Question about Lexmark Office Equipment & Supplies
My lexmark X1200 just quit. All simple solutions failed so I uninstalled program and downloaded the most recent updated program and it is downloaded to my files. When I try to install, it only takes me to the point where I have to re-connect my cables...at that point my only option is to cancel...will not let me continue. Is this related to the printer spooler?
  • 3 more comments
  • lynnjudy Sep 11, 2008
    Your solution says to unplug printer...do you mean the UBS cable or electrical outlets? Also says to restart spools...don't know how to do this. lynnjudy
  • lynnjudy Sep 12, 2008
    My lexmark X1270 just quit...says there is no communication between computer and printer....have downloaded most recent X1270 program and it won't go in....suggestion to unplug printer and restart spools....my question is unplug the UBS port cable or electrical outlet plug and how to you restart spools. lynnjudy
    Went into my computer and found spooler and made sure it was turned on...then tried to install print program...no luck..will take me up to point where I have to connect UBS port and will not highlight the continue button...only the cancel. I still have no printer!!! lynnjudy
  • lynnjudy Sep 13, 2008
    I replaced my UBS cable and can get no further on installing the program. Went into device manager and found not one single mention of a printer or anything remotely connected to a printer. Next I'm going to try to find someone (computer geek?) who can tell me if my printer is shot. Will keep you informed. lynnjudy
  • lynnjudy Sep 18, 2008
    The power source for the Lexmark quit and repair costs would probably have cost more than a new printer so we bought a new hp printer and have it installed and are ready to go. Thank you for your help...learned a lot about my computer from your suggestions.
  • Lexmark Master
  • 1,879 Answers
Goes up to the point where the installer asks you to connect the USB cable and it's not detecting the printer.
Cancel installation.
Make sure printer is connected directly to the computer, no USB hubs.
Go to Device Manager and look for Universal Serial Bus Controllers, expand.
All USB printers when connected to a Windows machine, the operating system loads "USB Printing Support". Look for that entry. If none is found, means no physical connection. Either the computers USB port or the printers port or the USB cable. Hot swap cables & ports.
However if it shows but with an exclamation mark or a red X , do right-click on it and uninstall then disconnect printer + reboot computer. On boot perform normal driver installation.
Try connecting the printer to another computer, just do the steps above to verify what equipment works.
Posted on Sep 12, 2008
  • 928 Answers
There is a simple test that you can do for your printer.
1. Connect the USB cable and power make sure that it is powered on.
2. Click start then run then type in devmgmt.msc
3. That will take you to the device manager.
4. See if you can detect your printer there. If it is not there or nothing there has a question mark or exclamation point then your printer unfortunately is toast.
Given that your USB cable is working properly by the way.
    President:
  • 1,952 Answers
A print spooler is software that temporarily stores print jobs on the computer hard disk or in memory until the printer is ready to print them. If you have been waiting an unusually long time for a document to print, or if you see an error message about the print spooler, spooler subsystem, or spooler resources, you might need to change and then restart the Print Spooler service on your computer.
To do this, we recommend that you save your work, and then restart the computer to restart the Print Spooler service. If you don not want to restart the computer, try these steps instead.
To change or restart the Print Spooler service and Printer Repair You must be logged on as an administrator to perform these steps.
1. Open Administrative Tools by clicking the Start button Picture of the Start button, clicking Control Panel, clicking System and Maintenance, and then clicking Administrative Tools.
2. Double-click Services. Administrator permission required If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
3. Right-click the Print Spooler service, and then click Properties.
4. On the General tab, next to Startup type, make sure that Automatic is selected.
5. If the service is not already running, under Service status, click Start, and then click OK. Administrator permission required If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Posted on Sep 11, 2008
    Sergeant:
  • 264 Answers
Is it getting detected on the usb
  • Sameer Kashyap Sep 11, 2008
    Print spooler is not in the picture at the moment. First make sure that the printer is getting detected by windows as soon as you plug it the USB Port.
    If Yes than you need to have the printed unplugged while installing the software and you need to plug it in when you reach the screen you mentioned.
    Also you may try to restore your system to a previous date, when the printer was working fine.
    It should help.
    Also check your USB cable
    Genius:
  • 1,142 Answers
You need to make sure that the printer in unplugged before you begin installing the drivers...
also restart the spooler service
Fax solutions software stopped working
Uninstall the Lexmark software including the Fax Solutions. Download an updated driver online at www.lexmark.com and install the updated driver. Once you have installed the updated driver, insert the installation CD to install the OCR and Fax Solutions.
Jun 10, 2012 | Lexmark Prospect Pro205 Wireless...
Printer write as javascipt
I presume you are using the Lexmark X1270 inkjet printer since you're posting under this model.
