Question about Photography
Pentax Asahi SP1000
At the bottom of the camera where the battery goes, I have lost the "Open Battery" part. Where can I get a replacement?
Go to, old phone number 1-800-872-0155 to order battery cover. Is yours a screw-in or 1/4 turn cover. I have machined covers from aluminum bar stock. much too expensive. Or buy parts body on ebay. Regards, Ken
Posted on Sep 12, 2008
Asahi Pentax Spotmatic SP jammed shutter
Have the film come to the end of the roll and the camera will not fire, if so rewind the film. Sorry, a shutter is not a self service item. This should be sent in for a CLA.
Nov 04, 2013 | Pentax Asahi Spotmatic Sp 35mm Film Slr...
Background, Pentax 110 camera
You may download the manuals from here. The specifications are contained in the manuals. You'll find more about the Pentax 110 system here.
Oct 18, 2012 | Pentax Asahi Auto 110, SLR Camera Kit
I am trying to find the value of my 35mm asahi pentax camera by the serial number. is there a site I could go to, to get this info?
Asahi Pentax 35mm cameras are not valuable....most can be purchased on ebay and other similar sites for under $100.
Aug 20, 2011 | Pentax Cameras
Asahi Pentex SP Spotmatic, need bottomplate with battery door treded.
Hi, You are goi8ng to have to find repair shop with pentax parts in order to get this fixed. You can sometime find the parts on eBay - but you have to be lucky.
Mar 13, 2011 | Pentax Cameras
I have an old Pentax ASAHI 35mm SP camera. It reads SPOTMATIC on the front. I can't see through the view finder. Any suggestions?
Remove the lens and look into the throat of the camera. The mirror should be resting at a 45 degree angle, but if it's fully or partially stuck upwards then the mirror has locked up.
There were a number of Spotmatic models made between 1964 and 1976, all were fully manual and mechanically operated so the battery was used only to power the light meter. This is important, as on later models the battery also powered the shutter and a flat battery would cause mirror lock up. On your model (either an SP500 or an SP1000), the lock up is either due to an internal breakage or simply due to dried out lubricants which may have been in there for around 40 years now. Fixing your camera requires professional attention; if you're lucky then the camera just needs a CLA service (Clean Lubricate Adjust), new light seals and possibly a battery recalibration (original mercury batteries are no longer available, modern "equivalents" have a different voltage). If this is done your camera can give many more years of service, but the costs will far outweigh the value of the camera. Millions of Spotmatics were made, and the only ones of value to collectors must be immaculate and fully complete and functional. If your camera needs spare parts then they simply aren't available except by cannibalising parts from others. Given that there are plenty of more recent, fully functional 35mm SLR camera outfits available for free on FreeCycle and Freegle you really need to appraise whether to sell your near-worthless camera for spares or to make an investment in repairing it. One benefit of your model is that it accepts the older M42 screw mount lenses and there are millions of them going for between zilch and peanuts.
Aug 16, 2010 | Pentax K1000 35mm SLR Camera
I have an old Asahi Pentax, release lever and shutter are stuck.
The Pentax is a easy fix, maybe.. If you feel comfortable removing the bottom cover, then remove the 3 cross point screws. The battery, if installed will be loose. Looking at the bottom section of the camera, locate the tripod socket. On on side is the battery compartment, the other an L shaped lever. Under the L shaped lever is a brass plate with a slot in it. In that slot is another lever that has a spring going through the end eyelet. Move that lever toward the front of the camera until it latches on the L shaped lever above. Then try the release.
The first thing to try on the X700 is fresh batteries. Clean the battery cap and contacts with a pencil eraser.
Jan 04, 2010 | Pentax K1000 35mm SLR Camera
I have a Asahi Pentax like this one: Old one. I was ''taking pictures'', you know, just using the lever and the button without really using a...
Sounds like your mirror has locked in the up position. Could be several things. These cameras did take a battery -- usually located on the bottom plate -- looks like a slot for a very large screwdriver -- use a coin instead, to unscrew. Inspect battery and housing, remove any corrosion with brush, match battery and replace. May have to go to camera shop for battery, or try online. If new battery does not release mirror, suggest unloading film in darkness, rewinding into cassette leaving loading tongue so can access it to reload or for developing. Then very gently try to release mirror from inside camera body and check for dust/dirt/etc. with camel's hair brush. Try operation of camera without film -- shutter, film advance lever, etc. and see if this helps.
Oct 24, 2009 | Pentax ME Super 35mm SLR Camera
Could someone please tell me what battery is used for the Pentax ESPIO 738S shoot and point camera. I picked it up second hand and it has no manual or accessories. As far as i can tell it needs a lithium battery but i don't know which one or what size. Also if you know of anywhere i can get an electronic copy of the user manual that would be handy aswell.
Thanks for helping with my dilemma.
Jul 05, 2008 | Photography
Shutter release
Hi , to release the shutter open the lense and push shutter button , rotate the camera mode to auto or manual release shutter.donnot set on bulb or lower speed can cause stuck camera miror and stter curtain, or blade.
Feb 19, 2008 | Photography
My rapid wind lever will not work, i have a Asahi Pentax camera, 35mm, full fram SLR
If you are handy with tools I can tell you what to try first. This involves removing the bottom cover on the camera (4 screws)
Feb 15, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Photography Logo
136 people viewed this question
Top Photography Experts
Are you a Photography Expert? Answer questions, earn points and help others
