Question about HP Pavilion dv9205us Notebook
SANDREW MY HP PAVILION DV 92505 INACTIVE THE WIRELESS
  • PONKE Sep 12, 2008
    MI WIRELESS SE INACTIVO Y DESAPARCECIO EL ARCHIVO WLAN Y NO HEMOS PODIDO ACTIVARLE LE ACTUALIZAMOS EL BIOS Y NADA VOLVIMOS A CARGAR VISTA Y NADA Y YA NO SE Q HACER POR FAVOR AYUDA
Hp pavilion dv8000 wireless printer does not work
Do you have more than one instance of the printer installed. If that happens the computer gets confused and don't know which one to print to. Also only one can be active if you have two instances of the same printer and you could be printing to the inactive one. Click Start/Control Panel and check your printers to insure that there is not more than one instance of the same printer installed.
Also check down at the bottom right near the time and if you see the printer icon open it and clear out the queue. If you've printed to an inactive printer the queue will block you so just delete or cancel the items in the queue.
Also check your printer properties to make sure it is printing to a TCPIP wireless connection and not a usb connection.
May 01, 2012 | HP Pavilion dv8000t Notebook
I have the hp pavilion 9820 dv pc notebook. I can't activate the wireless. Can you let me know how to do this. Thx
Hi.
There is a little switch on the front where all the little lights (LED) are when your cover is open.
It should slide right side and lights up a little LED confirming your wireless card is turned on.
Hope this helps!
Feb 13, 2011 | HP Pavilion dv9820us Laptop
PAVILION DV 9000 wireless card bios system
I've ran into that defect repairing these laptops and its a crappy motherboard issue, my wife daughter bought her pavilion dv 9000 over and i put my wireless card that was working in hers and it wouldn't even see that one.
The motherboards are junk and all HP is doing is replacing it with updated ones that doesn't have that problem with the faulty wireless card slot.
Sep 02, 2009 | HP Pavilion dv9000z Notebook
Drivers needed
1&lk=1&la=en&nh=10&rf=0&qs=&hpvc=sitewide&uf=1&st=1&qt=HP+HP+Pavilion+dv+9858&submitsearch.x=7&submitsearch.y=8
Apr 11, 2009 | HP Pavilion dv9700t Notebook PC
Morning,I've a problem of my laptop,it's hp pavilion dv4000 and it is missing a wireless driver
Hi, again.
You can select your model from this page
http://h10025.www1.hp.com/ewfrf/wc/prodTopCategory?product=1132535&lc=en&cc=us&dlc=
ones you have found the correct one you then need to choose the Software and driver downloads, you should find the driver there.
Jan 26, 2009 | HP Pavilion dv4000 Notebook
Hp pavilion dv 2310 wireless not catching any wireless networks in the area? even after i've reinstalled the driver...
INSTALL HP WIRELESS ASSISTANT AND CHECK THE STATUS OF THE WIRELESS ADAPTER.. IT MUST BE SET TO ENABLED
Sep 15, 2008 | HP Pavilion ze2000 Notebook
HP Pavillion Dv 9000 stopped recognizing wireless networks.
make sure ya have a VISTA compatible Driver for ya wifi ... go to manufactures web site and DL latest one for VISTA..
Remove and reinstall most up to date driver... then use ya connection program to set it up.
Jun 23, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv9205us Notebook Logo
101 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
