Question about Dryers
I want to know how to remove the lint trap (not just the screen but the entire assembly) from a Maytag Performa PYET344AZW front loading electric dryer. The lint screen will not even properly slide back into place because there is so much lint within the plastic frame (and probably in the ducts and everywhere else too!).
  • 1 more comment
  • jnrobinson Sep 11, 2008
    Thanks, but I know how to clean out the lint screen and the vent (and the tubing in between as well). My concern here is how to remove the piece of plastic that houses the lint screen...this assembly is FULL of lint behind the screen, and presumeably in between the dryer drum and the outer body, where ever it is that the air goes before venting out the back of the dryer into the piping. Any thoughts on how to clean out this area?
  • fcfay65757 Nov 22, 2008
    I saw my repairman remove the outer shell of the dryer once, and remove
    a sack full of lint from inside the body of the dryer. I have a Performa model PYE/G2000. Can you tell me how I get the outer shell off to do this?
  • kris88 Feb 02, 2009
    Yes! I have the same issue with lint getting stuck between the screen and the panel that hold the screen in place. My dryer takes forever to dry but does run and has enough heat to dry the clothes eventually, usually an hour and at times longer. I have lint everywhere but it seems to becoming from under the dryer and not from the connection or tubing to the outside vent.Stupid question, is it ok to vacuum the lint using a soft brush attachment when I get the panels off? Or is there some sort of magical tool I should using? Just concerned the vacuum may be too strong and might disconnect something.
    Genius:
  • 1,239 Answers
Besides drying clothes, dryers also remove lint. This fine, fuzzy material can cause trouble because it blocks dryer lint traps, clogs vents, and fills blowers. Lint can also gather around and in the tracks of the drum rollers, or in and under the pulleys and the drive belt. The result is poor clothes drying or -- sometimes -- no drying. To avoid lint problems, clean out the dryer's lint trap system every time you use the dryer.
To clean the lint screen, remove it from the unit. The screen may be located near or under the door sill, or in the top of the dryer near the control panel. It can usually be removed by pulling it up and out of its housing. Remove the accumulated lint to clear the screen; then replace the screen.
The exhaust vent also collects lint. Vent maintenance involves cleaning the lint from a screen in the dryer's vent exhaust collar and/or at the end of the exhaust vent where it sticks out through a basement window or through an exterior wall. To clean the screen, remove the clamp that holds the vent to the collar, or back out the screws that hold the vent to the collar, or pull the vent straight off an extended collar. Clean the screen thoroughly and replace it in the vent assembly.
To clean the vent itself, use a vent-cleaning brush (available at hardware stores) to pull out any lint deposits. Also check the vent run to make sure that the vent piping or tubing isn't loose at the joints, or -- in the case of flexible plastic venting -- isn't sagging between hanging brackets. Breaks or sags cause undue strain on the dryer's blower system, and can cause drying problems. If the vent pipe or tubing has become clogged with lint, remove the lint by pushing a garden hose or a drain-and-trap auger through the vent to a convenient joint. Disassemble the joint to remove the debris. With this procedure, it isn't necessary to disassemble the entire vent to find the blockage.You can head off problems before they become too serious by providing routine maintenance for your dryer's door gasket, thermostat, timer, and other frequently used parts. Let's discuss how to service these important components in the next section.
I want to know how - how-to-repair-a-dryer-1.jpgTHANK U.. RATE IT...
Posted on Sep 11, 2008
Bra stuck in lint trap housing on samsung front load dryer
You might need to remove the lint trap or the drum assembly.
Please check this video for tips
Click on Lint trap
Removing drum assembly
Jan 22, 2013 | Samsung WF337AA Front Load Washer
How do you wire the dryer MDE300AYW
Instructions
    • 1 Remove the lint screen from the dryer. If you are unsure how to remove the lint trap, refer to your owner's manual, as removal directions vary among Maytag models.
    • 2 Use your fingers to remove large chunks of lint from the lint screen. You should remove the lint from the lint trap after every load.
