Question about Bauknecht Dishwashers
Model gsfs 4211, i got power to the machine but there is nothing else happening
  • 550 Answers
Had this happen a couple of times, somebody(me) didnt turn on the water after a repair so the dishwasher wouldnt go
Not a solution something to check
Posted on Sep 11, 2008
Why won't my whirlpool 10kg sports washing machine model number wfe1210cs turn on?
Check this attached link, it may give you incite on your washer problem
May 27, 2014 | Whirlpool Washing Machines
My machine will not come on, nothing happens
check the outlet first
the check to make sure the power cord is pluggged in correctly
there could be a problem with the on and off switch
the motor could have gone out
the power cord could be bad
it would be a good idea to have the machine checked
Nov 26, 2012 | Singer CE-200 Quantum Futura Computerized...
Advent 4211-C won't power up on AC or battery. The only sign of life is the battery charging light which displays green continuously when the computer is plugged in to the mains... apart from...
You may have already tried this... Please remove the battery to see if the machine responds to pluged in power by itself. Press the power button for about 30 seconds befor pluging in the power... this is usually the way to reset the laptop. A defective battery can keep the machine from working.
If there is no response, the motherboard may have been damaged or a solder gotten loose, either way, it would need to be taken apart to verify and the solution could be expensive.
Aug 25, 2011 | Advent 4211c Notebook
Nothing happens no lights,buzzers,nothing. have power from wall to timer nowhere else
What is the make and model of the washer? If it is a Maytag top load, the lid switch assembly is probably bad. Get back to me with the make and model # of the machine and I will better able to assist you.
Mar 01, 2011 | Washing Machines
My Fisher & Paykel GWL15 clothes washing machine will not turn on. There is power at the the electrical outlet. But when I press the power button, nothing happens at the machine.
Hi just read your posting.Could you supply the model of the machine for me or the name of the machine which should be written on the front panel.The model number is on a sticker at the back.There are 2 reasons your machine does not light up.The 1st is your drain pump is faulty or 2nd- your motor controller is faulty.Please reply with additional information on the name or model number and I can guide you throe the next step.
Jun 19, 2010 | Washing Machines
LG Model WM2016CW Front load washer is 1 year old. It quit today. No power---NOTHING happens. Any answers??
Same thing happened to me
I freaked out
Then I emptied the water basin, on the front of the machine near the bottom. then it started up and worked
Feb 22, 2010 | LG Washing Machines
I have a simplicity model 4211 lawn tractor with no spark.
terry, check for kill line on motor to see if grounded out,you can remove from ground clip.
also you say you checked points??????
check for flywheel to coil pickup clearance .
point type coil to flywheel the airgap should be 25- 1000ths with feeler guage. on electronic ignition coil to flywheel pickup the air gap should be set @ 10-1000ths with feeler guage. hope this solves your problem..........lemmee kno.....chris
Jun 07, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Dishwashers Logo
174 people viewed this question
Top Bauknecht Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Andrew Taylor
Andrew Taylor
Are you a Bauknecht Dishwasher Expert? Answer questions, earn points and help others
