Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
WD external hard disk appears on disk manager but not on my computer nor on disk management
HI
Dear Experts
i have a problem with my WD my book premuim edition 320GB which is that it dont appear on my computer. I've tried everything fdisk utility and drivers , i googled for solutions but nothing worked.My whole life is inside that hard disk and i would be so grateful if you helped me
Regards ^_^ what can i do
  • 5 more comments
  • sweetlynaive Sep 14, 2008
    This is my second time using the Hard drive, this evening it work, the tonight my computer folder just stopped recognizing it. I have the 500GB Hard drive, I did everything that people suggested. I really need to use the Hard drive, i tried hooking it up to another comp. and even that comp. recognized it, but the my comp. folder refused to show the device.
  • Anonymous Sep 24, 2008
    I have the same problem and has nothing to do with being formated in
    Vista since I only have XP and it was pre formated fat 32 from
    factory. The drive does not appear at all as mounted and even
    after disconnecting and pluging it back windows does not see it.
    It was working fine for about a month and today it began to stop showing as mounted.
    I hope somebody can help.
    Thanks
  • ett184 Sep 24, 2008
    I have the exact same problem. It occurred only about 2 weeks ago and I've been trying to figure it out. I have the 1tb Essential edition, and like the originator, my life is on it. I don't mean that figuratively. All my music is on there and I DJ, this prevents me from being able to do anything.
  • Anonymous Dec 03, 2008
    same
  • rsbaxter Dec 07, 2008
    I have the same problem, my MyBook 500GB just appears as a USB device sometimes, I've been searching for a solution buy so far nothing to say, "I've fixed this, but I've been attempting to solve it for about 4 - 5 total hours.
    Just noticed mine no longer worked in Nov and it is about 15 months old.
  • Anonymous Feb 03, 2009
    Same here. Disk management only says WD, no serial number or anything.. Can't find it in My computer. Chkdsk fails..
  • abody_x Feb 15, 2009
    sameb pr
I too went through the Chkdsk, reboot, etc for a 500GB MyBook whick an HP laptop running XP couldn't see. Lucyfr's simple solution "try unplugging it completely, putting the USB in THEN the power supply" finally worked! So simple I nearly wept.
Posted on Feb 03, 2009
Hi guys,
I don't know if this will help you but just had same infuriating problem with my Western Digital Essential Book 250GB.
I wiped my PC and reinstalled windows and hey presto! It couldn't see my drive and I tried for a while pulling out the USB and trying different ports...
I connected it to my laptop and got the same problem, had a fit and pulled the mains plug and then plugged it back in... And it kicked in! I put it back on the PC (USB in but power off, then plugged it in the mains) and it kicked in there too.
Therefore I suggest trying the drive with another system to boot it. Once the laptop recognised it, so then did the PC. Also try unplugging it completely, putting the USB in THEN the power supply...
Might have just been a fluke but hope it helps someone here...!
Posted on Dec 10, 2008
I would like to know if u can suggest a solution for wd 160gb hard disk
Posted on Oct 28, 2008
I have a problem also. someone accidentaly deleted the w.d folders from the hard drive and now i cannot use the hard drive (500gb) it cannot install any drivers, cannot find any drivers, and it shows up on Device Manager as unknown device. anyone can tell me how can i install drivers for that thing?? pls!
Posted on Oct 16, 2008
It doesnt work on the computer i started it with.
Posted on Oct 13, 2008
I met similar problem as stated above. Since 3 weeks ago, my laptop (Win XP) did not recognise my WD hard disk even the disk manager/file management ... . I have hooking it up to another Laptops (such as Vista & Win XP again), it still not detected.
Is there anyone can help??? sigh~~~
  • Justine1984 Oct 13, 2008
We had a simmilar problem, the disk was initialised with vista. It does not read on any other computor on our network. I recently aquired a second vista computor and tried it out on that. Sure enough it works. Thus the problem is that if it was initialised on vista, only vista systems will read it and not xp or 2000. hopes this helps
Posted on Sep 23, 2008
2 Suggested Answers
SOURCE: WD external hard disk appears on disk manager but not on my computer nor on disk management
You do this opration for this my dear steps like 1) First you attache the hard drive to any other system as slave. 2) remove the jumper than start the anthor system then you can seee the data in the hard drive. if this not removale hard disk from your system insert the exrnal hard disk with operating system and remove the jumper for your hard disk than try it it will surley works
take the you data as baackup in some dvd are cd and than you format the drive and reinstal the os of your system and remove the extrnal hard disk
Posted on Jul 23, 2008
I plug in my WD external hard drive, i hear the chime saying the computer knows i plugged something in, but i see no icon to click on to open it. HELP! i have soooooo much information on this thing!
