Question about Motorola Mobility W385 Cellular Phone
Can not charge phone
When I plug it in to charge it says unable to charge, HELPPPPPPP
  • Anonymous Oct 03, 2008
    when i plug in usb it says unable to charge
  • Anonymous Nov 08, 2008
    when i plug my phone in to the charger it wont turn on and when i use other chargers or computer i get unable to charge =[ i think one of the charging pins are broken
  • 3 Answers
It's a disfunction with ur phone!!!mines did the same thing,but i had 2 send it back 2 motorola 4 repair.they come with a yr. warranty..check it out at servicemyphone.boostmobile.com
Posted on Nov 15, 2008
My phone is not charging. When plugged it says: Unable to Charge
Remove battery, clean contacts between battery and phone, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.
May 21, 2010 | Motorola Mobility RAZR V3
Plug up to charger and it says unable to charge
Remove battery, clean contacts between battery and phone, clean charging port, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.
Jan 18, 2010 | Motorola Mobility W385 Cellular Phone
Unable to charge
Um, you might need to either buy a new charger, or its your phone.
May 26, 2009 | Motorola Mobility RAZR V3
Once i charge my phone i get a yellow light rather than green.
Leave it plugged in for a little while. When it's yellow it means that your phone is dead and it's charging up the battery. It will eventually turn on and the light will turn green.
May 03, 2009 | Motorola Mobility ROKR E8 Cellular Phone
Won't charge
Same thing happened. The charging port is broken.
Apr 15, 2008 | LG enV VX9900 Cellular Phone
'Unable to Charge'?
COULD BE THE PHONE BUT MOST LIKELY ITS THE CHARGER, IF ITS AFTERMARKET GET RID OF IT AND BUY OEM, TRY AND TEST IT OUT WOULD A FREINDS MOTOROLA CHARGER SINCE THEY'RE MOSTLY THE SAME CHARGERS AND SEE IF YOU STILL GET THE MESSAGE.
Apr 06, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
Unable to charge the razor
there may be a short in the wire or in the plug. try wiggling it around a little bit and see if you can get a connection
Jan 19, 2008 | Motorola Mobility RAZR V3
Helppppppp
U took the battery out? as in popped open the iphone? Try plugging into the mains or computer and waiting a few mins brfore trying to boot it..
Dec 24, 2007 | Apple iPhone Smartphone
Phone will not take a charge or turn off. it says unable to charge
Have you tried another phone charger? I had a motorola charger that had a bad plug on it and it wouldn't connect right. The phone could recognize that the plug was connected, but could not route the voltage through it, thus telling me it was "unable to charge". If that's not it and another charger doesn't work either, look at the connector on the phone. See if there is any dirt or debris in it. If so, try to clean it out. Also, if you got the connector wet, it can corrode rather quickly. If this is the case, you may need to use a drop of isopropyl alcohol to clean the contacts. Hope this helps. Good luck.
Jul 01, 2007 | Motorola Mobility RAZR V3
Motorola Mobility W385 Cellular Phone Logo
161 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
