Question about Admiral Refrigerators
My ice will not come out from my slot wen i push the cup under i think its the moter that opens the lid to let the ice out
  • 126 Answers
THE FLAP THAT LFTS UP TO LET THE ICE OUT IS MAINLY CONTROLLED BY YOU PUSHING ON THE LEVER.YOU NEED TO CHECK IF THE LEVER HAS NOT BEEN DAMAGED.GOOD LUCK.MOHAMED
Posted on Sep 12, 2008
Tip
ICAPP-4 - A Wiki Manual
Cuisinart ICAPP-4 – Iced Cappucino and Hot Espresso Maker – A Wiki Manual
By Tha Mp3 Doctor (who also loves Cuisinart)
Since I am not well-versed in the copyright laws regarding reprinting copies of standard user’s manuals online, I am writing this Wiki Manual for the ICAPP-4. My unit is 12 years old (in 2009) and continues to run strong through two different owners.
General Directions for Making Iced Cappuccinos
- Place carafe on top of drip/tray grate with handle touching right front of ICAPP – the ice fill lines should be visible when looking at front of unit
- Turn “milk knob” to OPEN position, and open lid of ICAPP
- Remove milk container, espresso collector, espresso spinner cup and cover
- Put espresso collector back in place with two plastic teeth facing front of machine
- There is a stepped fill line inside water reservoir that measures off 1,2, and 4 cups
- Fill water reservoir with either 1,2 or 4 fill line cups – do not overfill to avoid damaging the electronics
- Add espresso grounds to espresso spinner cup
- Line up teeth of spinner cup cover with spinner cup so that the cover locks into place
- Fill milk reservoir with 3 oz of milk per cup of iced cappuccino that you plan to make – there is a fill line that measures off 2 cups or 4 cups
- Fill carafe with either 2 cups worth of ice or 4 cups, depending on how much iced cappuccino you plan to make
- Press down on lid and turn milk knob to HEAT postion
- Turn ICAPP on using the ON/OFF button – it will begin to heat – takes about 5-6 minutes (HEAT light will stay on during this process – doesn’t make noise or steam for several minutes)
- When READY light turns green, turn the milk knob to the DISPENSE MILK position – your espresso and milk will start dispensing
- Unit turns itself off automatically when ready – takes several minutes
on Feb 25, 2009 | Cuisinart ICAPP-4
How do I remove gear stick on 2008 Mitsubishi l200
For the handle. Pull it back, on the front there will be a slot or set screw in the front. Set screw takes an allen wrench to loosen. Slot, insert a small flat screw driver and push in and pull up. To remove the shifter , you have to remove the console first. Screws and bolts could be(I do to many, I just know where to look). Panels under the dash, under cup holder mats, remove the box and lid, some under them. At the back, remove the blower vent or cover. and on the sides, you have to move the seats forward to get to them. then 4 bolts to remove and the wires and cables.
Dec 18, 2016 | Mitsubishi L200 Cars & Trucks
WONT SPIN ?
There is a switch..(interlock) that activates when the lid is open or closed...not allowing the unit to go into spin if the lid is open. It may be that the machine thinks the lid is open. The switch could be dirty or broken or loose. There is a little leg sticking out from the underside of the lid, that goes into a slot on the machine when the lid is closed, that activates the switch. Make sure this all looks good, (no obstructions or debris in the slot) and the leg goes all the way into the slot (lid closes all the way).
You should see a little plastic lever in the slot that the leg on the lid will contact when you close it. If it is there and unobstructed, try gently pushing down on with your finger or the back of a pencil or something, until you hear a faint click (switch). It should spring back into position when you release. Its a quick and easy check. Good luck.
Feb 25, 2016 | Washing Machines
My washer washes fine but when its time to spin it wont spin or drain waster
Under the washer lid you will notice a peg that goes into a slot, that is a safety switch that when it spins and you open it when spinning in automatically stops to avoid energy. Sometimes from normalmuse the switch goes out To test this Carefully when in spin cycle , and lid open putna flat head screw driver in that slot and drepress and try again. You know push in and push out, if you hear a clicking sound on when pushing in and out, then switch is probably good. If no click qt all, switch needs replacing, which is cheap and do it self job with basic instructions.
