Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Kenmore dishwasher model #587.16252402
There is a little light that looks like lock and it is on, but i cannot turn on my dishwasher. I know there is a way to turn it off but i cannot remeber please help thaks
  • Tomeka16 Sep 12, 2008
    I am having the same problem, same model no., but pressing the button and holding it down for 6 seconds did not work. I even tried to switch the breaker, but that didn't work either. Help!
    Novelist:
  • 171 Answers
Hi stmike1georg
I'm Harvey the Master Plumber.
You want to know how to unlock the controls on your dishwasher?
No problem. You'll notice the lock light is next to the "heated dry" button. Just press and hold till the lock light goes out, about 6 seconds. The same process will turn the lock light back on. Perhaps the last time someone touched it they held it too long.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 11, 2008
Kenmore ultra wash dishwasher
Look carefully at your dishwasher keyboard, to see what key is nearest (above or below) the lighted lock symbol. Usually it's the Heated Dry button. Whatever it is, press and hold that key for 5 seconds. That should unlock you dishwasher and you can now use it normally.
Jul 17, 2014 | Kenmore Dishwashers
Kenmore mdl 665.16034401 dishwasher
does your panel have a lock button on it? if so press and hold button for 5 sec to try to unlock if not post your model number so i can give you the sequence
Nov 21, 2007 | Kenmore 16602 / 16604 / 16609 Built-in...
I have a 3022 13929991 Ken Elite Dishwasher - I need to know where i can pull up a mannual got this at Sears Outlet Control lock is on and i can't get it off thanks for your help
Normally you should press the child lock for about 6 secs to turn it off. But if there is a fault in dishwasher then child lock light will be on or flashing.
This means some diagnostics is required to find the cause of the fault.
However, I don't think you have provided the correct model number of your kenmore elite dishwasher.
Normally it should be 665.xxxx Please check the model number carefully and post a comment.
Nov 26, 2010 | Kenmore Dishwashers
My Kenmore dishwasher model 665.17604301 has the LOCK ON light on and the dishwasher won't run. How can I turn the lock off?
The LOCK ON can be turned on or off by pressing and holding the AIR DRY button in for 4 seconds. This feature is used to prevent accidental use of the dishwasher, and/or small children from manipulating the control panel. These instructions are on page 15 of the Owner's Manual. If you no longer have a manual, you can download or print a FREE copy at managemylife.com.
If you still require assistance, please post back and let me know. I hope this information is helpful to you.
Sep 22, 2010 | Kenmore Dishwashers
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
"Lock-on" light flashing
heated dry and normal toggle untill all lights light up then turn unit off. try that
Jan 02, 2009 | Kenmore 15899 Built-in Dishwasher
Kenmore ultra wash dishwasher control lock light flashing
Just press the 'Air Dry' button for 5-6 seconds....I have an ancient Kenmore Dishwasher (ULTRA)
Oct 02, 2008 | Kenmore 15899 Built-in Dishwasher
The control lock on button will not go off
I've tried the NOHEAT button but I just get a few blinks on the lock light and the problem persists.
Any Ideas?
May 23, 2008 | Kenmore 16919 Built-in Dishwasher
Dishwasher electronic panel locked
remove the touch panel and unplug it for couple of minutes. it should reset>
Aug 20, 2007 | Kenmore 15899 Built-in Dishwasher
Dishwasher "lock on ' control wont turn off
Hold the control lock in for more than four seconds. See if that works.
Jul 25, 2007 | Kenmore 15762 Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
232 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
