Question about Sony DAV-IS10 System
C:13:71 Sony Do you find any solution to this problem. I'm having the same with new DVD's Thanks
No, it's had to go back to Sony. Still waiting for it to be returned. I'll let you know when I find out. :-)
Posted on Sep 14, 2008
Dvd freezing
is ur dvd player in an inclosed area because they need air and some more than others. is the device getting hot to the tuch. if it is then put somthing under the corners of the dvd player to raise it up. this should stop it from over heating. also try cleaning it. please rate my suggestion. thanks
Feb 01, 2009 | Sony DAV-DX150 System
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
Panasonic 50? Plazma TV TH 50PZ 800A + Sony Model DAV ? SB 500W
that is possible
the home theater has so many in puts on your dvd and out puts.
there is a way
1 you can buy a vedio/audio converted to rf signals, this will mean both signals entering tv using rf.
2 get your vedio out from dvd and audio out, feed that to a converter, vedio in and audio in okey
How do you get DVD player SOUND to play through the TV speakers
plug the stereo headphone jack to your dvd headphone output then connect it to your tv audio/video in and press the tv/video switch in your tv remote control.
How do I connect a new dvd player to Sony DAVS500?
If DAV-S500 have Input then hook new dvd player there and you can listen surround sound too.
Jan 02, 2009 | Sony DAV-S300 System
Surround sound hookup question?
It looks like all you'll need to do is hook up audio out from DirecTV to audio in on the surround sound system. Sony has an interesting hookup recommendation guide on the product support site:
http://esupport.sony.com/US/perl/model-home.pl?mdl=DAVC700&LOC=3
That should give you the connection options. The short answer, though, is to connect the best audio out from DirecTV to an audio in on the surround sound and then choose that option in the surround sound system when you want to watch TV.
Jul 16, 2008 | Sony DAV-X1 System
No sound from speakers
You probably popped a fuse in the unit..should be on the back of the amp.
you can play dvd through your telle,just run audio video cables OUT of dvd player,and IN to tv (av1),then turn telle to AV1,and wholla...
Dec 30, 2007 | Sony DAV-SA30 System
Is Sony DAV-S500 optical input compatible with optical output from Pioneer DVD player DV-566K?
I don't think this has an Optical but a Coaxial connection. You might try a coaxial audio cable not optical.
Dec 30, 2007 | Sony DAV-S500 System
DVD skips or freezes when playing and not related to a scratched or dirty DVD
I think that this is the laser unit as I have three of these units and I have swapped everything but the laser unit.
Dec 27, 2007 | Sony DAV-C770 System
Is it possible to use the speaker system on a different DVD player?
I believe I understand what you're asking here. To the best of my knowledge sony puts a special type of connector on the reciever end of the speaker wire which will probably not be compatible with any other reciever brand. Depending on the age of your system, the speakers may not even be compatible with the new Sony models. Wait...there's good news though. Whatever reciever/DVD player you decide on, there will surely be speaker outputs and if you snip of the Sony connector and strip the wire a bit, you shouldn't have a problem. A couple of other things to consider though... A conventional standalone DVD player may not have outputs for five speakers and a sub. That sounds more like a dedicated reciever. I have a crazy suggestion but you might save yourself some money and trouble. -If you are satisfied with the speaker portion of your current system, buy a cheap DVD player, run the video out to the TV, the audio out to the AUX audio in on your current system and use it for sound only. Hope something in here helps.
May 29, 2007 | Sony DAV-BC150 System
Sony DAV-IS10 System Logo
148 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
