Question about Sony Handycam DCR-TRV460 Digital Camcorder
Sony DCR-TRV361 camera recorder LCD not working
The bottons on the touch panel are not working. I have tried calibrating but no luck. When I touch a button to activate the icon I get an effect similar to a stone hitting lake water.
Thanks.
Ray
  • arlray19 Oct 19, 2008
    Couldn't answer.
    Ray
WINDOWS VISTA NO ME RECONOCE EL DRIVER DE LA CAMARA SOñY DCR TRV361 NTSC. NECESITO INSTALAR ESTE DIRVER O DONDE LO CONSIGO?
Posted on Oct 19, 2008
I have a Handycam digital video camera recorder- DCR-HC30. The camera sat in its carrying case at room temperature for about two years without being used. When I went to use it, the touch screen would...
The LCD / Touchscreen module is no longer available from Sony for this Model. However, I have a limited supply of them.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Feb 08, 2011 | Sony Handycam DCR-HC30 Mini DV Digital...
My camera's finger touch panel doesn't work when I touch it to play back the records, how can I fix it myself?
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
Note: 8 represents the reset button on the above figure.
If the issue persists again, please perform LCD screen Calibration and check if that helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, please remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15 seconds, turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder.
Feb 01, 2011 | Sony DCR-HC26 Mini DV Digital Camcorder
Sony dcr-hc26 touch screen does not work
If the touch screen of the Camcorder is not working, pleasefollow the troubleshooting steps.
dcrhc26%20reset%20button.jpgdcrhc26%20reset%20button.jpgmoz-screenshot.pngmoz-screenshot-1.pngrsshajan_3.jpg
If the issue persists again, please perform LCD screen Calibration and check ifthat helps.
If the issue persists again, service is required.
I hope this information will help you to resolve the touch screen issue of theCamcorder.
Dec 30, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
I reset my Sony DCR-HC21 and now the LCD screen doesn't respond to my touch. It's just stuck on the date/time screen. I tried to do the calibration, per the user manuel, but I can't get to the calibration...
there is a problum in side the camera one is ffc whicis connect the lcd to main board if no then lcd it self having problum because thes tuch switches are in side the lcd please go to your nearst sony service centre & fix this problum
Apr 29, 2010 | Sony Handycam DCR-HC21 Mini DV Digital...
Lcd problm
there is 2 types of fault for this....one lcd cable damage or touch panel damage if it is you have replace LCD
Feb 27, 2010 | Sony Handycam DCR-HC30 Mini DV Digital...
DCR-HC40 LCD works, but Touchscreen doesn't. I was able to calibrate once -- but din't hold settings. I cannot calibrate.
hello its ruttine problem ,just change the lcd FLAP and you can use the touchscreen.its not to wory about that
Aug 25, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
The touch screen is not working. After resetting
If the buttons on the touch-panel LCD screen do not respond correctly or do not work at all, adjust the LCD screen calibration. Consult the instruction manual if specific information is required to perform this procedure.
NOTE: The touch-panel LCD screen cannot be calibrated if it is rotated.
Aug 08, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
SONY DCR HC 20
due to open & close screen your screen belt has damage. send to us for service.
Jun 18, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
Touch Screen not responding to Touch
the flexwire cable is have an openline and that line is connected to the touch screen panel...it have to repaired or replace that flexwire to the service center....in our shop we modified that wire and became more durable than the original wire......:-)
Jun 05, 2007 | Sony Handycam DCR-HC30E Mini DV Digital...
Sony Handycam DCR-TRV460 Digital Camcorder Logo
488 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
