Question about Sony DVP-NS425P DVD Player
Sony DVP - NS425P
Probem:Will not play DVD and it make and sound . (noise when it start up) There is another signal light below the light above. (That tell the minute or how long the movie been playing) Thanks,
Leon White
  • nbubany Oct 02, 2008
    When you try to play a movie, a loud screeching noise begins. The only way to get rid of it is to re-open the dvd and close it again. Sometimes you have to do this 4 or 5 times before it works.
MikeNJ1964
  • 398 Answers
SOURCE: sony dvp ns50p dvd player
If you are using the s-video jack to connect the DVD to the TV, the jack could be loose or the wire could be bad. The s-video cable has 2 signals, the black-and-white (luminance) and the color (chroma). If the chroma signal is not getting through, the picture will be in black and white.
Posted on Sep 01, 2007
SOURCE: sony dvp-ns425p will play regular CD, but won't play any DVD
just open the player (4-6 screws) and clean the lens. I had a similar problem (plays VCD, CD but no DVD - tray will open immediately). It worked afterwards
Posted on Sep 29, 2007
SOURCE: dvd dvp-ns425p picture no sound
Comcast installed the wrong cables ie. red,green,blue vs. yellow white red.
Thanks for your timely response,
Catherine
Posted on Dec 16, 2008
Shuttle83
  • 1139 Answers
SOURCE: I just purchased a Sony DVD player...DVP-SR200P.
Hello cherylsacket,
Check your cables to your TV. If possible check the various cables to your set. I would suggest using the HDMI cable if your TV has an HDMI input. Remember to power off all devices before connecting your cables. If I may ask which cable are you using to connect between your Tv and the DVD player?
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on May 10, 2009
  • 10 Answers
SOURCE: SONY DVD PLAYER DVP-SR200P BUT IT ONLY SHOW IN BLACK AND WHITE ?
You have posted this in the Panasonic DMR-ES30VS section.
Please note which product section you are in before posting your question.
For the Sony DVP-SR200P there could be multiple reasons for it only showing in B&W.
Was this a recent problem, is this a new hook-up, has it always been this way?
  1. In the setup menu there is a setting for Custom Picture Mode.
    Could someone have turned the color down?
    You can go to the setup menu and "Reset" the player to the factory settings.
  2. How is this connected to your TV?
    Check all cables to make sure they are plugged in, test each one by unplugging it, and then plug it back in fully.
    If you are using a composite cable (1 cable yellow plug), be sure you have plugged it in from yellow to yellow.
    If you are using the component (3 cables red-green-blue plugs) hook-up, be sure you are using cables only designed for component hook-up, and have plugged them in correctly, red to red, green to green, blue to blue (Be sure you've plugged the red cable into the red video not red audio).
    Are the cables in good condition?
    No breaks, loose connectors, they weren't smashed under a piece of furniture?
    Have you tried a different set of cables?
  3. Test the DVD player on another TV.
    Does the same thing happen?
    Did you "Reset" the DVD player?
    Maybe the DVD player is bad?
  4. Find another DVD player and test it with your TV.
    Does it work OK, or is it black and white too?
    Maybe the connectors on the TV are bad?
    Is there a custom setting on the TV for that connection?
    On some TVs you can adjust the settings for each input (INPUT 1, INPUT 2, ....) maybe the color setting is turned down?
There are may possibilities, but these are some of the basic things to check.
Best wishes,
-Greg-
Posted on Sep 14, 2009
Sony dvp-ns425 player has the word VIDEO in upper right corner appear and disappear every 20 seconds or so. It is in the same green block letters as all the menu/control titles so I know it is from the dvd...
That word Video in green color could be TV's on-screen display as DVP-NS425 has another kind of on-screen display that has track info, time info etc in display.
Please press Display on TV remote to turn off that green color Video on-screen display at top right corner.
Thanks.
Sep 13, 2009 | Sony DVP-NS425P DVD Player
I can hear audio but can not see the DVD?
A button named "PROGRESSIVE" would be there on DVD player front panal, press it and picture will come on screen, your DVD is fine nothing happen with it.Just press the progressive button.
Thanks for using fixya.
Jul 24, 2009 | Sony DVP-NS425P DVD Player
Sony dvd/video combo dvd stuck inside
will it play the disc? try giving the door a little help when ejecting sounds like a slipping drive belt.farr64
Apr 29, 2009 | Sony DVP-NS305 DVD Player
Dvd dvp-ns425p picture no sound
Catherine
Dec 15, 2008 | Sony DVP-NS425P DVD Player
Lost the remote
If it is Sony DVD Player DVP-NS425P then you need original remote to use above options.
Remote part number is as follows...
clear_spacer.gif " 147772411 " RMT-D153A REMOTE CONTROLand price is approx $18 and available at Sony Accessories. Please write model number of your dvd player DVP-NS425P in search box and see result.
Oct 04, 2008 | Sony DVP-NS425P DVD Player
Playing DivX format on Sony DVP NS530 DVD player
No Sir, You can't upgrade DVP-NS530 to play DivX format. This player has no ability to play DivX nor it can be upgraded.
Jun 03, 2008 | Sony DVP-NS530 DVD Player
Sony DVP-NC600 Powers down during CD playback
The tray won't open. I took top off and dvd top side holder, but the laser mechanism won't disengage so the tray will open, even with no dvd in it. How do
I reset it. I power on, hit open key, it makes hum noise then goes by to
standby mode.
Jan 06, 2008 | Sony DVP-NC600 Multi-disc DVD Player
DVP NS-530 Cannot Play
It sounds electro-mechanical. Meaning it could be a solenoid not engaging one of the mechanical arms, or even one of the plastic mechanical arms could have jumped out of their socket. It doesn't sounds too drastic, however the unit will have to be pulled apart and investigated. thanks ST
Dec 17, 2007 | Sony DVP-NS530 DVD Player
Sony dvp-ns425p will play regular CD, but won't play any DVD
Aug 14, 2007 | Sony DVP-NS425P DVD Player
Sony DVP-NS425P DVD Player Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
