Question about RCA 32V550T 32" TV
Remote Control wont Work
After cleaning fingerprints off the top control panel of the TV, the remote control immediately stopped working on the TV (no on/off, channel changing, nothing). The indicator light on the remote lights up so I know its working. I replaced the batteries and did all the troubleshooting, I even replaced the remote with a universal. I must have hit something on the control panel to stop the remote from working. Help.
  • Nancy Eichenlaub Apr 23, 2006
    I didn't use any cleaning solution, just a rag. Thanks anyway.
    President:
  • 3,130 Answers
Did you spray the cleaning solution right onto the control panel?? Well if you did you may have shorted out your remote sensor eye. If irt dosent dry out in a few days then your gonna need a new one. Go to http://partstore.com and they will assist you finding what you need. Good luck
Posted on Apr 23, 2006
My palsonic tv remote wont work even with new batteries:(
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
https://youtu.be/wUpnETSm6_k
Sep 12, 2016 | Televison & Video
Devant remote control wont work. it red light is always lit and wont stop. if i press STILL. freeze on or freeze off will appear on the TV but nothing happends.
May 12, 2016 | Televison & Video
My RCA LCD 42" TV control buttons on the television wont work, and the only button that will work on the remote is the power on/off button.
Feb 24, 2016 | RCA 42LA45RQ 42 in. LCD TV
Need to search for channels but the menu button on my remote or tv wont work
Jan 15, 2016 | AOC L19W89V 19 in TV
My Sharp Aquos 60" remote control stops working after a couple of minutes.
Search the site by type in this key phrase "how to test a remote control " in its search box at the top right of the display window to get the related post quickly.
Sep 27, 2015 | Sharp Aquos Televison & Video
VW37L 37 in. LCD HDTV input button wont work
Have you find out if the problem is with your remote control? For instance, you are able to control your TV using a Universal remote control. My 32" Vizio TV had a similar problem, initially thought it was related to my remote control but in fact the TV didn't respond either to an universal remote control of my SAT receiver that I eventually use to just turn on and off the TV. I've found out that the problem was with a little board on the TV located at the left down corner viewed from the front side of the TV and that receives the signal from the remote control. I found the board on ebay for about $5, replace it and the TV responded again to both original and universal remotes.
Nov 11, 2013 | Vizio VW37L 37 in. LCD HDTV
Samsung LE32C450E1W TV remote control stopped working, changed batteries no luck, turned off at power source for 30 min which fixed prob temp but has happened again and now turn off doesn't help....
Check the remote control for its infrared emission. Check it with fresh batteries. Clean the battery contacts inside its battery compartment. If these do not help you, you remote control need cleaning. If you wish to know more about how to clean and repair a remote control check this site. Pull up older posts. One among it has details.
Mar 24, 2013 | Samsung TV Remote Control
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Nov 15, 2011 | Vizio VA26L 26 in. LCD HDTV
The Remote Control will not turn on the Television, nor will any of the other remotes that I used to use.
The following is based on the assumption that none of the remote control functions work even after the set is turned on, but the set can be operated normally with its front panel control buttons.
Spray a small amount of window cleaner on a soft cloth or facial tissue and use it to gently clean off the plastic window over the remote control receiver on the TV. It may be obscured by tobacco tar or a child's smeary fingerprint.
If that doesn't work, then the remote control receiver circuit needs repair.
Oct 27, 2010 | Emerson EWF2703 27" TV
I cant seem to program my RCA universal remote to my emerson tv
May 28, 2008 | RCA Universal Remote Control
RCA 32V550T 32" TV Logo
106 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
