Question about Maytag Kitchen Ranges
The light to indicate left rear burner on burner doesn't work. Indicates when rest are on.
  • 38 Answers
It's quite possible that bulb may be burnt out. Especially if you favor using the left rear burner. If you are not familiar with troubleshooting electrical problems with an ohm meter then I would suggest removing the control panel and replacing the bulb. If the bulb doesn't come on then you have an electrical short somewhere along that burner's lines and I recommend consulting a local repairman that you can find on fixya's directory. I hope this lets you see the light.
Posted on Sep 11, 2008
I have a kenmore stove model number 790,72403012 and 3 of the 4 burners are working. They all are getting a spark, but the front left won't fire up.
First, try to light the burner in question with a match. Just hold a match to the burner, then turn the gas on to low. If the burner doesn`t light, the problem is the gas supply to the burner. Next, lift the top cover and put the prop rod in the hole in the cover to support it. Hold a match to the left-front burner. Now, turn the control knob to "light". You should see the igniter spark and hear a snap. If this doesn`t happen, repeat this step with the left rear burner. If you hear the spark and snap.
If the igniter doesn`t work on the front left burner, but does on the rear left burner, the igniter does work. The problem is likely the control knob for the left front burner. The. Control knob includes the electrical switch the activates the igniter when you turn on that burner.
Jan 26, 2015 | Kenmore Kitchen Ranges
1998 dodge Dakota Ok so I just got this truck and when I got it the abs light and brake light were on plus the speedo doesn't work sometimes I replaced the rear speed sense on the diff but the lights...
If the red brake light and the ABS light are both lit up on the dashboard, do NOT drive the vehicle. It indicates a major malfuntion with the brake system. The red light indicates low brake fluid or the parking brake engaged. The yellow ABS without the red light, indicates a problem the computer found and it disables the ABS system while still having conventional brakes. Since both are lit, it needs the brake system repaired. What you replaced on the rear diff was probably the rear ABS sensor. The vehicle speed sensor for the speedometer should be located on the rear of your transfer case if you have 4WD, or on the rear of the trans if you have 2WD.
Oct 11, 2012 | Cars & Trucks
Left brake light doesn't work when brake depressed but comes on when headlights are turned on.
Hello, this indicates a problem with either the left rear bulb or the socket that the bulb goes into. remove the rear bulb and check, also take a good look at where the bulb plugs into the socket and make sure there are no corrosion or burn marks
Aug 20, 2011 | 2001 Chevrolet Suburban
Turn sign flash fast in front and no light flash in rear
A fast flash usually indicates a burned out bulb. If you no flash in the rear, that is probably the culprit. Keep in mind just because your taillight works doesn't mean your flasher will. Most newer cars have combination bulbs in the rear with more than one filament in them. Try cahnging the bulb in the rear and if this doesn't help, reply back and we can explore this further.
Apr 30, 2011 | GMC Suburban Cars & Trucks
Burner light stays on
This is caused by a faulty sensor that is located between the burner element and the top. To replace the faulty part you will need to uninstall the cooktop and remove the glass top. The sensor is a rod a little smaller than a pencil that you will see right on top of that burner.
If you choose not to replace the sensor it will not cause any issues other than you will have to live with that light constantly on and you will know when the top is hot for that element.
Jun 19, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Unknown light indicator in the dashboard
it is a rear bulb failure light,have you checked the reversing light bulbs...?
Jun 18, 2010 | 1995 Toyota Camry
My truck lights
check and replace the bulb in the rear left light, the fast blink is normal when the front or rear bulb is out, the brake light not working indicates which one is out
Mar 30, 2009 | 2005 Dodge Dakota
Ignitor won't shut off
The Viking manual says that an ignitor that continues to try to light even after the burner has been lit indicates improper grounding, and that an electrician should be consulted.
Perhaps you could try to replace the ignitor, and see if that fixes the problem?
I have a similar age, 6-burner 36" rangetop.
Sep 30, 2008 | Viking 48" 6 Burner, Grill Professional...
Burner will not turn off
I will need the complete model #. There should be a sticker near the bottom front behind the drawer. Can't use the # that is on the owners manual.
Oct 08, 2007 | GE Spectra JBP78 Electric Kitchen Range
Kitchen Ranges Logo
47 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
