Question about Sony Car Audio & Video
I have a sony cd player for my car. everytime i turn the engine off, the pre set radio stations are wiped. what can the problem be?
  • 10,594 Answers
Its problem of connections. find yellow wire in player's rear connector and hook it always 12 volt as its supply to memory of player.
Posted on Sep 11, 2008
Hi, my problem is that each time I turn off the ignition I lose all my radio settings (i.e. the station pre-sets). My Sony is a CDX-L400X. I was wondering if there is an internal battery (like a button...
Hi, the problem is likely in the wiring or possibly a burned fuse. There is a separate wire to the radio that is always hot and keeps the station and clock settings while the key is off. If you tell me the car model and year, I may be able to tell you which wire and fuse to check. Was this working originally or has it never worked?
Aug 19, 2011 | Sony CDX-L400X CD Player
I CANNOT FIGURE OUT HOW TO PRE SET MY STATIONS FOR THE SONY EXPLOD
take off front plate and you will see a super small button push it in it will reset ur radio put face back on and turn on
Jun 07, 2011 | Sony XPLOD CDX-GT200 CD Player
Does not stay set.
your deck has two power sources a main for when your car is turned on so the radio kicks on and a remote which is always on keeping stations and clock powered passively so whoever installed it did it improperly or do to road wear and tear it was jossled lose and can simply tightened after pulling the deck out
Mar 29, 2010 | Sony MEX-BT2500 CD Player
Radio and clock memory goes when engine is switched off
The radio was installed incorrectly or the memory wire has somehow been disconnected. The memory wire is the one which is connected to a permanent 12v feed even when the ignition is turned off.
The permanent feed is usually red, the memory feed is usually yellow (and a poor/lazy fitter may have piggy-backed it onto the red wire). Just connect the yellow to a fused permanent 12v source:either direct to the battery/starter motor terminal, or you can find others attached to the hazard flashers and often to the brake light switch on the pedal assembly.
Do yourself a big favour when doing the job and avoid clip on Scotchlok wiring connectors: they're a constant source of faults and no substitute for proper crimp-on bullet/spade connectors.
Feb 15, 2010 | Sony CDX-S2200 CD Player
Sony CD/Radio CMT-EP505: Setting fixed radio stations
Click Sony Support to download instruction manual copy of CMT-EP505 that has operation details of every thing in this system.
Jul 07, 2009 | Sony Audio Players & Recorders
Preset channels on Panasonic car radio out of tune
this is simple enough to do, just find the channel you want to save, then press and hold a number u want to save it to!
i.e No. 1 - 96.9Fm
hope this helps
Feb 15, 2009 | Panasonic Car radio CD CQ-C1110GN CD...
Pre setting the radio station on the keh-p2800 cassette player
HAS TO BE A CONSTANT POWER WIRE THAT CONTROLS CLOCK AND SETTINGS SHOULD BE A 16-14 GUAGE WIRE THE SAY 12+ AND HAS TO BE HOOKED INTO A CURCUIT HAS IS POWERED ALL THE TIME (NOT ONLY WHEN IGNITION IS TURNED ON)
Jul 12, 2008 | Pioneer KEH-P2800 Cassette Player
Sony car radio/CR/cassette doesn't hold pre recorded radio stations once ignition is turned off
run the yellow wire to the battery as its the memory wire and that will work if it is installed correctly and still does the same it can be the battery even if the battery still works.
May 25, 2008 | Car Audio & Video
Car Audio & Video Logo
49 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
