Question about Insignia IS-LCDTV32 32 in. Television
No Signal on HDMI setting
One night I turned the TV on and there was no signal showing for the HDMI setting. I re-wired it using the ypbpr setting and there is no problem. So my guess was the HDMI input on the TV went out. I tried a different receiver and it still didn't work which is what made me think it was on the TV end... Anyone else have this problem? The set is about 2 years old.
Yea, i have 3 cables actually, one of which is brand new, and i tried them all and still don't work...
i only have the 1 hdmi port...
Posted on Sep 15, 2008
Hey, i tired and it didn't work....
what else could it be?
Posted on Sep 12, 2008
  • 71 Answers
Sometimes the HDMI port can lock up.
Reset the TV. Unplug it, wait 1minute and replug it. Did it work?
Posted on Sep 11, 2008
  • Ignatz Saturation Sep 15, 2008
    Did you check if its the HDMI cable?
    Do you have other free HDMI ports, have you tried those, are they all busted too?
    Insignia products, a lot of problems.
    Spare parts maybe here:
How do I change the HDMI from 720 to 1080.
How do I get 1080 instead of 720. - Comcast Help and Support Forums
Jan 3, 2012 - I can switch one of them from one HDMI input to the other HDMI ... The YPbPr option might be set at 720p, and you can change that to 1080i.
How do I change the resolution on my LG tv to 1080p ? - Nvidia ... > Forum > Graphics Cards
Tom's Hardware Guide
Apr 20, 2012 - 7 posts - ‎4 authors
Hello, I have recently bout a new LG tv, and I use a HDMI cable with my sky HD box, but ... only shows 1080i resolution, and i cannot find where to change it to 1080p. ...Forum; Optimizing blu-ray settings for 720p Plasma tv? 1080p TV outputs 1080i from desktop - Radeon ...
May 24, 2012
Bravia Full HD won't show pc via HDMI on 1080p but ...
Oct 30, 2011
More results from
Change it: Your Comcast/Motorola HD Cable Box may be ...
Oct 20, 2012 - Change it: Your Comcast/Motorola HD Cable Box may be outputting ...they set it to output a 720p signal via the HDMI out to my 1080p-capable ...
How To Change your PS3 from 720 to 1080p - YouTube
Jan 03, 2016 | Televison & Video
Ypbpr no signal
Did you make sure you hooked a yellow end cable to the right jack as that is the one that controls the settings the others control the color and definition abilities
Jun 03, 2014 | Sanyo DP37647 37 in. LCD TV
Link ASUS laptop to Sharp Aquos LCD TV
No, a DVI to VGA adapter will not work. (The TV is looking for the digital signal from a set top box. This is different from the analog signal on the VGA cable.) You need a converter. Your best bet would be a VGA to component video converter. (I am assuming that the Sharp TV has a component video input.) This page has some examples: . Note a VGA to component video cable will not work. The VGA to component cables are for projectors that read the RGB signal. The component video signal is YPbPr.
Connect the VGA cable to the converter and the component video cable to the TV and the converter with the computer and TV off. Turn on the TV first and set it to the component video input and then turn on the computer. Then (assuming the VGA port is enabled - adjust in the BIOS if needed) set the computer's video output to the VGA port. (On my Windows 7 laptop, this can be done by right-clicking on the desktop. Choose Graphics Properties and set the display to the external monitor or both. Click Apply and then confirm the change (on the external monitor if using the single monitor). (VGA to Composite video converters also exist if you do not have an available component video input on your TV.)
If your computer is fairly new, you may have an HDMI port. Your TV may be able to read the signal with a DVI to HDMI cable. (It depends on the TV. Not all of them will read the computer's signal on the DVI port. Check the documentation for your model. TVs without a VGA port are less likely to support this feature.)
I hope this helps.
Nov 28, 2011 | Televison & Video
I cannot get the YPbPr to work on my TV. I have a PlayStation 3 hooked up to it yet it still will not show it on the TV. Now the Playstation WILL show up on HDMI, but also can be used with component...
If you are using component connection for your playstation, you need to change the resolution from 1080p to 720p on the system. It will not work otherwise.
