Question about Symphonic SC313B Combo
Tv picture position problem
The picture on my tv is compressed and i have no idea of how to fix it.
    President:
  • 3,130 Answers
Repeat question?? you have a bad vert IC or a cap in the vert curcuit. If you have electronics experience then you gotta get a print for it then take some measurements. Good luck
Posted on Apr 24, 2006
I replaced my Samsung hln567wx color weheel about a year ago due to the tv making an odd sound. Changing the color wheel did fix the sound but after a year has past the picture is replacing all red with...
Tv have colors flashes back and forth some time u get a normal pictures again?Yes,u must take the tv aparts than check the colors wheel again.Check it out it condition only don't touch the colors wheel itself.U have compression air machine blow some light compression air into tv colors wheel it self might have acumalate dust on the wheel,don't solved the problems.Might have to change the colors wheel again.
Aug 27, 2011 | Samsung DLP HL-P5663W 56" TV
How do I expand my Tv screen
If the physical size of your screen is 4:3 the only thing it can show is a compressed version. The screen is physically not able to show the true 16:9 version. The true 16:9 HD signal has been developed to show on a screen that is twice as wide as it is long or 16:9 ratio. Your screen is almost square or 4:3 ratio. I hope this helps. Thanks for using fixya.
Dec 13, 2009 | Philips Televison & Video
Sony KV-27FS200 bright horizontal line problem
try to replace all filter capacitor on vertical section area that can solve your problem.
Mar 07, 2009 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Picture is stretched on top and compressed on bottom
the problem of your tv is in the vertical section,you need to replace the capasitor in vertical section .
Feb 18, 2009 | Konka FL2799U TV
57HX81 Toshiba. picture gets squiggly on dvd input
Perhaps 2 things. Does TV get a picture without DVD connected? If so I would bet you have a faulty connection in your signal board where the in jacks are at the back of the TV . Check to make sure cable from DVD are not bad, I have used cables before and got a false positive. Try turning and spinning the jacks once you have a picture.Make sure your signal board is firmly pressed into its slot on the signal board chassis. Thats it for now. Good luck.
Jan 20, 2009 | Toshiba 57H81 57" Rear Projection...
Picture compressed into upper half of screen
This is not an adjustment. There are some components that have become thermo sensitive with age and use. The fault is in the vertical deflection circuit area. Very often it can be a number of electrolytic capacitors.
An experienced TV tech can service this for you. After the fix, the TV should work as normal.
Jerry G.
Apr 20, 2008 | Toshiba 36A40 36" TV
Sanyo DS31520 31 Picture problem
hi there, it is worth for fixing it, cheaper than replacing it. you have a vertical section problem. look for a quilified service personnel for it to fix. ty
Nov 12, 2007 | Sanyo DS31520 31" TV
Compressed picture, staticky quieter sound
Sounds like you've got a vertical deflection problem causing the shrunk picture and finally a solid bright line. As to the loss in brightness you may be losing screen voltage to your picture tube. Probably it is time to shop for a new tv since cost of repairs may be too much. Stargazer
Nov 15, 2006 | Philips Magnavox 20MT133S 20" TV
Tv picture is smushed verticaly
another vert problem. The only way to fix this is replace the vert output IC and maybe a cap in the waveshaper that made the IC go bad. If you have no electronics experience then i would let a pro do the repair as it should cost more then 125 to 150 bucks or so. Good luck
Apr 24, 2006 | Symphonic SC313B Combo
Televison & Video Logo
41 people viewed this question
Top Symphonic Televison & Video Experts
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
