Question about Pioneer VSX-D711 Receiver
Amp error My VSX-D711 wont start before it died it displayed a AMP ERROR message on the display panel. Has anyone had this problem before or is it worth fixing it or replacing it? Thanks
  • Ramland Mar 07, 2008
    Amp err message and shuts off. Unpluged and repluged and standby power light does not come on.
I had this exact same problem, it can indicate that there is an impedance mis-match somewhere. i.e. using 4 or 6 ohm speakers instead of 8. However if you unplug the speakers and it is still doing it then you could have a problem with the actual amp circuit.
Mine was doing it with nothing plugged in and had dry solder joints on the circuit board with the two large output devices are. Simply resoldered those and it is fine now.
It had started crackling before it stopped working all together, which would also indicate the start of dry joints or bad connections somewhere.
Regards,
Rolf.
Posted on Jun 18, 2008
  • Andrea Biondo
    Andrea Biondo Mar 22, 2015
    Same here. Re-soldered all those hundreds of pins, or so it seemed. Works like a charm though.
    President:
  • 3,130 Answers
If you know how to troubleshoot solid state electronics then I would say it may be worth it. The amp error indicates a high current draw at the output ic's and drivers. depending on how much you can replace it for would be your final answer.. Find out also what a pro would charge for labor. Good Luck
Posted on Apr 24, 2006
My Pioneer vsx-D411 has a AMP error on the display what should i do about it.
Posted on Aug 24, 2010
What is dsp ng appear in the monitor
I'll ask again... What brand/model of monitor?
Does it seem like a receiver-to-monitor On Screen Display message or is it something the monitor is warning about?
How are the the receiver and monitor connected?
No more sound from where? The TV. The speakers running off the receiver?
What source(s)?
Give us some clues, please.
Jan 23, 2010 | Pioneer VSX-D711 Receiver
Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
Dec 28, 2008 | Pioneer VSX-D411 Receiver
Vsx-d711 sound problem
HI...
Sounds like ( no pun intended) poor speaker wire connections.
Check the wires at both ends and make sure theyre firmly attached.
If one speaker isnt connected , the amp will reset over n over
Nov 27, 2008 | Pioneer VSX-D711 Receiver
Pioneer D711
Hi...
Is there an access cover with screws in it underneath?
MOst of the receivers have something like that.
I would also check the output PCB assby for shorts or opens.
Jul 02, 2008 | Pioneer VSX-D711 Receiver
The Sound is Gone.
Hi....
The circuits that routes all the audio signals thru the amp has either died OR the power supply that runs that circuit has died.
Estimate to fix : $75-125
Apr 22, 2007 | Pioneer VSX-D711 Receiver
Amp error
AMP_ERR means the unit is detecting DC on the output of one or more amplifier channels. This is either the result of a failed/shorted amplifier (or other component) or bad solder joints (as mentioned above).
Dec 23, 2006 | Pioneer VSX-D711 Receiver
Pioneer VSX-D711 Receiver Logo
2,840 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
