Question about Olympus Camedia C-750 Ultra Zoom Digital Camera
Power zoom not working
Camera worked fine, switched off, powered back on but then Zoom seemed to be sticking. Motor was trying to work but nothing happening then bleeped. No error message on display. Can view pictures taken but other than that it seems stuck. Help!
    Novelist:
  • 130 Answers
If you dont have rechargable NiMH batteries get these first. Alkalines just dont have the power anymore these newer devices need. If you do have NiMH and yours still having problems try and tap on the lenses as you power it on. As the motors that drive the autofocus and the lens mechanisim wear they draw more current. When this happens the unit draws more power then the batteries can supply and you run into problems. If your camera has a battery pack you may need a new one. They test them new and everything is good on paper but after some use things change.
Posted on Apr 24, 2006
My camera is really blurry; theres a pop-up that says: E:61:00
Press the reset button on the bottom of the camera. Then power the camera off, and power it back on again. "I have a DSC-P50 and was encountering the same problem. I went in to the camera set-up mode with the memory stick removed and changed serveral options (Don't remember which ones, although I do remember trying to change the "Format" setting) When I re-inserted the memory stick, the camera worked. " E 61 00 Difficult to adjust focus Inspect the lens block focus reset sensor
E 61 10 Zoom operations fault Inspect the lens block zoom reset sensor
E 62 00 Steadyshot function does not work well. Inspect pitch angular velocity sensor
E 62 01 Steadyshot function does not work well. Inspect yaw angular velocity sensor
Hope helps.
Apr 06, 2011 | Sony Cyber-shot DSC-T10 Digital Camera
I dropped it and it says zoom error
Sounds like the power zoom assembly (motor, gears, etc), has jammed due to the drop. That and possible electronic problems on the controller board or possibly the zoom switch itself suffered damage in the drop also. Try working the zoom switch rapidly , back and forth a few times and see if it frees up. May be a candidate for the repair shop. Sorry for your accident.
Jul 14, 2009 | Fuji FinePix S700 Digital Camera
Won't take pictures when zoom
Most common problem in al the digital camera's. Slide motor start malfunction and the massage appears"Turn off the power and on again". In this situation you have to replace slide motor or lens block assembly, And your camera work fine again.
Thanks for using fixya.
Jun 27, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Wont zoom
Hello!!!
Try hard resetting once!!! Switch off ur camera , remove the batteries and press the power button for few seconds. then put the batteries back and try powering on!!
Nov 04, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
C8080 acting weired
The mode dial switch, zoom and power are all on the same ribbon cable. If you can spray some electrical contact cleaner into the crease of the mode dial, power button and zoom lever, it may be enough to get thing going again. I would try this with the camera inverted to reduce the spread of the cleaner. The upgrade process takes about 35 seconds. Make a file called firmware on your memory card, download the .bin file into the firmware folder and turn on the camera in play mode. The current version of the firmware will appear and an OK, press "OK" and the firmware will start to update. Do this after a factory reset as you stated that it was stable for 30 minutes. Good luck. Contact me pishta68 at hotmail dot com if you have any questions. I have 2 and a "half" of these cameras. I think the most current firmware is v757-78
Jun 16, 2008 | Olympus Camedia C-8080 Wide Zoom Digital...
Cannon zoom sd870
hi have you tried removing the battery for couple of hours so it can reset any settings that need to be set back to default it only resets camera memory not settings you have changed but this can sometimes solve the problem your having.
Also when you switch camera on and then press zoom when the camera switches off does the lense go back inside the camera as normal or does it reamin out.
when you switch in on do all the other buttons work like can you take picture and can you access all the menu if you can then take it off auto if its on auto then see if this let you use zoom if not then the chances are their is a fault on the zoom button either jammed could be that the lense motor has come out of line with zoom button, is the display clear when you go to take picture without adjusting the zoom is it still possible to take pictures
Apr 09, 2008 | Cameras
Zoom will not go back when i power off, comes up zoom error
My camera was dropped and the zoom small stick stop working, looks like it was stuck, when I want to zoom I pull de stick but it doesnt work, any suggestions?
Apr 04, 2008 | Cameras
Canon Powershot A520 Stuck in View Picture Mode
You need to power it with rechargable batteries. with the MAH being no less than 2000. I bought a charger which came with 2batteries for less than a tenner
Sep 30, 2007 | Canon PowerShot A520 Digital Camera
Zoom Won't Work
The motor has failed I guess Check the Olympus site for advice re repair or replacement.
Aug 12, 2007 | Olympus Camedia C-725 Digital Camera
Zoom is stuck
Just check the DC power supply flowing to the Lens block control. Some times the SMD fuse blows off and power may not reach the lens block motor.
Dec 02, 2006 | Sony Handycam DCR-PC105 Mini DV Digital...
Olympus Camedia C-750 Ultra Zoom Digital Camera Logo
60 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you an Olympus Camera Expert? Answer questions, earn points and help others
