When I wash clothes water leaks out from the bottom of the machine.
Hi sir
Dishwashers are usually protected from overfilling by a float switch. This switch is located in the bottom of the unit. Here's how to check and replace it:Step 1: Open the door and remove the bottom dish rack. Check to see if the float valve is stuck. If it is, clean away food debris around the float. With a screwdriver handle, lightly tap the top of the float to free it.
thanks.................rate it
I have a kenmore font load washer that also leaks water
