Question about Xerox Phaser 8400 Laser Printer
Fault 37,008,44:4501 This fault comes up after powering up the printer. Any ideas?
  • Xerox Expert
  • 297 Answers
Make sure the printer is plugged directly into the wall outlet and not into a surge protector or multi-outlet strip. These devices will not let enough power get to the machine for proper operation, resulting in 37 series errors.
The Fault you describe relates to the preheater being disconnected or no voltage getting to the preheater. Check the connections.
Posted on Jan 17, 2009
Printer not turn off
It sounds like a driver problem. Unplug the printer from the power and computer. Uninstall the drivers completely and then use the original disc that came with the printer to reinstall everything. Leave on automatic updating.
Mar 05, 2014 | Canon Office Equipment & Supplies
I have a HP Design Jet 1055CM that keeps showing "Receiceing" on the front panel. I have performed a cold re-set (turned off, dis-connected both power and NIC) and Power-cycled and error comes back. I then...
remove the net card completely and the cycle the power once it has come to ready print an internal print to ensure the fault lies external to the plotter , if it is able to print then the fault lies between the sender unit(PC) and the net card if you still have an error at this point the the Main PCA is at fault,
Oct 10, 2013 | HP DesignJet 1055cm InkJet Printer
Screen will not come on when trying to power it up. the power button blinks red 7 times, then pauses, then blinks 7 more times. it will repeat this process over and over. t.v. will not come!!!!
The blinking seven times is a fault code to locate which area of the TV has developed a problem, this is a protection mode to prevent further damage. I would need to know what model of TV you have to try & give you an idea of which section of the TV is at fault. This could be a power start up or scanning fault.
Oct 07, 2009 | Philips Televison & Video
Fault code 37,004.40:49612
Check you power coming in to the unit. If you are using a surge protector or UPS unit, Plug the unit into the wall and power up the printer. If that does not work, then:
PEST Fault 37,004.40: xxx
Printhead reservoir 0 disconnect:
Reservoir is not drawing the expected power from the power supply.
Service manaul states the the printhead needs to be replaced.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 15, 2009 | Xerox Phaser 8400 Laser Printer
Error in xerox phaser 8400
37,004.40: PEST - Printhead Reservoir 0 disconnect. Reservoir 0 is not drawing
the expected power from the supply.
One of the printhead cables may have come partially unplugged. Also, an ink spill on the circuit board could lead to this problem.
Apr 13, 2009 | Xerox Phaser 8400 Laser Printer
Fault message comes up after the printer is powered on
That is a print head fault. Most likely the print head itself has failed.
Mar 11, 2009 | Xerox Phaser 8550DX Laser Printer
Fault 37,008,44:21892
Printer paper preheater is open cct. The machine has a seperate drum heater
Jul 02, 2008 | Xerox Phaser 8500/DN Printer
sc541 is the thermostat, in the fuser section. i would personally change both the thermostat(s) and the thermistor(s).
Jun 20, 2008 | Ricoh Aficio AP410N Laser Printer
Printer Fault
USB port is set wrong on driver...
Unplug usb, delete driver, reinstall driver, plug usb in only when directed by install
Jan 15, 2008 | Brother DCP-7020 All-In-One Laser Printer
Fault 37,008.44:6069
That is a pre heater fault.
Most likley the pre heater needs to be replaced
Aug 29, 2007 | Xerox Phaser 8500N Printer
Xerox Phaser 8400 Laser Printer Logo
248 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
