Question about Whirlpool LSR5132PQ Top Load Washer
Washer wont do anything.......
I have a whirlpool lsr5132pq washing machine and it fills with water but does nothing else after that please help.l
  • 3 Answers
My whirlpool washer did the same thing recently. It ended up being something rather simple to fix. A screw had came loose (isnt that all our problems!) on the lid which held the switch for the washer to kick on when the lid shuts. All we had to do was replace the screw to hold the bar in place on the lid to work correctly. Make sure all your screws are there and tight before dismantling the control panel!!!
Posted on Oct 13, 2008
    President:
  • 1,314 Answers
The pressure switch may be bad there is a switch under the control panel it has a plastic tube coming to it from the tub when it fills with water the pressure stops the water and starts the motor now first turn the timer to final spin and see if it runs through that if it does the timer and motor are good and the pressure switch is prob the culprit to get under the control panel there are two screws on the back of the end caps back them out pull the panel forward and tilt it back on its hinges if you further help contact me
Posted on Sep 11, 2008
Overfilling with water after i took it apart to replace a hose. water wont stop running.
YOUR FILL VALVE IS NOT SHUTTING OFF GET A NEW ONE ON LINE SHIPPED TO YOUR DOOR IS THE BEST PUT ALL INFO IN ORDER A FILL VALVVE AND YOUR IN BUSINESS
Jan 14, 2011 | Whirlpool LSR5132PQ Top Load Washer
Will not fill with cold water
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 28, 2010 | Whirlpool LSR5132PQ Top Load Washer
Wont fill
heatman101
kjkj
Mar 24, 2010 | Whirlpool LSR5132PQ Top Load Washer
Washing machine fills, but will not agitate, drain or spin
Coupling broken which joins the motor to the gear box. Look and see or listen if the motor is running then if nothing else is working coupling is broke, easy to replace.
Dec 05, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washing machine wont stop filling with cold water
Since you removed the screens, the sand probably has entered the valve and damaged the spool. It's apparently sticking open. You need to replace the complete valve and keep the screens in place.
Jun 09, 2008 | Whirlpool LSR5132PQ Top Load Washer
Will not agitate,spin or drain
There's a coupler that normaly goes.just tip the machine over and loosen the motor.the coupler will be 3 legged and plastic.just replace and it should be ok.
Feb 22, 2007 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
69 people viewed this question
Dan Webster
Dan Webster
Sal De
