Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Cable connector broke off of the television. - RCA D52W20 52" Rear Projection HDTV-Ready Television
    Scholar:
  • 195 Answers
Ha Ha, this problem is common with most televisions that have repeatedly been unhooked and rehooked to cable. some use pliers and tighten too tight till it snaps off, or just plain step on the cable while connected. Chances are you already have the solution already hooked up. If you have a VCR or DVD that is capable of searching tv channels, just hook that up to your TV with the yellow red and white cables to the Input jacks on the back of your tv, either in the Comp 1 or
Video input jacks. You can still adjust your screen size etc, with your original tv remote, but you will have to channel search with the VCR or DVD remote. (Snicker Snicker)
Posted on Oct 28, 2008
  • 374 Answers
You can by an RFmodulator and a set of composite cables to get the cable signal into the tv provided you have audio and video inputs. You will then need to tune tv to the proper input to view.
Hope this helps you.
Posted on Sep 11, 2008
The antenna connection broke off
If the cracked portion is on the cable then you need to get the cable recrimpted with another connector. You can do this yourself but this needs a special tool. Ask your cable provider to get the proper connector reapplied.
Dec 28, 2013 | Sanyo DP32649 31.5 in. TV
You should be able to get a replacement Small signal board from www.tvrepairworld.com
Nov 15, 2011 | RCA HD52W59 HDTV Projection Television
Cable connector broke off in back of tv
had same problem virtually impossible fix if broke off if you have rca plugs use vcr thats what i did!
Jun 30, 2009 | Televison & Video
The female cable connector on the back of the tv broke off
yes,you could also use RCA cords from the cable box to the tv and bypass that by selecting the video channel that you hook the rca's to
Jun 02, 2009 | RCA TruFlat 27F520T 27" TV
Cable connection broke off while unscrewing cable wire
The unit may be repairable depending the damage done to the input circuit that the connector was connected to. The board can probably be replaced if not repaired. You can call Polaroids customer support at this telephone number. 1-866-289-5168. Give them the model number of your television and the problem you had with the cable connector coming off inside the television.They should be able to tell you how your can get the unit repaired. I hope this information helps you with your problem.
May 04, 2009 | Polaroid FLM-3732 Television
Cable connection in rear of TV broke off.
This problem will have to be taken or shipped in to a service center for repair or replacement of the cable connector on the main board. The telephone number for Insignia customer support is 1-877-467-4289. and the website is www.insignia-products.com. You can also call the Best Buy customer support telephone number. 1-888-237-8289. Give them you make and model number of television and the problem you had with the broken cable connection.They will be able to tell you how you can get service for your television. I hope this information helps you with your problem.
May 02, 2009 | Insignia IS-LCDTV32 32 in. Television
In ANT connector broke off
If you have cablebox, use RCA cable(composit) or componentcable to hook up. you will see better picture than repairing connector back on.
Mar 25, 2009 | iLO 3200 32 in. LCD Television
Main cable connector broke off back of TV
Maybe so. Sometimes the connector is fed by an RCA connector which just plugs in inside the TV and sometimes it needs a little solder work. Sometimes you have to solder on the circuit board and if it's a multi-layer board you want an expert to do it but from the manual it doesn't look like that is the case with your TV.
I'm pretty sure Radio Shack stocks such connectors with maybe a little hardware to get the fit right.
Dec 17, 2008 | Televison & Video
The cable connector broke off the back of the tv
If you need to hook up to the barrel connector for cable or sat. you can use a converter box(Radio Shack) or VCR which both have a cable connection and then send it out component or Svideo.
Aug 18, 2008 | Televison & Video
Cable connection on 42'' VIZIO
use neddle nose or dental tools ok thx nick
Feb 08, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
186 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