It could be that the printer driver on your computer is not properly installed. Try to uninstall your existing printer driver then reinstall using the X1270 driver on the Lexmark website. To uninstall, from your computer, go to Start menu > Programs > Lexmark X1200 Series folder > Tools > Uninstall. After the uninstall process, reboot your pc when prompted.
When the computer turns on, please visit the Lexmark website to download and install the Lexmark X1270 XP Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
Try to print your document again to verify that the problem is fixed now.
Nov 22, 2011 | Lexmark X1270 All-In-One InkJet Printer
I have tried to download the driver for my lexmark x1240 all-in-one printer to my dell windows 7 laptop and cannot download it without an error please help
Try this approach. First, uninstall the existing Lexmark X1240 printer driver from your pc.
  1. On your computer, go to Start.
  2. Go to Programs.
  3. Go to Lexmark X1200 Series folder.
  4. Go to Tools.
  5. Uninstall.
When your pc turns on, check your system if it's running on 32-bit or 64-bit. Go to Start > right-click on Computer > click on Properties. Take note of the System Type.
Use the link below and download the file that corresponds to your system type:
- Lexmark X1240 Printer Driver for Windows 7 32-bit - Lexmark X1240 Printer Driver for Windows 7 64-bit
Execute the file. Simply follow the instructions on your computer screen to complete the installation.
I hope this helps.
Oct 27, 2011 | Lexmark X1270 All-In-One InkJet Printer
Cannot connect lexmark 1200 all in one printer to dell laptop windows 7
Please visit the Lexmark website to download and install the printer driver on your laptop. First, check if your Windows 7 is running on 32-bit or 64-bit operating system. Follow the steps below:
  1. On your computer, go to Start menu.
  2. Right-click on Computer.
  3. Click on Properties.
  4. Take note of the System Type.
Click on link below to download and install Lexmark X1200 Series Printer Driver: - Lexmark X1200 Series Driver for Microsoft Windows 7 32-bit - Lexmark X1200 Series Driver for Microsoft Windows 7 64-bit
Aug 14, 2011 | Lexmark X1270 All-In-One InkJet Printer
I do not have a dice for my lexmark x1200 series how do i get it on to my computer
Visit the Lexmark website to download the Lexmark X1200 series driver for free. Click on this link Select a Lexmark Product. Then type the model number of your Lexmark printer (e.g. Lexmark X1250, Lexmark X1270 or Lexmark X1290) and hit SELECT. Choose your version of your computer's operating system on the next page, then hit FILTER. Click on the Complete Driver under Recommended Downloads. Download, execute the file and follow the instructions on the software. NOTE: The Lexmark X1200 Series is only supported on Windows operating system.
Dec 29, 2010 | Lexmark All-in-One Printer with PictBridge
Can't reinstall my Lexmark printer
Usually, that can easily be resolved by uninstalling the printer completely, then reinstalling it. To uninstall properly, click on the Windows logo Start menu > Programs > Lexmark 6500 Series folder > Tools > Uninstall. Then restart pc. To reinstall, you can use the installation cd or if you don't have it or you lost it and since you have dial-up which is slow in terms of downloading, you can contact Lexmark Technical Support for assistance. They'll be able to send you one for free. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 12, 2010 | Lexmark X6570 InkJet Printer
Cannot uninstall Lexmark Fax Solution.
Go to www.download.com put in Revo uninstaller in the search box. select the program for download and download it. Run the program. The window will come up and show all installations on the computer. Pick the program you want to get rid of. select program and click uninstall in the header, the program will initiate the programs own self installer first, when it is done or if it fails, Revo will continue with the uninstall. Make sure to choose option (4) when prompted with the type of removal you need. if prompted to restart windows after the uninstall, ignore and continue with the Revo program. Click next when it is highlighted by Revo and select all when prompted to delete files. Revo will prompt you when it has finished, just say yes to all files to delete.
Sep 09, 2009 | Lexmark X2550 All-In-One Printer
Lexmark 1270 all-in-one
Explanation
A clicking noise from the scanner is probably caused by the driver for the scanner.
Resolution
1.
Download the latest driver from www.lexmark.com.
2.
Once the driver is installed, power the printer off and back on again.
Additional information
The original driver CD for the X1200 printers had part number 17M4160, and some early X1200s were shipped with this driver CD. When the X1200 was manufactured with a new scanbar, the updated driver CD became part number (PN) 17M4360. The updated CD should have been included in the box of new products being shipped. If the X1200 is making a "clicking noise" when you try to scan and the CD PN 17M4160 was installed, you need to download and install the web driver which supports ALL the X1200 printers. NOTE: The X1200 driver CD PN 17M4360 works with ALL X1200s also.
to download the drivers::
link::;http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+X1270
Mar 10, 2008 | Lexmark X1270 All-In-One InkJet Printer
60 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
