Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv no sound
No sound.
Mute and SAP checked. Speakers on.
  • pkschmidt Oct 04, 2008
    I have a Sony Triniton. It is in the SAP mode and I don't have the original controller as I purchasedd it used. Anyone no how to reset it to factory settings or how to get it out of this mode. When I select the menu on my Sony Universal remote it only displays stuff like time set, closed captioning, and channel block.
  • frankiemud Nov 11, 2008
    suddenly no sound from tv but still sound thru headphones-sony trinitron 7 years old
I have a onwa tv and i want a remote code for this tv
Posted on Oct 18, 2008
    Problem Solver:
  • 6 Answers
Ther is a problem with the sound box of th TV. Please contact the company from where u purchased ur TV set. And please from next time onwards send your correct and full name or u will receive no help from me. If any other problem is there then feel free to contact me at prakharsrivas7@yahoo.com
Posted on Sep 26, 2008
I am getting no sound out of my Panasonic Viera TH-50PX80U Plasma TV
Are the speakers' cables connected correctly? (p. 37) Is "Sound Mute" active? (p. 13) Is the volume set to the minimum? Is "Speaker output" set to "Off"? (p. 22) Change "SAP" settings. (p. 16) Check "HDMI 1 in", "HDMI 2 in" or "HDMI 3 in" settings. (p. 22)
Hope this helps, page# refer to your manual.
Feb 14, 2015 | Panasonic Viera TH-50PX80U Plasma TV
Why do i hear no sound from the tv
Most often caused by a mute circuit or the mute button pressed. Others are a wrong sound setting. Such as being set for Dolby Digital sound.
Oct 16, 2014 | Vizio L32 32 in. LCD HDTV
Hitachi 32ld8700 ua no sound
Make sure you are not set to SAP mode...use mono or stereo.
Feb 03, 2012 | Hitachi 32LD8700 32 in. LCD Television
No sound on panasonic dv3 tv
Hello, if you have a cable box attached to your television,it can be the mute on the cable was accidentally enable. Check to see if it's on SAP, if so return it to stereo. You can also try to hook up the audio ports with some external speakers to see if that worked: if so you have to replace either the speakers.
Thanks
Jul 05, 2011 | Televison & Video
I cant get any sound I did the trouble shooting
Changing the Audio Output
To switch audio output from the internal TV speakers to a connected external sound system or headphones:
Press 1. MORE.
Press 2. 9 (AUDIO).
Press 3. until the Speakers option is displayed. The Speakers option will display only if an A/V receiver connection has been detected.
Press 4. to switch between TV and either AV Receiver or Headphones.
Check if the MUTE key is on.
• The TV's "Listen to:" setting may be set to SAP (analog program from the ANT input) but no SAP is being broadcast.
• Check that the Speakers option is set to TV to hear sound from the TV speakers. Possibly sound is being sent to one of the audio outputs for an A/V receiver or headphones.
• If using an A/V receiver, check that the Speakers option is set to AV Receiver to hear sound from the A/V receiver speakers.
Press and hold the POWER button on the control panel for 10 seconds to perform System Reset.
Mar 07, 2011 | Mitsubishi LT-40151 40 in. HDTV LCD TV
I PRESSED AN UNKNOWN BUTTON AND IT TURNED THE SOUND OFF ON TV SET.
well mute button is too obvious, can't be that.Some remotes have an SAP button for secondary audio programming, meaning its looking for an audio feed in another language, that would mute sound if it didn't find it. So look for buttons labeled sap or audio. if you have a button labeled "display" it may tell you on the screen what setting the tv is currently on as well.
Jul 09, 2010 | Televison & Video
Matsui tvr 180T Tv set shows pictures but no sound
Hi and welcome to FixYa,
Offhand a couple of possibilities:
  • audio settings of the TV (mute, SAP) (most likely);
  • audio amplifier is defective (likely);
  • sound processor is faulty (least likely);
  • speakers defective (unlikely for both at the same time).
Try plugging an external amplifier with speaker to the audio out ports if the Matsui TVR180T model has audio out jacks.
Good luck and Thank you for using FixYa. Happy New Year.
Jan 02, 2009 | Televison & Video
I turned off the tv and when I turned it back on I have a picture but no sound. Please help. Samsung model#TXS3082WH
Check to see if the set is in Mute. Check to see if the speakers are turned off. Check to see if the volume is turned up. Go in to the menu and make sure the set is not in the SAP mode.
More than that, the set will probably require service to determine the cause of the failure.
Jerry G.
May 21, 2008 | Samsung Televison & Video
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
85 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
