Question about Moulinex DG6 Food Processor
Model MH 920
The ON_PULSE button on the top of the cyclindar won't move It seems to be stuck. How does one get it "unfrozen"?
When the top section is clicked on and on button or pulse or dough button pressed it doesn't go. took top off and pressed the little black button to simulate top being put on and still no result.
Try taking the bowl off and pressing the safety switch with a screw driver. If the processor turns on then you have a problem with the bowl, if it doesn't turn on then the issue is inside of the food processor, and usually internal parts are not available.
If you can find your model & brand information off of the base of the food processor we can look up replacement parts for you.
Thank you,
colleen @ mendingshed.
May 12, 2015 | Food Processors
On button acts like pulse button
Replace switch, sorry didn't mean to say the obvious. Just good like that I guess
Apr 02, 2015 | Food Processors
Kitchen aide chefs chopper Model KFC3100ER2 does not always turn on when pulse button is pressed
You need to replace either the bowl or the lid. Either the lid is not pushing the bowl mechanisms far enough or there is too much lost movement in the bowl part.
Sep 14, 2013 | KitchenAid KFP715 7 Cups Food Processor
Cuisinart DLC-8S Food Processor: On/Off Switch not working
Replacement of the switch would be a likely repair unless other damage makes replacement impractical.
Apr 14, 2017 | Cuisinart DCC Food Processors
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
Cuisinart dlc-7 superpro food processor won't run.
The DLC-7 SuperPro is awesome -- very powerfull. Be aware they are 1.5 horsepower; the blade can take your hand completely off in a blink of an eye. Because of the potential danger, SAFEGUARDS are in place such that everything must be aligned and in correct position or it WILL NOT POWER-UP. So, yes, is very likely the safety switch.
Simple test: Use just the BASE, (no work bucket, no top, no blades), such that if it starts, only the spindle will turn. There is a little black button on the base, just back of the spindle. Use a chop-stick to depress it. Plug-in, press the button w/chop-stik, press the PULSE button. It should power up.
Presuming it powered up okay, the "problem" is probably in how the unit is assembled; such that the button is depressed properly.
1. The work bowl must be all the way down on the base, and the alignment column in the back, work bowl base skirt turned to the "Hard Stop". It will feel very solid when docked properly.
2. The top inserts and rotates into and snaps into position while pressing the plunger into the button.
It all sounds too easy, but if something is just a little off, the plunger doesn't plunge ind the power doesn't go on.
These are FABULOUS machines -- spend the time into getting it working. The near- equivalent if something this robust and powerful in today's products will cost nearly a THOUSAND dollars - seriously.
May 04, 2009 | Cuisinart DLC-2014 PowerPrep Plus Food...
Need to fit new switch assembly
Only two screws ?? this must be an older magimix 5000 machine, does the replacement part have a 10mm frame around or flush, the part you need is click here http://www.magimix-spares.co.uk/On-Off-Pulse-switch-with-frame-5000---5100-Chrome/product/101296/
Sep 15, 2008 | Magimix 5150 Food Processor
Euro pro food processor and blender combo
Defective pulse button or blender attachment not installed correctly.
Sep 12, 2017 | Euro-Pro EKP110 6.25 Cups Food Processor
Cuisinart won't pulse
I started from scratch with the assembly instructions. Got it together correctly and now everything works.
Mar 03, 2008 | Cuisinart DLC-2011 PowerPrep Plus Food...
Stuck sunbeam blade on spindle
Put some water in it and run it for a minute or so. That helped me with the same problem on the same processor.
Aug 12, 2007 | Sunbeam 4816-9 Food Processor
Moulinex DG6 Food Processor Logo
127 people viewed this question
Top Moulinex Food Processors Experts
clay_pots_47
clay_pots_47
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Moulinex Food Processor Expert? Answer questions, earn points and help others
