Question about Danby Washing Machines
Rinse cycle of our Danby Portable washing machine
Occasionally, not all the time, the water, which is being pumped in continues to pump out. The water just keeps going through the machine. This is a problem. It is a real problem. We pump water out of the lake into a holding tank. The washer pumps all the water out of the tank; and the hot water tank. This could burn out our pumps and our hot water tank. We got the machine because it would be using less water. What do you think is wrong with it? We would really like to fix it ourselves since we live out of town in the Yukon and taking it into town to get it fixed (if anyone can even fix it) will be costly.
My husband is very good at fixing things and could probably fix it with the proper advice, pictures and parts.
Waiting for your reply.
Sharon
    Scholar:
  • 141 Answers
Find the drain solenoid valve and see if it is stuck open. It should be near the drain outlet. Measure the power at the drain solenoid. It should be 0 volts when the washer is filling. If there is power there (AC voltage), then there is something wrong with the control board, this is unlikely. I suspect the solenoid valve has seized in the open position. Manually advance the wash cycle to drain or spin. The solenoid should click when it opens. If it buzzes, then it is seized. The best thing is to watch and listen as you advance the cycle and see if you can verify what the valve on the solenoid is actually doing. I suspect you may want to replace this solenoid.
Posted on Sep 11, 2008
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Washer won't spin
Good Day,
Avanti washer repair
Good Day,
Nov 01, 2013 | Washing Machines
Danby dishwasher not washing
see this possible causes: 1) water heating cycles;the water must be preheating,test the heating elements and thermostat. 2) Timer: test for defective, clean contact, repair any wires loose, burn, or break. 5_9_2012_1_15_39_pm.gif
May 08, 2012 | Danby DDW1899WP Portable Dishwasher
Hi our Bosch exxcel washing machine has stopped spinning and doesn't reach the end of its cycle most of the time. If it does the washing is still soaking and needs a new rinse and spin cycle after....
Hi gillsteer,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Bosch Washing Machines
Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
During short spin cycles between rinses it doesn't pump water out
Try looking to see if the little motor is spinning the drain pump. It is in the bottom right. Occasionally I get a small metal shard which locks the pump and therefore-no draining. You can undo everything and check the pump for blockage. Then if need be, replace the mechanisim. The parts are all on line, as is the manual. or call 800 776-3538
May 11, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Washer won't advance from cycle to cycle
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
* It's the timer, if your washing machine fills with water and begins agitating, but the timer never
advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace
the timer.
* It may be a cold-water supply problem, if the washing machine fills with water, agitates,
drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 16, 2008 | Danby DDW1805W Designer Series...
Washing Machines Logo
204 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Jim Y
Jim Y
Samyfam
Samyfam
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