Jul 06, 2011 | Bush Televison & Video
Tv turns on it says no signal and when hooked to dvd player no pic? cable is good and dvd player all works on a didffrent tv.
try different type inputs on your TV-
HDMI, component, composite
then look in the menu of your DVD player- with no disc in it- find "setup menu"
then find "video output format"- select the one you are using on the TV, the options will be
HDMI, YpBpr (component) , video out (composite)
Apr 12, 2011 | Sony KDS-50A2000 50" HDTV
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
The Insignia LCD tv shwos no signal?
Using the function button or source button on the remote switch to TV mode. that should do it.
Feb 23, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
32 in Astar LCD won't recognize input signal
Hello, According what you saying not recognize any iput. Then your main board is defective.
The HDMI and the YPbPr are the same connection according the main board build. Any other question please call 323-767-6030.
Jan 08, 2009 | Astar LTV-3201 32 in. LCD Television
Trying to make DVR work after 2-17-09
I have been able to record down converted HDTV shows on my Panasonic DMR-EH50 recorder directly to the unit's hard drive and/or directly to a blank DVD-R disc.
I do not know of any DTV converter box that can provide the proper codes to the Panasonic DMR-EH50 to allow recording and scheduling of shows using the unit's built in TV Guide menuing functions (the program recording codes are essentially VCR Plus codes in the USA and VCR Video codes in the UK, and this technology was previously owned by TV Guide/Gemstar but was purchased by Macrovision within the past couple of years.)
When the DMR-EH50 is hooked up to standard RG-59/U coaxial TV cable, the cable company provides the specific VCR Plus recording codes, as well as auto setting the time and date information required for the TV Guide recording schedule menus. The VCR Plus recording codes are sent via the cable company through the coaxial cable to the end consumer's recording device. Since Gemstar's VCR-Plus patents are now owned by Macrovision, I am not sure of how this works (or will work) for non-cable/non-satellite customers or if such codes will be made available by Macrovision to record shows when one receives HDTV signals (or down converted DTV signals) from an over-the-air antenna.
Though the DMR-EH50 recorder can only record at Standard Definition (SD) broadcast resolutions, I connect the DMR-EH50 to my High Definition TV using the three progressive scan YPBPR output cables and switch my HD-TV into the YPBPR mode when I want to watch shows from the DMR-EH50.
YPBPR are the analog video signals carried by three color coded component video cables. The green cable carries the Y signal; the blue cable carries the PB signal; and the red cable carries the PR signal. The added benefit of using the YPBPR hookup is that you can 'up convert' a standard DVD disc (non HD Blu-Ray disc) in progressive scan mode to somethin akin to 720p resolution using the DM-EH50 (or any other progressive scan DVD player) to get a better quality image on your HD-TV.
Visually speaking, the same appears to hold true for playback of programs recorded on the DMR-EH50's hard drive even though down converted via the DTV converter box, and when played back on an HD-TV using the YPBPR progressive scan cabling hookup.
I also been able to successfully record programs from the DTV converter box to the DMR-EH50 recorder in both 16:9 wide screen and 4:3 normal aspect ratios, but again only in Standard Definition quality.
For NTSC and PAL formats, the correct aspect ratios for any particular TV (the rectangular height and width of your output resolution for a TV screen) can usually be setup correctly for most any DTV converter box by going carefully through the menus on the converter box. Though the converted DTV often will yield 'better looking TV' than cable, it's certainly not high definition however, as the purpose of any DTV converter box is * not * to yield a High Definition digital TV signal but a lower quality Standard Definition signal for viewing on older SD-TVs.
We must remember that what is happening here is that (by NTSC USA standards), we are transcoding (i.e., down converting) an over the air 1920 x 1080p (progressive scan) High Definition digital broadcast signal, captured by your over the air antenna, back to a Standard Definition 720 x 480 resolution analog broadcast signal (the 720 x 480 resolution is a 4:3 aspect ratio.)
Hope this helps a little -
Greg Loveria
Conklin, NY USA
Jan 03, 2009 | Panasonic DMR-EH50 DVD Recorder
Samsung LTP326w
After few years of service with different TV providers I have problem with my TV. Last night my Samsung LTP326W just did the same think on HDMI connector and no mater what you do it will not turn HDMI video... it's connected to Verizon/Motorola DVR I called Verizon and they promptly replace DVR and HDMI cable but it didn't help at all, also sometimes when you power on/off I get message: The HD Content Protection of your display has been compromised Please use the YPBPR outputs for your HD connection...
When I switch to component cable it works just fine.
Feb 09, 2008 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
Insignia IS-LCDTV32 32 in. Television Logo
639 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
