Question about Dryers
Old Kenmore 30BG dryer
We need to replace our old dryer. We have a 20 room motel and need one the same size as we now have.
It is 30x30. ID#TT-D-166431CD
Sears
Originator: Huebsch ??
  • Anonymous Mar 23, 2014
    I have an old Huebsch gas dryer, now it's not working...don't know why?
  • 126 Answers
YOUE BEST BET IS TO CONTACT SPEED QUEEN APPLIANCES AS THEY ARE THE NUMBER ONE SUPPLIER OF INDUSTRIAL WASHERS AND DRYERS.GOODLUCK.MOHAMED
Posted on Sep 12, 2008
Motel tv broken trying to hook up my own
1st I hope the motel is giving you a discount for a room with no tv , second an educated guess would be that your tv is non digital and is set to receive an antenna signal , along about three years ago most all cable systems went to a digital system , this required a down converter for the older TV's to still be able to work on higher channels but some systems still sent 2-13 out on the wire for the older sets as well , essentially the converter takes a hi res digital signal and changes it to a fuzzy/blurry analog signal for the old tv's , silly as it sounds , there's millions of em working everyday in America that way
Feb 26, 2016 | Panasonic Televison & Video
I need to replace some old storage heaters in my
you need to measure the height of celing size of room how many outside walls thickness of walls take this info to your local heating shop they will tell you the heat loss for each room and what size heating you need in kws you then choose the heaters you want
Apr 19, 2010 | Heating & Cooling
15 year old Kenmore dryer not working
Sounds like you thru the breaker. If not, it is the door switch.
Jul 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Have-kenmor-80-series-dryer-about-5-yrs-old-losess-flam-about-6-min-into-cycle attemps to relight no flam.
replace coil kit no 279834.coils will be found on top of burner, unplug wires, 2 screws remove bracket,easy fix part~ $20 .Hope this helps ,please rate my solution :)
420.. 20 min fix .hope thuis
Jun 27, 2009 | Kenmore 73952 Gas Dryer
Dryer no longer has heat to dry clothes
The element gets brittle and breaks. The element is in the rear of the dryer under the dustcover.
May 06, 2009 | Kenmore Dryers
Kenmore Dryer - no heat and timer doesn't stop
First turn off both breakers then back on. Next, check the wiring from the receptacle to the plug to the back of the dryer. Next, the thermal switch under the top of the dryer next to or near the drum may be bad. Bypass it and see if you get heat. If so, then replace it for about $20. Your heating element may be bad also. You can visually check it and see if it is burned in 2. Now your timer is probably bad. They are easy to replace and fairly inexpensive.
I guess after looking at all this, you need to decide if it is all worth it to fix it. If it is more than 10-12 years old, you may be seeing the beginning of the end. If the thermal switch, the element, the timer are all bad, you may want to make room at the curve and take the door off for safety. Dryers aren't that expensive especially when you consider the hassle. Good luck and let me know how and what you do.
Feb 11, 2009 | Kenmore Dryers
Needing 15-20 year old apartment sized dryer belt.
go to a Maytag service agent
even the unit is old , there is a good possibility that the belt is still in use or was discontinue recently and they may have spares
Aug 19, 2017 | Zanussi TC180W Electric Portable Dryer
Kenmore dryer king size capacity 90 series
Sorry to say, but the motor needs to be replaced. motor cost around $150... 9yrs old=not worth fixing...
Jan 03, 2008 | Kenmore 63942 Dryer
Dryers Logo
208 people viewed this question
Top Dryers Experts
