Question about NEC VT676 Multimedia Projector
NEC VT676 lamp error
When I try to turn the projector on, the status light blinks 6 times indicating what the manual calls a lamp error. The manual simply says to try again. That did not work. I unplugged it and plugged it back in. That did not work.
We replaced the lamp about 3 months ago and it probably has about 75 hours on it.
  • 3 more comments
  • DaveTheITGuy Oct 15, 2008
    I have the exact same issue. Should I replace the lamp again or do I need a whole new projector?
  • Higgins2190 Nov 11, 2008
    Have the same problem.
  • Anonymous Jan 14, 2009
    Same problem. Talked to NEC, they said it means a power supply issue. Happens about %1 of the time, the guy said, when the Lamp Error cycle happens.
  • papersolve Apr 21, 2009
    I have the same problem also
  • papersolve Apr 22, 2009
    I don't see any solution listed here. Am I doing something wrong?
  • 115 Answers
Indicating ballast unit problem
Posted on Sep 27, 2008
Nec projector do not work brand new lamp
Posted on Mar 17, 2009
Does a lamp error message (6 blinking red status lights) mean the lamp needs to be replaced? or could something else be wrong.
According to NEC technical support, if the status light flashes red six times, this could indicate a defective lamp. If a new lamp is installed and the project still won't turn on, the projector will need service.
Jun 15, 2011 | NEC NP400 Projector
What does a solid red status light on a NEC VT676
This could be a number of things. When I encountered this problem it was simply a burned out lamp. If you have not checked that make sure you do that first. Also there is a safety feature on the projectors that will not let you turn the projector on until the lamp cover is back in place. You may also want to ensure that the filter door is securely in place. After you have done this try to power up the projector (it will take a few seconds for the lamp to warm up.) If the projector starts up, go to the menu and clear the lamp hours. These projectors have lamp life's that will expire after a certain amount of time, irregardless of the functionality of the bulb. Hope this helps you out. :)
Apr 13, 2011 | NEC VT676 Multimedia Projector
Lamp error on nec projector
Have you changed the lamp? is so check out fixmyprojector.com
the ballast most likely needs to be replaced
Dec 16, 2008 | NEC VT676 Multimedia Projector
Blinking status light
Replacing the lamp with an old one was helpful for me. Good news: the projector itself not faulty. Bad news: I have two projectors with the same issue at the same time (the lamps were replaced also at the same time) after only 400 hours of running.
Apr 01, 2008 | NEC VT47 Multimedia Projector
Status indicator / no lamp
The power supply unit ballast is bad for the vt670 part # 3n100572
Feb 12, 2008 | NEC VT670 Multimedia Projector
No Picture on my nec VT676 model
Hi there
I'm shocked that NEC can't answer this guys.
The NEC's & Acer's make use of teh status lights and beeps to warn you that your lamp needs replacement.
Nov 13, 2007 | Office Equipment & Supplies
Status light blinking red
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Oct 23, 2007 | NEC VT47 Multimedia Projector
NEC VT676 Multimedia Projector Logo
985 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
