin and locking ring, then place your hand just at the bottom of the bearing, using your other hand gently tap the top of the tire, the bearing should come out, inspect it to make sure it is okay and not in need of replacement, repack the bearing with new bearing grease and reinstall it. Ajust the bearing to 0 play, do this by tightening the bearing nut, and grab the tire at the top with one hand and bottom with the other, then push and pull in opposite directions at the same time, if the tire wobbles then tighten the bearing a little more until the tire will not wobble. Spin the tire around forwards and then backwards serveral time and check for 0 play again. After spinning and 0 play is good, reinstall the nut locking device and cotter pin, and dust cover. Hope this helps, let me know.
Jul 01, 2010 | 1981 Ford F 100
How to fit a odyssey g3 gyro set
Hi MonkeyManTim
Firstly, remove the centre lock nut on the stem. This loosens the stem/headset. Pull the handlebars up and rest them next to the front wheel, make sure the brake cables aren't being stretched too much.
You'll see there is a locknut on the headset (at the top of the frame/top tube where you pulled the stem from) and loosen this (might need a massive spanner!).
Pull offthe toppart of the headset, ball races and lower part. Replace with the gyro bottom and top parts. Grease the ball bearing if they aren't already!
Slide it together, fit the stem and you'll notice the brake lines that come with it. Undo the rear brake, run the splitter cable from the front lever to the top half of the gyro, same with the bottom half. I found putting some padded stickytape on the bars helped here as the splitter cable would 'ting' off the bars.
Undo the front brake and run it through the stem hole, through the forks and cable tie it to one fork leg.
Test the brakes, adjust where necessary and on you go pulling bar-spins for fun. Please don't land a jump with the bars half spun, it hurts....a lot!!
Jun 22, 2010 | Mongoose 20-Inch Gravity Games BMX...
Bottom portion of agitator works, the top portion does not
Pry the agitator top off with a screwdriver (in the little slot provided)and remove the part with a 7/16" socket. Lift out the top part of the agitator and replace the four plastic dogs with parts from for $4.95 plus shipping.
I am replacing mine for the second time in 18 years. John
Jun 05, 2009 | Kenmore Washing Machines
Kenmore Elite Washer top load Wont spin
Sounds to me like the belt is broken or has slipped off. Try taking the back off (6-8 screws) and you will immediately see if that is the problem.
Dec 23, 2008 | Kenmore Elite 45986 Front Load Washer
Adjitater is ruining clothes. They get caught in the gap at the bottom between ther tub and the flange.
ngafm at your service!
Call service and don't run it any more!
you may cause more problems and cost more money!
Bless you,
please give me a good rating before you sign off
Sep 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
there is a tensioner pulley as well as the drum and motor
It hooks into a slot, usually on the floor of the case, and has a spring that pulls it against the belt to tension the belt.
Broken belts have been known to knock the tensioner out of place, it should be sitting on the floor of the case as should its spring.
There is usually ony one slot for it to sit in, self evident if you know to look for it
loop the belt around the drum.
slide the belt down the drum directly over the motor pulley
loop the belt around the motor pulley
pull the tensioner pulley hard to the end of its travel against its spring
wrap the belt around the tensioner pulley
release the tensioner so the spring pulls it against the belt
rotate the drum by hand to ensure the belt is aligned and does not pull offf the pulleys
reassemble case
dry clothes
its easier than it looks seeing a broken belt in the bottom of the case.
fd5c779.jpg tensioner may be on the bottom run pushing up, or on the top run pulling down
Jul 07, 2008 | Zanussi TC7114W Electric Dryer
Take the top off the unit,and check the springs..there are 4 on top and 4 on the bottom..make sure they a attached..and tighten
Jan 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My washer wont drain nor spin...
don't suspect yet for the belt! if the motor runs then the belt could be the problem but not exactly! you could tighten the belt by adjustments of some components.
for the drain, make sure that the drain hose is placed down. try to look for connection for the drain knob going to the drain outlet. it could just be a cut/broken line!
notice also if there is a leak (water) on the bottom of the washer spinner. if it has, then the water seal has worn out causing slipping and poor spinning!
Nov 15, 2007 | Kenmore 22942 Top Load Washer
Roper RAB2121KW Top Load Washer Logo
71 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
