Question about Sharp Televison & Video
My Sharp DV-A1000 eject disc - Sharp Televison & Video
SOURCE: Sharp DVD disc error
I've found out that the recording speed is important for this model. The speed on the dvd must be 4x or less. If your using an 8x or 16x it will not work. Hope this helps.
Maybe you can help me. I'm looking for the 4 digit code that goes into the remote to make it compatible. I think it's in the operators manual, which I no longer have. If you can find this number I would really appreciate it.
Posted on Dec 18, 2007
Panasonic dvd video camcorder VDR-M55PP
system malfunction, put a soft reset on the camcorder.
Feb 24, 2008 | Panasonic NV-DS65 Mini DV Digital...
Sharp dvd codes
Of all the things, Google found the following in a Bulgarian text file..
Sharp DV-SL1500W
- switch on DVD player
- press eject (tray open)
- press stop
- press 734466
select 0 on OSD for region free
Aug 12, 2009 | Sharp DV-SL1500W DVD Player
Sharp ux a1000. I need to clear the memory. Can
Just unplug the machine.
When the power supply is interrupted (intentionally or due to power failure) the memory is cleared.
Download the manual from here:
http://www.sharpusa.com/files/fax_man_UXA1000.pdf
Aug 09, 2009 | Sharp INKJET FAX UX-A1000
Region Code crack
sure here ya go
- press stop
- press 734466
Mar 28, 2009 | Sharp DV-SL1500W DVD Player
How do I set the player to multi region for a Sharp DV-SL1500W ?
try this
- press stop
- press 734466
Mar 18, 2009 | Sharp DV-SL1500W DVD Player
Sharp DV-RW340U will not record new dvds, give error message :E24
ensure you are using DVD-R not DVD+R discs. if what you are attempting the record is copyright protected, depending on the protection, you may not be able to record.
Feb 08, 2009 | Sharp DV-RW340U DVD Recorder/VCR
Sharp Ux A1000
On the bottom there will be a tiny hole which might say reset Press it with a pen or somthing sharp/pointy
Or ring (02) 4321 0080* and they will give you an answer free!
*May Be STD call
Jan 28, 2008 | Sharp INKJET FAX UX-A1000
Oct 12, 2007 | Sharp DV-RW340U DVD Recorder/VCR
Standby
If both decks have a disc or tape in it , the unit shut down because of a power supply glitch or a mechanical trouble shut down the system control system. One way to possibly get them out is unplug unit for a few hours or overnight even better. Before you plug back in press the eject button and hold it in while you plug it in. Dont let go untill the tape comes out. Now if it comes out then unplug the unit anf replug back in and wait a few secs. to let it reset and do its thing. then see if it will turn on and try to eject the disc. if this dosent work then its a power supply problem and its going to need serviceing unless you know your way aroundservo controls and power supplys . Remeber always unplug these units as they do have voltages on the primary side of the transformer that can bite ya. Good Luck
Jun 05, 2006 | Sharp DV-RW340U DVD Recorder/VCR
Televison & Video Logo
91 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
