Question about ASUS F3Jc-AP141C Notebook
Bios hi! I am sorry not speak English well,include a laptop when a flash animation and Asus will not continue. Only when I click involvement F2 button and begins to read bios. Fit when it finds hard disk and end. need help, Bios fit, I tried format hdd .I have a serial mistake with bios or is it mere luck
How to enter Asus Q534UX BIOS
Windows 10 - How to enter BIOS configuration? - Asus
https://www.asus.com/support/faq/1013015/
  1. Cached
  2. Similar
Hold and press [Shift] then turn off the system. Press and hold the F2 button then click the power button. DO NOT RELEASE the F2 button until the BIOS screen display. You can find the BIOS configuration. Category. Windows 10 - How to enter BIOS configuration? Windows 10 - How to boot the system from USB drive/CD-ROM?
How to enter Asus Q534UX BIOS Google Search
Jan 26, 2017 | ASUS Computers & Internet
How do I turn on my wifi switch on my Asus F555l
Usually hold the [ fn ] key and the [ f2 ] together or just the [ f2 ] key depending on how your "Hotkeys" are setup. If you've had a fresh install of windows or the drivers aren't working properly you can do it manually by going into the bios like so:
Step 1
Turn on your Asus Netbook. If your netbook is already on, click the "Start" button, click the arrow next to the "Shut Down" button and then click "Restart."
Step 2
Wait for the Asus Netbook BIOS screen to appear, then press the "F2" key.
Step 3
Press the "Right" arrow to scroll over to the "Advanced" tab.
Step 4
Press the "Down" arrow until you reach the "Onboard Devices Configuration" option. Press the "Enter" key.
Step 5
Press the "Down" arrow to "Onboard WLAN" then press the "Enter" key.
Step 6
If the "Disabled" option is highlighted, press the "Up" arrow to highlight the "Enabled" option, then press the "Enter" key.
Step 7
Press the "F10" key. Press the "Enter" key to save your changes and exit the BIOS. Note: If you are missing your hotkey drivers you can find them here under the ATK section (Use the latest version) http://support.asus.com/download.aspx?SLanguage=en&p=3&s=670&m=F555LA&os=&hashedid=n%2fa
Feb 26, 2015 | ASUS Computers & Internet
Asus r503u bios
Shut down your Asus laptop. Click "Start" then click the "Shut down" button. Power your computer back on. Wait for the ASUS splash screen. Press the "ALT" and "F2" keys on your keyboard as soon as you see the ASUS splash screen. Your computer will enter the BIOS.
Feb 14, 2013 | ASUS R503U-RH21, AMD E2-1800, Laptop, 4GB,...
Asus K52N Series Multi recorder not recognised
Start hitting F2 even before the screen comes up and keep hitting it about every one second until the Bios screen comes up... Also, it could be that your Multi-Drive is dead and needs to be replaced...
May 15, 2012 | ASUS Computers & Internet
Asus eee pc 900 netbook will not boot. Error message says remove disks or other media press any key to restart
Hi guys, i hope this could bring little light to this boot-stop error. First of all sorry for my english /slovakia/. So thi applies for asus eeepc 1005HA /maybe some other models too - depending on motherboard construction. In my case it was 2 parts motherboard which were conected via flex cable. Both parts contrains USB ports which is the think what stops you access to BIOS and all functions. If you hit TAB button during start up /best way to do so before pressing powerbutton/ you will see post messages, which stops on inicializing USB controlers. So what you need to do is
1. turn on computer
2.unplug flex cable which leds to usb ports
3. now you should see progress on your screen, so go to BIOS /F2/
4. visit ADVANCE tab
5. visit ide onboard configuration
6. check for usb controler configuration
7. mark it as DISABLED
8. hit F10 to save your settings
9.reboot
after this hint you will have full access to all functions like before, USB ports included.
hope this little research hlep u too, my eee1005HA is now glowing
May 03, 2012 | ASUS Eee PC 900HD Netbook
Hello, i'am italian a don't speak english correctly i'have a problem my motherboard asus p5p800 vm have one error I gett Chassis inrusion error message - system halted THE SOLUTION? TANKS!
Go to the BIOS. Just restart your computer and while restarting, keep on pressing "f2" key or the "del" key, sometimes "f8" until you see the option that you can go to setup/bios. On the Bios menu, just find there the option to disable the Chassis Intrusion detection.
Oct 07, 2010 | ASUS P5P800-VM Motherboard
Bios
As soon as you press the power button - continuously press F2 until it enter the bios.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 19, 2010 | ASUS Eee PC 1000HE Netbook
Chassis Intruded
try take out the battery on board for one min. then put in battery see if that works jim
Feb 16, 2010 | ASUS K8N Motherboard
Do I really need a floppy disk to do an upgrade bios?
Of course floppy is the easiest but if you configure a flash drive with flash drive utilities to be bootable, and the BIOS will support it you can flash from the USB flash drive.
Mar 21, 2008 | ASUS P4S800D-X Motherboard
P5s800 bios update
Updating bios should be done flash bios setup, when your restart your computer after the POST you will see a selection to enter to flash bios manager.
Jan 16, 2008 | ASUS P5S800-VM Motherboard
ASUS F3Jc-AP141C Notebook Logo
153 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