    • 3 Run the lint screen under the faucet. Use hot water and thoroughly wet down both sides.
    • 4 Scrub both sides of the lint screen with a wet nylon scrub brush. Rinse the screen again under hot water to remove loosened buildup. Allow the lint screen to air-dry on a towel before putting it back inside of the dryer.
    • 5 Make a paste of powdered laundry soap and warm water into a small bowl. Use three parts powdered detergent to one part water. Stir with a spoon until a paste forms.
    • 6 Dip a soft rag into the paste. Wipe down the entire interior of the dirty Maytag dryer with the rag and paste. Apply more paste to the cloth as needed.
    • 7 Rinse the interior of the dryer with a damp rag to remove the paste.
    • 8 Dry a load of damp towels in the Maytag dryer. Run a complete dry cycle to remove any residue left inside.
    • 9 Wipe down the exterior of the dryer with a rag moistened with all-purpose household cleaner. You can also use the household cleaner to remove certain stains from the interior of the dryer. Make sure the cleaner you are using is noninflammable.
Jan 15, 2013 | Maytag Dryers
My husbands wedding ring fell into the lint trap of our Maytag front loading dryer. Anyone know how we can get it out?
You can remove the lint filter to retrieve the RING, please do not put the machine to any wash until the filter and drain pump is removed and checked.
check this link.; Cleaning lint filter
Jan 01, 2013 | Maytag MDE9700AYW Neptune 174 Electric...
Lint problem
Yes, check filter assembly is not blocked.
Mar 25, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag performa Keeps blowing Thermal Fuse. Vents are clean. Cleaned entire system. Seems to heat up as soon as dryer cuts off.Changed control thermostat as well. Can get one load and replace fuse.
something is still plugged with lint,if the vent line is long blow it out with a leaf blower to clean it out,you have to clean out the duct that the lint filter slides into,if the filter is on top remove the vent line,remove the back panel,remove the lint filter and the two screws in front of it and remove the four screws and clean out the duct,if the filter is in front take off the bottom panel,remove the filter and clean the duct,also vac out the inside of dryer where the motor is,when the dryer gets to hot the thermal fuse pops as a safety so you still have a block somewhere
Mar 19, 2010 | Maytag PYE2300AY Electric Dryer
I need to know thermostat location on maytag performa dryer
The operating thermostat is located on the blower housing behind the front panel, however the thermal fuse/hi-limits are located below the top attached to the heater box. They are more often the culprit as is the element in those units.. Check the exhaust path from the lint screen out to ensure a clear 4" path the entire length, as blocked ducting will raise internal temperatures and also cause those components to fail..
Have fun, and best of luck,
Thanks,
Chuck
Feb 22, 2010 | Maytag PYE2300AY Electric Dryer
How do I remove the lint trap holder. I have lint
you have to remove the top then the control pannel then the entire front. are you ready for this?
Jan 08, 2010 | GE Washing Machines
Maytag electric dryer is drying inconsistently.
you may need to check the lint trap and clean it .. also try cleaning out the dryer vent... if this doesnt work , try changing the drine belt...
good luck
Oct 12, 2009 | Dryers
It is taking 3 full cycles to dry my small loads on my Maytag Performa PYE2300AYW. I have cleaned lint tray and trap. I need to clean the lint from the inside of my dryer - How do I do this?
The main area that you have to clean is the pipe leading from the back of your dryer to outdoors. Pull your dryer away from the wall. Unplug it. Unfasten the vent pipe. Now look into the back of the dryer exhaust and remove any lint you see there then look into the vent pipe and remove any lint. Finally go outdoors and remove any lint you see in the pipe or the pipe grill/cover.
Jun 04, 2009 | Maytag PYE2300AY Electric Dryer
Dryer Lint Trap Not Catchin Lint
If you have the ability to move your dryer away from the wall and look at the hose located at the bottom of the unit.
1. Take the house off it might be clogged 2. check for ang gaping holes in the lint screen
Jan 19, 2009 | Maytag Performa PAV3200
Dryers Logo
926 people viewed this question
Top Dryers Experts
