Question about Fisher DEIX2 Dryer
Fisher and Paykel electric top load dryer
I have to "trick" this dryer to make it work. It will tumble and dry if I use the 20 or 40 minute timed setting. If I go up to 80 minutes, it stops with the drum locked and beeps until I turn it off. To me it seems like the dryer stops when it gets too hot. The delicate setting is usually problem free; the denim setting will start beeping in under 40 minutes. We have cleaned the lint trap, checked the outside vent (it blows just fine). Anybody have an idea or solution? My husband can fix it if you can point us in the right direction.
  • kagrove Nov 07, 2008
    Thank you! We cleaned it out last night and it was FULL of lint. I'll test it this weekend when I do laundry.
  • kagrove Nov 10, 2008
    Hurray!
    Alspals solution worked. Thank you!
Dd you try to unscrew the larger lint trap underneath the lint cup collector. My serivce person showed me how to do this and after a year I cleaned it out and was surprised how much lint was caught in there. My dryer was not heating and drying quickly, this helped the problem.
Posted on Nov 05, 2008
Dryer does not dry, looking for the reset button. Where is the button and how do i get to it?
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Oct 07, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Auto dry not cutting off when clothes are dry
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem. Your problem should either be dirty or bad connections with the contact continuity plates, the chrome things under the lint bucket or the control circuit.
Oct 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
FPaykel Dryer model # DE05US2 is making a screeching LOUD sound ... still turns and dries just VERY VERY LOUD and high pitched squeeling
It could be bearing or guides in the drum.Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Sep 27, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My dryer is a top loading Fisher and Paykel and it has started squeaking.
It could be bearing or guide in the drum.Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Sep 21, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Heating element will not shut off after drying. Top of machine is warm/hot all the time.
Pull the plug out of the outlet , wait 30 minutes and replug it. This may fix it. If it doesn't it sounds like the relay that operates the heater is faulty. Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will show you where the relay is located, check the posts regarding heaters, it should help.
Jul 01, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Fisher & Paykel top load electric dyer makes loud squeaky sound
to be honest i doubt that a bad belt would make a squicky noise and for a high class dryer like that i would suggest just call repairman  they are very complex
Jun 08, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Dryer takes MUCH longer to dry clothes than it should
Is the hose crunched down at all in the back
(vent hose)
Feb 09, 2009 | Fisher and Paykel Dryers
Burning smell after hitting the reset button
the lint may have moved into the motor/ or other areas, clean the unit again and have another inspection, checking for burn't wire etc.
Jan 25, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Dryer tumbles, no heat
Fist thing to check is if the manual reset on the heater box has tripped. That dryer can be serviced from the front. Also, there is a heater upgrade kit that can be purchased from Fisher Paykel Parts that has several updated parts in it for the top load electric dryers.
There are several things that can cause the reset to pop out. You may have a lint build up behind the shroud where the lint bucket fits.
This is a complicated appliance. You may wish to obtain a service manual for it.
Link to factory service manual:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=39
Link to heater upgrade kit:
http://fisherpaykelparts.net/index.php?categoryid=112&productid=32
Dec 17, 2008 | Fisher and Paykel DEIX2 Electric Dryer
Fisher DEIX2 Dryer Logo
740 people viewed this question
Top Fisher Dryers Experts
Tim Whalen
paul
paul
ray gallant
Are you a Fisher Dryer Expert? Answer questions, earn points and help others
