Question about Kitchen Ranges
Weber 110LP gas bbq- igniter button down- won't come up not able to ignite the grill
  • 38 Answers
This is either from the spring under the button being worn out or broken. or if the button and sleeve it depresses into is not clean. Try removing the button and checking to see if the spring is in working order. If the button is a contained unit and you do not have access to the spring, make sure that it is clean. If that doesn't work then you will need to replace the button. Check to see if you are still under warranty and maybe you can get a replacement free of charge or if the unit is new enough you may get a new unit altogether. I hope this gets you grillin again.
Posted on Sep 11, 2008
Ignition button not working, however the bbq will light with a match. I have replaced the old gas bottle and this is still an issue?
Sounds like you need to replace the igniter. If the gas lights with a match, there's nothing wrong with the gas bottle. line or burner.
Jan 28, 2014 | Weber Baby Q Grill
I have a 3week old Webber Q220 bbq and it does not ignite - Plenty of gas but igniter does not work - what to do please?
If it's no longer sparking, then it sounds like your igniter battery is dead. Unscrew the igniter button and replace the battery.
Jan 01, 2014 | Weber Genesis Gold B Grill
Weber q bbq
What is the model number? Here is a link to webers website http://www.weber.com this might make it a little faster for you to get your information.
Apr 28, 2013 | Grilling
Infared burners ignitor won't work
Mike, have you replaced the battery in the igniter button ye? That's the first place to start troubleshooting. Be sure you install the new battery facing the same direction as the old battery. Also, check the interior contacts of the battery holder for corrosion. If you find any, use a Q-Tip sprayed with a little WD40 to clean it.
If the above doesn't solve the problem, trace the igniter wire from the igniter button to the spark igniter at the burner for damaged wire or a loose connection.
And finally, try match lighting the infrared burners to make sure that they are getting an adequate flow of gas.
Hope this helped you t troubleshoot and solve the problem. Happy Grilling and thanks for choosing FixYa.
Aug 24, 2011 | Weber-Stephen Products Weber Summit...
Our igniter doesn't work.
clean the elctordes on the burners make sure the battery conections are clean corrosion free
Jun 21, 2010 | Weber Genesis E-310 Gas Grill
Hi, I have just bought a Weber 100 BBQ. I have a
You have a couple of questions. In order: 1. Flame may not be visible because it burns very clean. 2. When they say 'turn gas off', they actually mean 'turn gas tank off'. 3. It's not necessary to remove the tank after every use. Just make sure the gas valve is off and the entire grill and tank are covered. I do remove the tank, and store it in an outdoor shed during the winter.
May 18, 2010 | Grilling
Weber gas grill will not ignite
you will probably have to get a new igniter or try to adjust the one you have. there is a little electrode on the igniter that needs to be clean and a certain distance away to work properly.
May 26, 2009 | Weber Q Grill
Weber gas bbq
Hello stevie66, disconnect the gas tank, carefully remove the burner element (the thing with the small holes) and soak it in a bowl of vinegar overnight. Remove and shack the excess out, remount and connect the gas. Open the gas line about 1/4 turn and CAREFULLY LIGHT. Please E-Mail the results. Thank you.
Oct 26, 2008 | Grilling
Kitchen Ranges Logo
413 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