- try plug in a normal usb port (usb2)
- try open up the device manager, look for your WD and delete it.
then unplug and plug back.
try goto control panels->administrative tools->computer management->disk management
and see if your wd appears there. if yes, try change the drive letter assignment.
Jun 14, 2011 | Western Digital My Book 3.0 WDBAAK0010HCH...
Hi Experts! I was using WD essentials 1TB and till two weeks I was working brilliantly, and all of a sudden the Hard disk drive stopped appearing in My Computer ( I am using windows XP). I can see...
There are several walkthroughs on how to recover data
Try loading Windows Recovery Environment on Windows 7 disk
1. First we will be needing a windows 7 dvd (Any windows 7 disk will do ..home, ultimate...etc.)
2. Boot the windows 7
3. under the Install Now windows, click on Repair your computer
4. Choose Command Prompt among the list
5. type Notepad
6. From the Notepad GUI (Graphical User Interface) -> Click File -> Open
7. Open windows will appear
8. Try to path where the external hard drive is in. And select all files that you need to save. By simply copy and paste from where you want to save the files in
Hope this helps
May 19, 2011 | Western Digital - My Passport Essential SE...
My drive is not being recognised and im not sure why up in till this point it has worked fine? It is a WD Essential Model - Wdbaaf0010hbk - 1TB drive it has alot of valuble information that i would hate to...
when your external drive does not appear in "my computer" or not recognized in windows vista or windows 7, then just right click on my computer, click on manage, the go to disk management. Find your external drive there and right click on it, then select assign new drive letter. Select a letter from the midlle of the alphabet like m, then enter. The icon of your external drive should appear inside my computer
Oct 03, 2010 | Western Digital My Book Essential 1TB...
WD 1 TB- WINDOWS can detect but cannot see in my computer
if the disk is not in Computer Management then the disk has a major problem. it should be there but in black because u need to initialize it.
Apr 14, 2010 | Western Digital My Book Essential 1TB...
My computer fails to identify my WD 1tb external hard drive when I plug it in the USB. It also does not show up on Disk Manager. However, it still lights up and I hear it turning. How can I get the...
I fixed that problem with a WDC My Book Home 1TB in Windows 7:
The drive was recognized in computer management and in device manager but no drive letter was allocated while connected with a e-sata cable.
1.in computer management > storage > disk management
2.rightclick drive 1 or wathever the number of the WDC drive (which should be basic at this time)
3.select 'convert to dynamic disk'
4.drive should get a drive letter
5.format (warning: all data get lost, but you can download original software from wdc.com)
Succes!
Olivier
Oct 31, 2009 | Western Digital MY BOOK HOME 1TB EXT...
My WD 2T external My Book hard drive is not working
You will need to try formatting the drive. You can do this from the drive management section on the Mac.
Jul 10, 2009 | Western Digital 500GB My Book World...
External Drive WD is not visible in Mycomputer.
select manage
then disk management
identify the correct drive
right click and format,
once formatted remove
then plug back in,
you should beable to then see it under my computer
Jul 06, 2009 | Western Digital My Book Essential 320GB...
My e book 500 GB IS NOT DETECTED BY MY COMPUTER JUST APPEAR LIKE USB MASS STORAGE AND WD BUT NOT LIKE E:
Rt Click My Computer, Manage, Device Manager and in the Rt side, highlight the TOP icon. Then under Help, click the Computer with magnifying glass i con aand wait. This forces your OS to 'Look' for any new devices.
When it finishes, close the window and see if your new HDD popped up under My Computer
If not, Rt Click My Computer, Manage, Disk Manager... or Click Start, Settings, Control Panel, Administrative Tools, Computer Management, Disk Manager and see if it is there. You may have to Rt. Click and import it as a foreign drive or Rt click and give it a Driveletter ;-)
If RtClicking My Computer doesn't work, Click Start, Settings, Control Panel, Administrative Tools, Computer Management, Disk Manager to get there.
Windows doesn't like 'foreign disks' so ANY time this happens, if OS doesn't see it, use disk manager and Import it.
Mar 26, 2009 | Western Digital 320GB MyBook External USB...
Jul 18, 2008 | Western Digital My Book Essential Edition...
My Book Essential does not show on My Computer - Can't access files.
No matter what I tried, I ws unable to get my "MyBook" working. My solution? Remove from case and voila, it's just a seial ATA drive attached to a small circuit board which converts it to USB. Disconnect from the circuitboard and plug into the motherboard. Imstant success. It failed as an external drive three weeks after the warranty ran out. WD support was zero help.
May 25, 2008 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
776 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
