Question about Jura Capresso Impressa E75 Espresso & Coffee Maker
Malfunction 5 Our Impressa E75 is showing a malfunction 5 message, but I can't find any reference to it in the manual. Any ideas
  • 46 Answers
SOURCE: jura impressa S70
its a grinder group fault , the seal on the internal group head (the part that compresses the ground before brewing) has stuck or gone dry from lack of use. if u gain access to the internal of the machine( may need a special tool, oval head srews) grease with food grade lube, the red/orange seal on the long 45 degree cylinder inside. u can manually turn the gear by hand once inside. If still a problem check the motor that drives the same unit.
Posted on Feb 09, 2008
SOURCE: Malfunction light on Jura E75
I just called the company with the same problem today. They will fix your machine for free. They have recalled this machine. Call them and they will tell you what to do. 201-767-3999
Posted on Mar 20, 2009
  • 13 Answers
SOURCE: Jura impressa E75.message mafunction 8 shows up
Malfunction 8 is related to the brew unit typically. It is usually an indication of the brew unit motor having to work too hard to move the brew unit up and down. This is usually cured by disassembling, cleaning, replacing any o'rings that may be bad, and lubricating the unit, then reassembly.
I have had to do this twice on an an E75 and an E8. I finally broke down and bought seal kits and lubricant for doing this. One could by a new brew unit off of e-bay and change out the whole thing. But a simple rebuild will typically suffice.
Mike
Posted on Jul 05, 2009
  • 60 Answers
SOURCE: jura impressa f9 malfunction 8 i need help whats
Malfunction 8 means that the brew unit can not get in the right position in the right time. This is usually because the brew unit is full of old coffee grounds. Try to shut down the machine for one day. The next day, take out the tray and clear out all coffeegrounds inside the brewunit. Use your fingers and maybe a small towel. You can do this right away, but it is easier when everything`s dried up. When all this is cleaned up, start manually a Cleaning program. This should solve your problem.
If it doesen`t, i could be that the o-rings inside the brew unit is defective and needs to be changed.
Posted on Jul 09, 2009
espressonist
  • 1711 Answers
SOURCE: Jura Impressa F9
You can find some detail procedure in this tip below
http://www.fixya.com/support/r5713182-jura_capresso_impressa_f9_malfunction_8
Try it since it have help some other with same problem.
Posted on Aug 23, 2010
Display tap on Jura Impressa E75 say close tap, where is tap please
The tap is the dial on the left turn it, then it will turn the tap off. If it is repeating this then it may need to be decalcified.
Sep 06, 2012 | Jura Capresso Impressa E75 Espresso &...
I have a malfunction 8 that shows up
malfunction 8 is the brewer piston oring. one from a franke saphira will work.
Aug 26, 2011 | Jura Capresso Impressa F9 Espresso Machine
How to fix error message 8
DISPLAY SHOWS MALFUNCTION 8 Solution: Turn off and unplug machine. Wait a minute. Turn machine on and wait until it stops making any noise. Now try to pull out the drawer. If this does not work, try the procedure again. If this does not work, call customer service
Regards Kat (please leave feedback, many thanks)
Aug 19, 2011 | Jura Capresso Impressa E8 Espresso/Coffee...
Impressa S70 - Malfunction 3
This indicates that either the sensor for the thermoblock is defective or the thermofuse is blown. For this you need to go to your local dealer for service. I also recommend that you measure out the mains.
In worst case the powerprint or the mainboard sends wrong signals to the thermoblock so it`s overheated.
Aug 02, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
Nov 17, 2008 | Jura Capresso Impressa E75 Espresso &...
Jura Impressa F9
Nov 09, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Mike
Aug 12, 2008 | Jura Capresso Impressa E75 Espresso &...
Impressa E75 leaking out bottom
kat346 There are a number of places were the leak could be occurring. I can't pinpoint it without see inside your machine. I maybe something like a broken or dried out oring or a cracked fitting or heater cartridge. We repair E75 www.hotncold.com
Feb 05, 2008 | Jura Capresso Impressa E75 Espresso &...
Jura Capresso Problem
check out this link:
http://www.kuntze.de/E/index.htm
May 12, 2007 | Jura Capresso Impressa E75 Espresso &...
Jura Capresso Impressa E75 Espresso & Coffee Maker Logo
37 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
