Question about SKYPE / VOIP to PSTN (RJ11) Phone USB Adapter (POTHVOIPUSB3)
I have sound problems with skype, speech cutting and a lot of noises
Every time i used skype to make phone calls there is a terrible echo and speech cuts all the time ., i am able to hear one word and i miss 3 or more words
  • 3 more comments
  • terriet2 Nov 22, 2008
    I have tried using my built in microphone, as well as a separate headset with microphone. Both situations the sound cuts in and out. I contacted my ISP and we checked download and upload speeds and they were good.
  • Anonymous Dec 11, 2008
    poor sound missing words
  • optymyst Dec 25, 2008
    While using Skype incoming sound is fine, but others report that my speech to them is staccato and parts of words are lost, almost as if compression is taking place. This is also apparent when I listen to the recording I make when I use Skype Test Call. I have adjusted all settings according to Skype help several times and have tried four different microphones.The problem persists.
  • yavirac Dec 27, 2008
    I have same problem. Skype cuts in and out. I am using a fixed wireless ZTE, think it is the internet connection, but would like to know ways to optimize that connection
  • samrose Apr 11, 2009
    call breaks down every few minutes
  • 71 Answers
Usualy this is a problem with the internet -even if the speed looks ok
bernard
http://www.rylwy.com/
Posted on Aug 08, 2012
  • 6,487 Answers
Did you try using a different headset just to check if the probem is with your headset or wuth the skype connection? by the way if you have time send me a message on my yahoo messenger so we can tak about this problem of yours...
Hope that helps....
Posted on Sep 12, 2008
2 Suggested Answers
ziraffa
  • 827 Answers
SOURCE: i have sound problems with skype, speech cutting and a lot of noises
if you right click on the realtek audio manager at the bottom right hand corner of yr screen, then hit the microphone tab, you might be able to run 'acoustic echo cancellation'.
otherwise, turn up your microphone a bit, and make sure you have enough bandwidth, ie your not running torrents or have msn messenger sending or receiving a file or something (or indeed running at all, it is sucky bloatware hoho).
try turning the pc sound down a bit and the skype volume up a bit.
otherwise we just have to wait for skype to improve, as i'm sure it will do as more people use the service. good luck..
chris
ziraffa@hotmail.com
Posted on Dec 13, 2008
Noise when talking on skype
When using services like Skype or VoipBuster the audio is compressed. Depending on the quality of the internet connection the audio quality will be different. If you or the person on the other side of the line has a bad internet or bad WiFi connection, the compression of the audio will be much stronger, resulting in a worse audio quality.
Another problem that occurs many times is an audio feedback. If you, or the person you're talking to uses a microphone and computer speakers, the audio coming out of the computer speakers can be captured by the microphone and be amplified again. It forms a feedback loop and creates an echo. The best thing to do is that you both use a good quality headset instead of putting the audio over computer or iPad speakers.
For your iPad, you can buy the Apple EarPods. They are affordable and contain a microphone to make Skype calls with your iPad.
You own a iPad, which is a device of high quality. If the person you're talking to has a crappy phone or bad hardware, the quality will be bad. The advice then is that that person buys a device that has a higher quality than he or she is using now.
I hope my advise will solve your problem.
Feb 12, 2014 | Apple Ipad I-pad
How do I reduce my clipper's rattling noise and still be able to cut properly?
The power screw is the correct way to adjust the problem you describe. If you have attempted to adjust it as instructed in the user manual and have not had satisfactory results, there may be a problem with the clippers.
Most Wahl clippers have a 1 year or longer warranty. You can call Wahl for warranty service at 1-800-334-4627
Nov 12, 2011 | Health & Beauty
Everything works except the person I call cannot hear me. I am using skype. The echo check on skype works, I have tried two other cameras and I have the same problem. No matter how I change the settings...
The Camera and Audio setups are unrelated in both Windows and Skype. Please check your Windows Audio devices volume settings and specifically the Microphone settings: it appears to be disabled or the volume level set much too low. The windows settings overrides the settings in Skype (or in other words, Skype volume settings are a subset of the Windows volume settings). Check that Skype audio is setup properly after starting Skype: Tools -> Options -> Audio Settings -> select your required devices and volume levels. During this ajustment process, make free calls to Skype 'Echo / Sound Test Services".
Hope it helps! Let me know how you go!
Dec 31, 2009 | Microsoft LifeCam VX-5500 Webcam
chris
ziraffa@hotmail.com
Dec 13, 2008 | SKYPE / VOIP to PSTN (RJ11) Phone USB...
