Question about Kitchen Ranges
Weber genesis silver-c no gas through front burner, only middle and rear, therefore cannot ignite the grill
Cloged burrner
Posted on Sep 12, 2008
3 burner - front and rear ignite,middle does not. Replaced all 3 burners. Still does not light. Suggestions?
It might be an igniter problem. It might be a problem with the gas tank (either empty or not releasing the gas). It could be a problem with the control valves or even with a safety mechanism that prevents relighting the grill after multiple tries because of a possible gas build-up. Make sure the gas tank is full and releasing gas - you should be able to hear a hissing noise in the burner compartment. If you can hear the noise then you need to check the igniter and make sure you are getting a spark, and that the spark is reaching the burner. If you can't hear a noise then either the control valves are the problem or the safety mechanism is operating. You can also call Weber and they are pretty good at helping you figure out the problem.
Jul 23, 2011 | Weber Genesis Silver A Grill
I have a 2005 Weber Genesis Silver propane grill. The first and third burners work fine, but the middle burner will not ignite. I have cleaned it and still no flame in the middle. I'm about to order...
Jeanne - Did you remove the burner to clean? If not. you weren't able to clean the Venturi Valve, which is part of the burner. Spiders love to get in the Venturi Valve & build a nest. When that happens it stops the gas to that burner. I suspect, that may be the problem. The Venturi Valve, is part of the burner (the open end part) that's closest to you, when you face the front of the grill. It will look like 2 slots (one on each side) cut out of the burner tube, where it fits over the burner orifice. But, you can't see it, without removing the burner. An old tooth brush works well to clean it.
Hope this helped you to solve the problem. Please let me know and Happy Grilling!!
Jun 19, 2011 | Weber Genesis Silver B Grill
The front burner will not ignite. The middle and rear burners seem to function properly. Any suggestions for what needs to be repaired/replaced?
First Make sure the gas is turned off. You then need to clean the gas orifice and make sure it is not plugged up. Remove the front burner, using a paper clip clean the orifice. Make sore the burner is not plugged up and if it is use a wire brush to clean the burner. If this does not fix your problem the you will need to change the gas control for that burner. I hope this heps you with your problem.
Jun 06, 2011 | Weber Genesis Silver B Grill
My grill is a Genesis Silver B. The front burner ignites but the middle and back burner will not. I took off the tubes and can't see where anything is plugged or restricted. I can hear gas through the...
I believe your model Weber has a Cross Over Tube Burner , on the left side of the interior of the grill, just above the middle and back burner. If that's clogged or needs replacing, that's more than likely the culprit. As, it won't carry gas to those two burners. It is easily replaceable, if necessary.
In case you have misplaced your Owners Manual, I have included a link to it. You can download and print it for future reference.
http://www.weber.com/help/manuals/pdf_files/Genesis_SilverB_LP_Owners_Guide_55008_03_21_01.pdf
Apr 09, 2011 | Weber Genesis Silver B Grill
Back burner won't light on my Weber Genesis Silver A Gas Grill
Only front burner lights (out of three) and it only has flame comming out of half of the tube.
Apr 04, 2010 | Weber Genesis Silver A Grill
Problem with gas getting to the front burner
Follow manufacturer's recommendation in resetting the excess flow safety device....(Turn burners and LP cylinder off...Disconnect regulator on cylinder. Turn both knobs to high for at least one minute...Then turn them to off...reconnect the regulator to the LP tank...Turn LP valve VERY slowly (30 seconds) until fully opened..then start the grill in the usual manner. ALWAYS TURN THE LP TANK OFF WHEN DONE USING THE GRILL....
Jul 04, 2009 | Weber Genesis Silver B Grill
Kitchen Ranges Logo
46 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
