Question about KitchenAid 24 in. KUDS25SH Built-in Dishwasher
Kitchenaid Dishwasher-Water Problem
Water line bent and replaced. Now ,when trying to run no water in the cabinet. The electrical seems to work fine. Did the key pad diagnostics, no problems
  • 641 Answers
Check that water entrance valve works (it is an electromagnet valve,loocated at the pipe's enterance to the machine). If it doesn't work, test that it get power. In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new valve.
Posted on Apr 25, 2006
    President:
  • 878 Answers
You want to make sure you do not have a sticky float assy. first of all. Next, see if you have 120 volts getting to the fill valve. Remove the harness and start a cycle. If 120 volts is present and still no water, you probably have a bad valve. If no voltage is present, check your door switch to make sure they are closing when shutting the door. The next issue would be the control board itself. This is all assuming you have water to the dishwasher.
My kitchenAid dishwasher won't drain well. the hoses are clear. solenoid seems to be opening and closing. What is my next step?
Hello there again I am really sorry we got disconnected
Please try this
The water doesn't drain from the machine
If the water doesn't drain from your dishwasher, check these: Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Jun 27, 2010 | KitchenAid Dishwashers
I have a stainless steel kitchenaid dishwasher that has come completely loose. I can pull the whole dishwasher out of the wall. I need to know how to tighten it back down?
Generally, these units just slide into the cavity, and then several screws are driven up into the underside of the cabinet top. Open the door and look up at the upper front lip. Either the screws were never installed, they may have pulled out of the wood due to being too short, or the cabinet is made of chip board and the screw holes were not pre-drilled. Hope this helps!
Jan 07, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
No water comes in my kitchenAid dishwasher
you only need prime to pump water out if you are not getting water to D/W it is most likely the water control valve
Oct 23, 2009 | Dishwashers
Kitchenaid (KUDM01TJWH0)
wires where thy bend at bottom of door and heating element....water in motor
Aug 14, 2009 | KitchenAid 24 in. KUDM01TJ - Multiple...
KitchenAid KUDR24SE dishwasher doesn't drain.
check the drain tube at the disposer
Jul 02, 2009 | Dishwashers
Kitchen aid dishwasher
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 17, 2009 | KitchenAid Dishwashers
KitchenAid KUDP02 built-in dishwasher will not fill with water
Couple of things that come to mind here... May be helpful or not - but after all this is free ifo and probably worth what you are paying!!!
Anyway:
1: Have you tried removing power from the appliance?? All these modern appliances use a microprocessor and - like MS WINDOWS - need a kick up the bum now and then - (Well.. with Windows it seems to be every day- hour -minute - or so)
2: Dishwashers are installed with water reduction valves, so there could be a problem with one of there (particularly the hot water side).
3: The water inlet is controlled by soleniod valves (read: electronic valves). If the valves are not opening, no water will enter the appliance, so there could be a problem with the valves.
Nov 25, 2008 | KitchenAid 24 in. KUDP02CR Built-in...
Water is not draining
Your drain pump might be bad/disconnected. Check the underside of your machine for disconnected wires.
Dec 17, 2007 | Whirlpool 24 in. GU3200XTP Built-in...
KitchenAid 24 in. KUDS25SH Built-in Dishwasher Logo
348 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
