Question about Freezers
Charging i have a 1996 reach in cooler for beer, and it lost its charge since 2003, was originaly a r-12 22oz charge now a 434b hotshot can i change it to r22 at a 22 oz charge after i leak check it. and can you tell me what my pressure should be on the suction when the box is at 40 degrees. i am at around 15 to 20 lbs and i am at over my run load amps by 1 amp.
    President:
  • 1,314 Answers
No you don't want 22 its for ac they have a new product out now for sealing leaks its like stop leaks for sealed systems can find it here http://www.cliplight.com/hvacr/products.php?catID=27 its called acr superseal put it in bring your low side between 8-10 and you will work fine now i had one of my inst at frigidaire put 134 in an r12 system and he said it was still going strong after 2 years so use your judgement there
Posted on Sep 11, 2008
Compressor never comes on
I made video how to replace compressor on true air beer cooler, should be the same for most of prep tables and etc. Hope That helps someone. REPLACING COMPRESSOR TRUE AIR BEER COOLER R134A
Apr 01, 2014 | True Freezers
Help with charge
I would suggest charging about 2 oz below label then charge by pressures if it is a TXV. Cap tube is critical charge so i would as the manufacturer of Hot Shot. Not recommended to use hot shot on cap tube systems. My opinion only.
Mar 17, 2014 | Delfield Freezer 6125XL-S
What happens if you would add a charge to a running system that has a low charge on a 404a system and you charge thru the suction as a vapor. I had a memory lapse and have charged 410 systems as a liquid...
as long as you recovered the charge, pulled a vacuum, changed the filter/dryer, and added the correct amount of refrigerant as a liquid, you should be good to go.
Jun 28, 2017 | Hoshizaki Freezer Commercial Ice Machines...
Which way do I turn the temperature dial on a true 3-door reach-in stainless steel cooler?
Numbered 1-9 - one is the warmest setting, nine is the coldest. For a cooler it should be good on 5 for a freezer 7. If it doesnt work well on those settings the thermostat is usually bad.
Aug 03, 2013 | True Freezer GDM-49RF
Can the T-49F be converted from freezer to refrigerator?
Anything is possible so Yes... Although I wouldnt recommend it. The price to have a qualified technician do the job would reach very close to the cost of a new reach-in cooler and it could put a bit of a burden on the compressor. You are better off selling the freezer and purchasing a cooler with the money from the sale. It would involve one of two fairly large scale jobs. 1. The recovery of the refrigerant and installation of a CPR (Crankcase Pressure Regulator) with some wiring changes and adjustments... Or 2. The replacement of the compressor and capillary tubing.
Dec 26, 2010 | True 49 cu. ft. / 1388 liter Commercial...
What is the normal operational pressure in lo/hi side at the compressor of commercial freezer like dispaly case, reach in cabinet or other any low temp refrigeration uses 502 or408A/404a. is there any rule...
why yes there is. Generally speaking, the head pressure should be around the "ambient +30" rule.
That is, measure the entering air temp to the condenser, say 75 degrees. Now add 30 to that and get 105 degrees. Look at a P/T chart and see what the pressure is for that temp which is about 253 for R-404-A.
The evap on a freezer leads the load so, as a general rule, the evap temp is going to be around minus 10 degrees to get a 0 degree box. Coolers are different. So, the pressure for a minus 10 evap is around 25 or so. But the unit has to be close to operating temp. If the box is warm, naturally the pressure is higher. And what influences the pressure is whether or not it's a TXV or a cap tube system.
If a TXV and no receiver, charge by subcooling. If a receiver, fill by sight glass. If Cap tube, charge by superheat.
Hope that answers your question.
Oct 03, 2010 | True 49 cu. ft. / 1388 liter Commercial...
For a walk in beer cooler i installed a 1/2HP compreser 50 feet to the evp 2 fan fairly large,am i underpowerd or too far because i am getting freezing in the evp.any ans.
No your are Ok . You may be to small on your unit. Check the charge you may be low. Make sure site glass is clear. Also I have had to install a dfrost time on several of my coolers. If you have one just set defrost for more or more often. Got to keep the beer cool. Rus
Jul 14, 2009 | Freezers
Freezer has lost its suction & no longer freezing!
Depending on the age of the unit it does take a 134a freon charge or 12 or 22. when fully charged unit should cool properly. need to check door seal for suction issue. the unit does need a good charge to cool. it could also be a restricted sealed system issue.
Jun 21, 2009 | GE 17.1 cu. ft. / 484 liter Upright...
I got a restriction in my freezer
this happened to me once, when I brazed up the comp some flux ran down inside the pipe causing an intermittant blockage, hope this helps.
Apr 11, 2009 | Traulsen Reach in Freezer - G22010
Freezers Logo
98 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
