Question about Crosley CW6000 Front Load Washer
Crosley CW6000W Washing Machine
Knob turns great, agitates with unbearable noise, it quit after a minute or so on the rinse cycle....had to throw it into spin just to get the water to drain (after taking out and ringing out the laundry inside). Can someone tell me what to look for before I crack it open? Never worked on an appliance in my life, in my small town there is no repairman available.
  • Anonymous Nov 09, 2008
    it just wont turn on or do anything
  • 641 Answers
SOURCE: Spin Cycle/Machine makes noise and moves
You can't tight up the tub. You should replace the damper pads that located beneath main support housing on base's machine. Goog luck !
Posted on Jul 26, 2007
  • 105 Answers
SOURCE: Crosley caw5923mqd Top Load washer spins but leaves A LOT of water in the clothes
have you checked the pump out of the maachine
the pump may be blocked restricting water flow
if that is ok maybe you need to give the n
machine a hot wash the seals may be draging the spin down
Posted on Mar 16, 2008
  • 185 Answers
SOURCE: Crosley top load CW6000W
check to see if the water is plugged in the hoses and check the water valves
Posted on Mar 26, 2008
thaurfen
  • 623 Answers
SOURCE: extra loud noise when spinning
most likely the main spin bearing at the top of the transmission just below the spin basket and seal
the bearings dontjust go out for nothing either,you will need to be replacing the tub kit seal also
not the easiest of repairs,may need special tools to remove the seal nut assembly...
Posted on Mar 17, 2009
  • 14 Answers
SOURCE: I am not sure how knob comes off of CW6000W
pull hard or pry it off it is just pressed on.
Posted on Nov 21, 2009
Washer makes grinding noise when it agitates
check back of unit as the concrete on the back may of been dislodged check not over loaded also the belt maybe loose or streached
Jan 02, 2014 | Crosley CAWC529JQ Top Load Washer
How to disassemble drum from shaft of cw6000w model
my washer agitator will not move or make its usual half turns it makes loud noise i went out and bought a new bas for it tryed it no luck went to take spline off offdrum to fix gaskets or whatever just to check wont come off
Dec 09, 2012 | Crosley CW6000 Front Load Washer
Maytag agitator will not turn
Sounds of a loose motor or need brushes replacement.
Jan 13, 2018 | Maytag MAV6457 Top Load Washer
Kenmore Series 90 washing machine, won't start cycle
First, see the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26912691&pathTaken=partSearch
Next, see the Whirlpool / Kenmore Service manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I hate to say it but it sounds like a Timer problem.
I'd use the troubleshooting section of the Service Manual and the timer testing procedures to confirm the problem.
Note that there are two types of timers with different procedures to remove them.
Also see the following for how to release the console for access to the timer and other controls.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=5216f244d51176ce1069bbf148b14335
May 07, 2010 | Kenmore Washing Machines
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Mar 19, 2008 | Washing Machines
Crosley CW6000 Front Load Washer Logo
367 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
