Question about Kitchen Ranges
Cooker hood i bought a baumann tukan 80 cooker hood off ebay but i didnt get the user manual. i need to know how to clean the internal filter.
  • 1462 Answers
SOURCE: rangemaster cooker hood. model no.LEIHDC120SC/
hood should be connected to a fused spur outlet which you havent found. try removing the chimney and you may find it there. chimney only held by 2 screws at top usually.the fuse in the outlet sometimes goes when bulbs blow
Posted on Jun 03, 2007
  • 1314 Answers
SOURCE: F60 SS Cooker hood
short in light switch
Posted on Dec 30, 2007
SOURCE: cooker hood not working
Check power from the wall.
Check power in the wiring coming into the hood.
Check to see wiring is not broken.
Posted on Feb 18, 2008
SOURCE: indesit cooker hood
HELP WHERE IS THE FUSE
Posted on Mar 11, 2008
  • 50 Answers
SOURCE: Indesit cooker hood.
some have fuses, some dont. i know that if you dont have the vent hood hooked up correct the heat can melt the wires on the inside. so make sure the vent is hooked up right.
Posted on Jun 23, 2008
Hola, I'm looking for a replacement ceramic insert/bowl for my slow cooker. its broken. Is there anywhere that i can buy another one for a cheap price?
Yes, lots of those available.
Slow Cooker Replacement Parts ' Crock-Pot
www.crock-pot.com/parts/
  1. Cached
  2. Similar
Replacement Lid - Crock-Pot® 5-Quart Round Slow Cooker. ... Replacement Stoneware - Crock-Pot® 5-Quart Round Slow Cooker - Black. ... Replacement Stoneware - Crock-Pot® 7-Quart Oval Slow Cooker - White.
Where can I find a replacement ceramic insert for the GE slow ...
https://ca.answers.yahoo.com/question/index?qid...
  1. Cached
  2. Similar
Nov 8, 2012 - I have looked on GE's site and it seems they only offer replacement parts for major appliances. If someone knows where I could get a ceramic ... Where can I purchase a replacement lid for a GE slow cooker ... 24 Aug 2014 Anyone know how to locate a replacement insert for a slow cooker ... 9 May 2009 I need replacement glass lid for GE slow cooker (6.5 qt). Already ... 7 May 2008 Where would I find Replacement parts for a Slow Cooker? ' Yahoo ... 16 Jul 2007 More results from ca.answers.yahoo.com
GE Slow Cooker ' eBay
www.ebay.com/bhp/ge-slow-cooker
  1. Cached
  2. Similar
GE 3 - Crock Round Slow Cooker 103734 1.5 Quart Inserts. $34.99. Buy It Now. or Best Offer ... It has 3 temp settings. Also your able to remove the ceramic.
GE 6-Quart Digital Slow Cooker - Walmart.com
www.walmart.com/ip/GE-6-Quart-Digital-Slow-Cooker/12442589
  1. Cached
  2. Similar
Rating: 4 - ‎200 votes Buy GE 6-Quart Digital Slow Cooker at Walmart.com. ... to be sent back if under warranty. I would think you could contact GE parts on-line to find a replacement insert to purchase. .... To me, "stoneware" is like ceramic or porcelain. The insert for ...
Customer Reviews: Ge 6-quart Digital Slow Cooker
www.amazon.com/Ge-6-quart-Digital-Slow-Cooker/.../B007P60E94
  1. Cached
  2. Similar
I will never use anything but a ceramic slow cooker again, and never a G.E. ... I am keeping the unit and on the hunt for a stoneware/ceramic liner replacement.
Mar 28, 2016 | GE small appliance slow cookers 106724...
Where can I find the elite pressure cooker manual for EPC-808
I found this if it helps;
http://amazingonepotmeals.com/maxi-matic-epc-808-elite-platinum-8-quart-pressure-cooker/
Mar 25, 2014 | Kitchen Appliances - Others
Cooker hood installation
A cooker hood needs to done by a competent qualified Electrician but basically depending on your surface of the cooker hood.Depending on the type of cooker hood you have(extract or outside) If it is a extraction (meaning you are using filters and not connected to a vent) The Electrician needs to connect the electric to a point or spur via a power switch on the wall which when you fit up the main part of the hub covers the spur. after that you need to measure and fit the cooker hood to your requirements but make sure your walls can support it and mark off the holes before drilling or check the walls for electric wires in terms of safety.
May 21, 2012 | Washing Machines
I didnt get a user manual with my creda cooker dont know how to set the timer
try this site for your manual
kitchen.manualsonline.com/manuals/.../creda/creda_oven_product_list.html
hope this helps
Apr 28, 2010 | Ovens
Need instruction manual for the Dazey DCP-6 Cooker/Fryer
Someone on Ebay in the USA has 2 x instrunction manuals for sale on Ebay item number 270549879418 (will post worldwide).
Regards
Alan Hood
ami-man
UK
Mar 30, 2010 | Crock Pots & Slow Cookers
I've bought a new cooker hood that filters the air and then re-circulates it. At what minimum height from the ceiling should it be fitted?
Its not the ceiling height that matters its the height above the cooker or hob thats important. Above a gas burner the bottom of the hood should be at least 750mm, above electric burner 650mm . This measurement should be taken from the highest point of the cooker top.
Nov 24, 2009 | Kitchen Ranges
Slow cooker made for Walmart GE model 169143
I am looking for a user manual for a walmart slow cooker model 169143.
If available, please provide cost for the manual.
Thank you
Feb 04, 2009 | GE 106851 6-Quart
Internal cooker hood
Hi judav,
I'm Harvey the Master Plumber.
Your problem is: You live in a flat with no chimney and you would like to install a cooker hood. how do you do this please?
Is there living space above? If so you can't go straight up. If your range is on an outside wall, it can be piped out the back. If only attic or roof above, no problem. Just pipe it straight up useing B-vent pipe or equivlent. If you can't do any of this just get a hood that vents filtered air back into the room.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 03, 2008 | Kitchen Ranges
Neff cooker hood
the manual i have says that the charcoal filters inside need changing about every 6 months. take out the grease filters then you should be able to turn it and take them out. you may not have these if the extractor vents to the outside. the grease filters can be cleaned with a neutral detergent and then put back in. Make sure the electric is off before you do any of this. Hope this makes sense and helps!
Jul 09, 2008 | Kitchen Ranges
Kitchen Ranges Logo
55 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
