Matshita DVD-RAM UJ-840S Problem
My Acer Notebook came standard with this burner and it worked fine for 2 years but now it reads professionally made cd's (like programs and music bought in stores) but it won't read copied discs. Not just music but data cd's too. That means every time a client gives me a disc to work from my notebook sees it as an empty disc. PLEASE HELP!!! I'm desperate! My Lenovo Y500 Notebook came standard with this burner and it worked fine for 1 years but now it reads professionally made cd's and DVD's (like programs and music bought in stores) but it won't read copied discs. Not just music but data cd's too. PLEASE HELP!!! I'm desperate!
    Scholar:
  • 55 Answers
CD drives work by reflecting a laser to a sensor, where the existance or absence of a reflected signal corresponds to a 1 or a 0 in the binary code.
Prefessional "pressed" CD have a much greater level of "contrast" between 1 and 0, while CD-Rs have a lower contrast and CD-RWs lower still. This is why many older CD players that were not designed to read CD-Rs will either not read writable disks, or will read only CD-Rs and not CD-RWs.
Since you are able to read "high contrast" CDs but not lower contrast CD-Rs, it sounds as though your drive is getting a poorer signal than it did when it was new. This could be:
The laser is old and fading out.
The system is mis-aligned.
The lens is dirty and the signal is not all passing through to be detected.
You can't do much about the first two, other than buying a new drive (you could get a replacement internal one, or an external USB CD drive). However, before you do that, try very carefully cleaning the lens. A laptop CD drive usually has a try with the lens mounting in it which spits out with the CD, so you could either clean it manually with a little rubbing alcohol (isoproyl alcohol), or meths on a cotton-wool bud, or preferably get a lens-cleaning CD and run that in the drive.
Hope it works!
Posted on Sep 12, 2008
Busco matshita dvd-ram uj-840s driver para el windows xp. Alguien me puede ayudar? No lo encuentro en ninguna pagina. En la pagina oficial solamente existe para el windows 2000. Gracias.
Not sure of your question; I read only English.
There are many sources for the drivers for your DVD; many would liek you to downlaod and use their driver update programs. An advantage is if there is ever an additional update the program will let you know. Here are two examples that you might consider as sources for an updated driver:
http://driver-helper.org/matshita-drivers/matshita5/matshita-dvd-ram-uj-840s-ata-device-driver-download/
http://www.driverboost.com/lp/drivers/update/Matshita-System-Drivers.php
Dec 28, 2010 | HP Computers & Internet
ASUS M51SN Matshita BD UJ-120 burner does not work - Windows 7
You need to install windows 7 (32 bit) not 64. To change to 64 you have to make internal changes and updates to your notebook. Your notebook is set up for 32 bit systems.
May 19, 2010 | ASUS M51Sn-C1 Notebook
System not reading my matshita dvd ram uj - 850s ata device
If you are using genuine microsoft OS the download the Microsoft User-mode Driver Framework Feature Pack1.0.0 (Pre-release5348) from microsoft corporation or from CNET driver update tracker....sodeep
Mar 17, 2009 | Acer Aspire 5100 Notebook
Drive cant write any disc
If the unit was working ok and suddenly the unit stop to read the blank disk, the problem could be related to a dirty lector (need to clean) or unit firmware (need to be updated)
In that case you can update your firmware here:
http://drivers.softpedia.com/progDownload/Matsushita-DVD-RAM-UJ-840S-104-Download-14615.html
Remember
1) You have to use a blank "recordable disk" to allow your drive write a disk
2) Not all disks are compatible
3) Try differents brand
4) Clean your drive lector
5) Update your firmware
Oct 24, 2008 | HP Compaq nx6310 Notebook
Is your DVD/RW. you may only have the dvd that can read disk. have you ever burn cd or dvd on this dvd rom.
To burn dvd you have to have the software.This does not come with the dvd. you have to buy one on your own
good luck
Jul 18, 2008 | Toshiba Satellite A105 Notebook
MY DVD DRIVE CAN NOT SEE VCD AND DVD THAT NEVER WRITE THEN CAN NOT WRITE ALL DISE BUT IT CAN READ VCD&DVD THAT EVER WRITTEN
you need to install a third party VCD viewer software...
some operating system doesn't come with VCD viewer.
when you look for a software you should keep in mind that you need a software that will support your dvd drive also.
Jun 03, 2008 | Computers & Internet
My Matsita DVD Rom wont play any discs at all.. I just bought a new printer and i can't even install it b/c it came with a cd..... I am going to buy a new drive for this.
Mar 22, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
MATSHITA DVD-RAM UJ 85JS problem
I have mashita DVD-ram UJ 850s in acer aspire 3100 that wont play vide while it only plays sound
Mar 05, 2008 | Toshiba Style Bay DVD-RAM Drive Kit...
Computers & Internet Logo
240 people viewed this question
David Payne
David Payne
