Hi, My Gateway MX3215 notebook computer no longer powers up with the AC plug. The battery was 5% and the AC plug was connected when the computer died, and it has not come back since. I have plugged in the AC to recharge the battery but after hours of recharge time, it is still not operating. What can I do? Thanks, Kendall
    Scholar:
  • 141 Answers
Make sure you have power at the wall outlet (Dumb question, but I have to ask). If your AC power cable is detachable from the laptop transformer, make sure it is plugged in tightly. If there is a LED on the transformer, make sure it is on. If you have a voltmeter, check for DC voltage at the power supply plug where it plugs into the laptop. You should have between about 10 - 14 volts there. If you don't have a voltmeter (or multi-meter), see if you can borrow one.
If your battery was not seated properly or was worn out, then obviously it would not charge, but the laptop should still function off the power supply, so it is probably not a battery issue. If the voltage input and cable condition checks out okay, then it is probably a bad power supply.
Posted on Sep 11, 2008
When plugged in, will not turn on.sylvania synetlp7" 2gb tablet
"plugged in, not charging" could a symptom of incompatibility between the charger and the battery.
If this is the case, once you unplug your charger, the laptop goes off.
Anyway, it's still Ok to use the ac adapter but you need to plug it in all the time.
Here is a little trick that I found that works.
1. Power up the Notebook with the battery installed,if you can.
2. Turn the computer completely off and remove the battery.
3. Power up the Notebook with AC power only (no battery installed).
4. Turn the computer completely off and re-install the battery.
5. Power up the Notebook.
6. The message no longer appears (at least for me it has disappeared).
Aug 07, 2013 | Computers & Internet
Charger light goes out when plug in computer
it could be that the connection jack on the mainboard has been dislodged from the solder joint, common among Gateway comuters and HP units too. is the DC jack loose from the notebook ? if so thats the issue it seems. You will have to bring it to a computer person to resolder. if not and youc an do it yourslef, save money -- but be careful not to damage anything on the mainboard.
Jan 03, 2012 | Gateway NV5207u Notebook
Gateway MX6428 Power Problem
faulty wiring in the wall (hopefully not) or the AC adapter try another adapter or outlet
Aug 12, 2009 | Gateway MX6428 Notebook
I have a Gateway 4525GZ power problem
your ac adoptor is not correct it is low amh
please check for original adoptor
Jul 30, 2009 | Gateway 4525GZ Notebook
Intermittent dc jack connection for Gateway mx3215
Here is how to disassemble Gateway laptop,
Here is replacement DC socket (needs soldering),
Here is DC board (no need soldering, but expensive).
Hope this helps.
Mar 17, 2009 | Gateway MX3215 Notebook
Need to replace my keyboard on a Gateway mx3215.
The best way to replace the keyboard is to first order one off of ebay.
eBay links for MX3215 Keyboards
Next step is to follow the instruction manual from Gateway. Download the following PDF document, and check out page 45 in the PDF document [labled as page 41 in the manual].
Download Gateway MX3215 Hardware Manual
Best of luck!
Mar 16, 2009 | Gateway MX3215 Notebook
Gateway MX3215 will not come on its only 2 years old
check first to remove the battery and plug the cord if it is working without battery...if working..means the battery problem...
try to put the battery back into laptop and check if working and not working.
Jan 04, 2009 | Gateway MX3215 Notebook
Plug in power cord and push power button, nothing comes on
Yup Yup I had the 28, same problem, the issue is within the adapter plug itself, I ended up taking my laptop apart and hard wiring the the connections directly into the wires that came off the plug, it was the only way to solve the issue without ordering the part from gateway,,,this is a image of the device that is causing you this misery.
t
http://cgi.ebay.com/DC-Power-Jack-For-Gateway-MX3212-MX3215-MX3225-MX3228_W0QQitemZ330288544158QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item330288544158&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
Nov 21, 2008 | Gateway MX3215 Notebook
Gateway
Throw the whole thing away. I had the same problem plus the wireless card gave out. Biggets piece of junk made. Also had to upgrade the ram to 1 gb just to get the thing to work. Best use for this unit is a paper weight.
Mar 29, 2008 | Gateway MX3215 Notebook
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
