Question about Bosch Washing Machines
We have inherited a bosch WFF2001 washer> It starts washing but does not rinse or spin. We have left it an hour washing but goes not further.
    Genius:
  • 1,239 Answers
Hi sir  i thinkKeeping the dishwasher's sprayer arms, strainers, and water pump clean will help deter problems before they begin. Here's how to check on these important features.The heating element is used to help dry the dishes. In most dishwashers, the heating element fits around the screen in the bottom of the tub housing; it looks like an electric oven element. The heating element doesn't malfunction often, but it can burn out. If you suspect a faulty element:
thank u..................................please rate
Posted on Sep 11, 2008
Wash doesn't progress to rinse and spin
This is one of 3 faults
1 you may have a problem with the heating cycle check element
2 you might have a water valve not working
3 there may be a program fault
These videos on how to change an element and water valve will help
Jul 22, 2013 | Bosch Classixx WFL 2066 Front Load Washer
Bosch WFF2001. Works OK in wash cycle but leaks heavily (from drum seal?) on rinse. Not from door seal. Any ideas?
This video will show you how to change a door seal on this Bosch WFF2001 front loader washing machine
May 02, 2011 | Washing Machines
My WFF2001 Bosch washing machine will not wash above 30 degrees. Previously, I had started a prog and immediately realised it wasn't the correct one. Stupidly, I turned it to the correct delicate wash...
Normally this must not happen but remove the plug and keep aside for the error voltage to subside in the processor controller.
Now after a few hours plug on the washer holding the stop /pause button.
Now check to see if the fault has cleared.
This is a case of errror when the program wa shifted and you can still repeat to unplug the washer overnight/24 hours.
Sep 18, 2010 | Bosch Classixx WFL 2066 Front Load Washer
My Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Dec 09, 2009 | Bosch Washing Machines
Bosch Nexxt 300 washer takes hours to do a single load
We had similliar problem. We were overloading the wash barrel and using too much soap. The soap was foaming causeing the washer to add rinse cycles hinse more time to the cycle. Make sure your soap has the HE ( high efficiency ) label on it. Hope this helps.
Jun 27, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Detergent dispenser
As far as I am aware, there IS NO dispenser for bleach, you have to put bleach in drum before adding clothes and starting cycle. The far right compartment is only for "pre-wash" cycles, and if no pre-wash is selected, water will run through ALL compartments at the rinse stage..... Oshie
Feb 28, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
142 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
