Question about HP LaserJet 4 plus Printer
I am using a HP Laserjet 4 plus. I got a flashing "PC" and "Load A4" on the screen and could not print. Pleas help.
  • steve shroder May 11, 2010
    what is your operating system? what country are you in? what size paper are you trying to print on? is the problem consistent or sporadic with one file or application? Please be specific?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
Clear the Print Que in the PC, turn off and unplug the machine, turn it back on.. send a test print from the driver.
A4 is european paper size, your printer is set for letter, someone attmepted to print an A4 file. Which is in the page set up in what ever file was to be printed.
Next Time Please be specific?
Posted on Oct 23, 2008
How to fix PC Load A4 printer problem
A4 refers to a paper size, so its asking for that size of paper to be loaded.
Mar 15, 2015 | HP LaserJet 4 plus Printer
Code PC Load A4
This means that the printer is expecting A4 paper rather than letter size or whatever you are trying to use. Check your "Printer Options" on your computer and make sure that the appropriate paper size is selected. A4 is an international standard paper size that is 210 mm (8.27 inches) x 297 mm (11.7 inches) and therefore is just a bit narrower and longer than the American "letter" paper size.
To correct this, cancel the print job currently in the printer's memory, change the computer to the proper paper size, and send the print job again.
Jan 26, 2014 | HP LaserJet 4 plus Printer
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
Printer shows "PC LOAD LETTER" when asked to
Have you made sure the tray slide that buts up against the paper is snug? I had this issue yesterday and that was the only issue. You may have to go into your settings and adjust the paper settings.
Aug 31, 2011 | HP LaserJet 4 plus Printer
Getting an alert saying: PC Load A4 What do I do?
Load A4 paper. Or just press the green button to force it to print to whatever paper is in the tray.
May 06, 2011 | HP LaserJet 4 plus Printer
Printer says " PC LOAD LETTER" will not print
Change in printer driver to use paper "A4" not "Letter" format
Jan 30, 2011 | HP LaserJet 4 plus Printer
Pc load letter come on when try to print all the time
First of all, go to Control Panel - Printers.
Right click on your printer, click properties.
Click on Printing preferences, click Advanced.
Change it to A4.
At device settings tab change all to A4.
Aug 27, 2009 | HP LaserJet 4 plus Printer
Pc load letter
Hi there this issue is caused by your driver defaulting to letter and a4 paper being used set your default paper size to a4 in the driver and also set tray to a4 this should cure the problem Regards AL "alstech"
May 28, 2009 | HP LaserJet 4 plus Printer
Printer cant print excel files
Chjange the page size of the excel document, it at present is set to letter, ...file page set up in excel
Sep 23, 2008 | HP LaserJet 4 plus Printer
My hp laserjet 4 plus printer cannot print excel files
wherer are you printing this, A4 is european, north america would use letter, etc..
if you go to control panel, open the printers and faxes folder, right click the printer in question, a window will pop up, click on properties.. a new window should open. click on "Printing Defaults" or "Printing Preferences" then click on "Advanced" ( I believe it should be to the lower left) that will open another window, in paper size make it Letter if your in N America, A4 for Euro.. this will set the deafult print..
Click ok, then print a test page from the general tab..
The reason you getting this LOAD LETTER message. your excel page setup is set to print to letter, your machine is set to print top A4
If you open Excel then go to Print then a window should pop up where you select the printer you want to use, click on Properties, then Lay out, then Advanced, and input the correct paper size before you print.
does this happen with all excels files, or one particular?
Create a new Excel file, and try printing it.. possibly could be in that particular file. I have seen this happen alott particulary with PDF files.. Where the incorrect paper size is in the file..
HP LaserJet 4 plus Printer Logo
281 people viewed this question
Ben Johnson