Logitech Quickcam Communicate Delux Auidio Problems with Skype
I had a similar problem, the solution was as simple as not playing your voice through the speakers. The problem sounds like one of feedback. There are companies that sell phones that hook up to your usb port and will not cause this type of problem. Another solution may be lowering the volume on your mic.
Aug 20, 2008 | Logitech Quickcam Chat Webcam
Motorola H3 headset. Echo and Squeal.
The echo is unfortunately a common problem with the Motorola H3 headset. I have one of those sitting in a drawer somewhere because it echoed with every phone I paired it to. After buying the H3 and experiencing the echo, I read reviews. I should have read the reviews first. Lots of people get the echo and there doesn't appear to be any fix. I guess that's why I got the headset, a leather case, and a car charger in a kit for just $20.
Jul 03, 2008 | Motorola Mobility H3 Bluetooth Headset,...
Terrible feedback sound
sounds like maybe you have two microphones running at same time?
Feb 25, 2008 | Microsoft LifeCam VX-3000 Web Camera
Linksys adapter
Factors that Affect Voice Quality
  • Audio Compression Algorithm
    Speech signals are sampled, quantized and compressed before they are packeted and transmitted to the other end. For IP Telephony, speech signals are usually sampled at 8000 samples per second with 12-16 bits per sample. The compression algorithm plays a large role in determining the Voice Quality of the reconstructed speech signal at the other end. The SPA supports the most popular audio compression algorithms for IP Telephony: G.711 a-law and µ-law, G.726, G.729a and G.723.1. The encoder and decoder pair in a compression algorithm is known as a codec. The compression ratio of a codec is expressed in terms of the bit rate of the compressed speech. The lower the bit rate, the smaller the bandwidth required to transmit the audio packets. Voice Quality is usually lower with lower bit rate. However, Voice Quality is usually higher as the complexity of the codec gets higher at the same bit rate.
  • Silence Suppression
    The SPA applies silence suppression so that silence packets are not sent to the other end in order to conserve more transmission bandwidth. Instead, a noise level measurement can be sent periodically during silence suppressed intervals so that the other end can generate artificial comfort noise that mimics the noise at the other end using a CNG or comfort noise generator.
  • Packet Loss
    Audio packets are transported by UDP which does not guarantee the delivery of the packets. Packets may be lost or contain errors which can lead to audio sample drop-outs and distortions and lowers the perceived Voice Quality. The SPA applies an error concealment algorithm to alleviate the effect of packet loss.
  • Network Jitter
    The IP network can induce varying delay of the received packets. The RTP receiver in the SPA keeps a reserve of samples in order to absorb the Network Jitter, instead of playing out all the samples as soon as they arrive. This reserve is known as a Jitter Buffer. The bigger the Jitter Buffer, the more jitter it can absorb and the bigger the delay it can introduce. Therefore the jitter buffer size should be kept to a relatively small size whenever possible. If jitter buffer size is too small, then many late packets may be considered as lost and thus lowers the Voice Quality. The SPA can dynamically adjust the size of the jitter buffer according to the network conditions that exist during a call.
  • Echo
    Impedance mismatch between the telephone and the IP Telephony gateway phone port can lead to near-end echo. The SPA has a near end echo canceller with at least 8 ms tail length to compensate for impedance match. The SPA also implements an echo suppressor with comfort noise generator (CNG) so that any residual echo will not be noticeable.
  • Hardware Noise
    Certain levels of noise can be coupled into the conversational audio signals due to the hardware design. The source can be ambient noise or 60Hz noise from the power adaptor. The SPA hardware design minimizes noise coupling.
  • End-to-End Delay
    End-to-end delay does not affect Voice Quality directly but is an important factor in determining whether subscribers can interact normally in a conversation taking place over an IP network. Reasonable delay figure should be about 50-100ms. End-to-end delay larger than 300ms is unacceptable to most callers. The SPA supports end-to-end delays well within acceptable thresholds.
Dec 01, 2007 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
I hear an Echo when I'm using my Iphone
One of the PC magazines did an extensive drop test on the iPhone without breaking it, so your dropping it on the carpet didn't cause the problem. Echos can be caused by communication with the cellular network, so you should verify the problem by trying the phone in your local ATT/Cingular store. You may also experience a time delay that you will notice if you call another phone close by where you can hear the live voice as well as the one on the phone. Both of these problems are found in all cell phones, not just iPhone, BTW.
Jul 22, 2007 | Apple iPhone Smartphone
SKYPE / VOIP to PSTN (RJ11) Phone USB Adapter (POTHVOIPUSB3) Logo
2,486 people viewed this question
Top SKYPE Computers & Internet Experts
Mike
LP
Are you a SKYPE Computer and Internet Expert? Answer questions, earn points and help others