May 29, 2011 | Washing Machines
Moter slipes
Could it be that your lid is worn, or the little indentation on the can is not holding the lid in place? There could also be a stripped gear in the motor. If you need replacement parts, they're sometimes available here: http://stores.ebay.com/Lauras-Last-Ditch/_i.html?_nkw=rival+ice+cream&submit=Search&_sid=93311479
May 11, 2010 | Rival 8401-M 4 Quart Ice Cream Maker
Keurig b30 turn on here motor, no water comes into cup!!!! help
It takes about 3 minutes to brew. You cannot use a clear coffee mug (scensors won't detect it)
You should be able to turn it on, Then place k-cup in holder, Then close lid and water reservoir lid will pop up and you add desired amount of water. Then push lid down, place mug under spout and the blue light will light up and you push taht. Within 3 minutes you should have some coffee
Apr 08, 2010 | Keurig B100 Coffee Maker
No instuctions for my arctic twister which was given to me as is
This product wastes a lot of ice cream in its mechanisms. I would not reccomend its use to anyone who believes in "waste not..."
Here are the instructions for any wasteroos who would still use this product:
Série IC200 Series
Arctic Twister™
Ice Cream Mixer
? U.S.A./Canada 1-800-231-9786
Mexico 01-800-847-2309
www.blackanddecker.com
To Assemble the Ice Cream Mixer:
1. Insert the Twister firmly into the opening on the
Base (A).
2. Slide the Chute/Dispenser over the Twister along the runner
on the Base (B); it will click into place.
Note: Unit will not operate if Chute/Dispenser does not click
into place.
3. Hold the Lid with Ratchet Clip in one hand with the Handle
facing front. With one finger, push the Ratchet Clip on the Lid
forward. In other hand, hold the Plunger with smooth side
facing front, and from underside of Lid, insert Plunger into
Clip opening (C), pushing Plunger up until the Ratchet Clip
rests on top of the Plunger base.
4. Set aside the Lid with Plunger in place. Now you're ready to
start mixing up some fun and delicious ice cream treats!
To Use the Ice Cream Mixer:
Assemble all ingredients before you begin to make your first
batch of twisty treats: Set out an ice cream scoop, the mix-ins
you plan to use, ice cream cones, cups or dessert dishes,
then bring out the ice cream.
For best results, use hardened ice cream, frozen yogurt,
sorbet or sherbet directly from the freezer.
You may want to rinse off the Lid, Plunger, Chute/Dispenser
and Twister before beginning new ice cream flavors or
mix-ins.
Always wash Lid, Plunger, Chute/Dispenser and Twister
between batches, if you have been using ice cream or mix-ins
containing peanuts, to prevent accidental peanut
consumption by those who may be allergic to them.
1. Plug the Cord into a standard 120V wall outlet.
2. Position a flat-bottom cone, dessert dish or cup under the
spout of the Chute/Dispenser.
3. Place 1 scoop of store-bought ice cream into the
Chute/Dispenser. Sprinkle in 1-2 tablespoons of the mix-ins
(see "About Mix-Ins"); add another scoop of ice cream, and
continue layering as above, ending with ice cream, until
Chute is filled.
4. Fit the Lid with Ratchet Clip and Plunger in place (see
assembly instructions #3 above), onto Chute opening,
pressing down slightly and turning the Lid to the right to fit
into position, then to the left to lock it into place on the Chute.
5. Gently pump the Handle up and down a few times to "prime"
the Chute.
6. Press the On/Off Switch to "on" position, then slowly pump
the handle to move ingredients down the Chute. As you
pump the handle, the ingredients will automatically be moved
into the Twister, then out the spout of the Dispenser.
7. When the Chute is empty, turn On/Off Switch to "off" position.
Push the Ratchet Clip forward and pull up the Plunger, then
use the Handle to move the Lid to the right. Lift the lid with
the Plunger in place out of the Chute.
8. Repeat steps 2-6 to make as many batches as desired.
Jul 06, 2009 | Black & Decker IC200 Arctic Twister 2.11...
NEED DIRECTIONS For Model ICAPP-4
I can answer just about any question you have on the unit - I wasn't able to find the manual online, but I would be more than happy to scan and e-mail you my copy of the original manual. In the meantime, here is my basic Wiki Manual:
-Tha Mp3 Doctor
Feb 25, 2009 | Cuisinart Coffee Makers & Espresso...
Over flow grounds without a cause
I have had two of these machines (warranty return) and they both did the exact same thing. Here is what I have discovered the problem to be.
The lid for the carafe gets stick and internally jams. As another poster suggested clean it thoroughly (this sometimes works). I have another solution. Call 1-800-726-0190 and explain that you lid jams and leaks all over your counter. They will send you an new lid for free no questions asked. They obviously are very aware of this situation and don't even ask for proof of purchase or purchase date.
Jan 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Refrigerators Logo
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
