Question about Panasonic CT-27G23 27" TV
Fixing horizontal line problem
I'h happy you told me the problem, now if you could provide how to fix it I would be greatly happy. Thanks.
  • Jonathan Whitehead Apr 23, 2006
    Also does hitting the TV in anyway do anything? LIke say if I were to hit it on the side a little bit hard, could that do something to the horizontal line problem, or the vert sweep?
    President:
  • 3,130 Answers
If hitting the set gets the vert to come back then you have bad solder connections on the vert. outputs.. If it dosent then your gonna need to measure the voltage first on the vert output IC see if its about 24 or so volts If it is replace the IC. If its not the replace the vert B+ drive capacitor off the flyback xformer. If you cant find these things then your gonna need to get a schemtic from sams photo facts and post the vertical section and I will tell you or assist youin this repair. If you have had experience in soldering and curcuit work your already ahead in the repair. post the schematic.
Posted on Apr 23, 2006
Horizontal lines on LG TV
I hate to give you bad news but about 90% of the time horizontal lines come from a bad panel and if that's the case the set isn't worth fixing as a panel costs hundreds of dollars
Mar 24, 2018 | LG Televison & Video
My Dell XPS 9530 has a white vertical line on the display
Fixing this old of a TV would be a waste of money as unless you have the testing gear and expertise you would be guessing. Just buy new and be happy. You could also join a book club and give up watching TV altogether. LOL
Aug 21, 2016 | Televison & Video
Green Horizontal lines on screen comes and goes RCA L32HD31
I think some problem in the IC of hori./ vertical.circuit.This could fixed in service center
Aug 01, 2017 | RCA Televison & Video
The sound is great, but the picture has gone to gray with horizontal white lines across the screen. It is 20 years old, and probably not worth fixing, but i will ask anyway, just in case it is a simple...
Hello Sat, hi, its a failure of the horizontal output transistor responsible for high voltage. This transistor is needed to be replaced. you need a TV tech guy to have this fixed. have it checked first, the trouble is common to CRT type TV really easy to fix. for a tech guy.
Dec 07, 2010 | RCA Televison & Video
SEVERAL BLACK HORIZONTAL LINES ON COPIES
You need to locate the source of strikes.
1) remove toner crg., if it has black lines or dirts on drum replace drum.
2) check/clean copy glass
3) use flash light to check fixing section ( Left sideway of copier small doors ) if damadged replace fixing assy.
Jun 30, 2010 | Canon imageCLASS D320 Digital Copier
Horizontal lines in the picture.
Give it time to warm up like another 10 to 15 mins i find put a tv guide channel on the screen stays pretty much the same picture, then leave the TV on" i use a 4 hour rule if i dont view in 4 hours or more i will close tv power
Oct 07, 2009 | Mitsubishi VS-60705 60" Rear Projection...
Monitor has many horizontal lines flashing across the screen
Yes your monitor can be fixed by an electronical expert! Is not so big problem but you can do nothing without an expert! The fixing-cost is not much! Is just sync problem! If this help you, rate me! Thx.
Apr 25, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Permanent horizontal black lines on my 50
Ive got bad news for you, about 90% of the time black horizontal lines are caused by the panel failing, your going to need a new TV. You can try replacing the timing board but the chances of it fixing it are slim..
Jan 06, 2018 | Panasonic TH-50PX60U 50 in. Plasma HDTV
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Panasonic CT-27G23 27" TV Logo
82 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
