Question about Whirlpool Microwave Ovens
Whirlpool AVM 230 Microwave short circuit
My Microwave caused the circuit breaker to swicth off after pushing the start button. Being in a hurry I actually set the temperature and pushed the start button very rapidly after that. I'm pretty sure not at the same time though, since I had to move my hand to hit the start button.
After a pretty loud noise there was some gun powder like burned smell. A day later I opened up the device for visual inspection, but I couldn't find anything. After I put back the covering I powered it up again and it still seems to function.
My question is, is the microwave still safe to use now? Some component must have got damaged during the short circuit and something must have caused it to happen?
  • druiper Sep 17, 2008
    Thanks for your excellent reply. I have been using the microwave since I had the problem and it functions normally. But I'll keep the links you gave in mind in case of future problems.
    At the part store my model Whirlpool AVM 230/WP/WH was unknown. I figure it was only made for the European market or only labeled as Whirlpool but actually a Philips device.
  • Whirlpool Master
  • 9,098 Answers
If the fuse or breaker blew again, you probably have a shorted high voltage capacitor. If not, then you may have a shorted high voltage rectifier diode.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Sep 16, 2008
Microwave oven no power
The main fuse is probably blown.
When replacing, try to determine the cause.
if it has a bad door switch, then the monitor/short switch also must be replaced. On an inverter, replace the power relay as well.
If the fuse holder is not holding the fuse securely, then it will heat and blow.
A failing component in the high voltage circuit can also cause the problem.
Apr 04, 2014 | Whirlpool GH7208XR Convection / Microwave...
Hi,on my Samsung microwave over range,when I open a door my 20 Amp breaker in a panel goes off.This is a dedicated circuit and everything is OK until I open oven door.
the wiring to the oven light,or light swicth is shorting out.will likely have to have a repairman service it unless you know some one with some elect.experiance
Oct 12, 2010 | Samsung Microwave Ovens
Entered time, pushed start, nothing happened. Circuit breakers are o.k. Unit is only two years old.
If the oven is completely dead I would be looking at the internal monitor fuse, the most likely cause for this to blow is a poorly adjusted interlock switch.
Hope this helps
Jan 06, 2010 | Whirlpool MH7140XF Microwave Oven
I need english instructions for a Whirlpool Microvave Oven model AVM 230/WP/Wh, VIP-34, made in Sweeden
Having contacted Whirlpool UK, they at fisrt stated that this unit was not produced for thr UK (English speaking) market and that no manual in english existed. However, after we finished speaking a very resourceful lady at the Whirlpool head office found one and has mailed me a PDF. If you would care to mail me at chris.i.hall@hotmail.co.uk I will foreward it on to you :-D
Oct 09, 2009 | Microwave Ovens
J have mirowave oven Whirlpool AVM 918. It remain in calibration (CAL on display) when i push any button. I think that miss plate, there is turntable. I have'nt manual and the label that explain the cal...
i have the same microwave oven,
when the display say CAL, you have to calibrate first,
how to do this is: push on the left (cancel) button and hold it till it starts
May 15, 2009 | Whirlpool GH4155XP Microwave Oven
Circuit breaker continually trips immediately when used
check for a shorted hi voltage capacieor ,transistor or shorted multiplier diode
Nov 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Whirlpool AVM 230 360 microwave but no instruction on how to use it.
You should be able to download your owner's manual (instructions for use) here.
Enter either all or part of the model number of the appliance (e.g. AFG 549) or the 12 digit numeric code, (usually starting with 85) that can be found on the service sticker of your appliance.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 07, 2008 | Whirlpool Microwave Ovens
Microwave Ovens Logo
1,456 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
